Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. May 7, 2019 at 8:51 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    I spend more time keeping the underbody clean than i do the body lol
    Thunder Fist and InfernoChalupa like this.
  2. May 7, 2019 at 9:38 AM
    T4golfR
    T4golfR Golf dad > Soccer mom
    Allen
    HSV, Alabama
    08 T4R
    Golf club accommodation mods
    Yall every wonder why Alabama doesn't have it's own primary thread like some other states? Why are we tied into a combination of NC, SC, WV, and VA?
  3. May 7, 2019 at 10:53 AM
    tweakit88
    Leroy IL
    Only the best.
    Does anybody in here have a coilspring compressor with skinny spring seats?
  4. May 7, 2019 at 11:02 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I had never thought about that, but I think we warrant our own thread.
  5. May 7, 2019 at 12:12 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Screw painting!!!!!!!
    That is all
    pat's taco likes this.
  6. May 7, 2019 at 12:43 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I'm right here. Bored out of my mind.
    I have been playing around with a new design for some bed bars though. Trying something new. Any suggestions on this? This is the side support that will rest on the bed side.
    baldridge and pat's taco like this.
  7. May 7, 2019 at 1:06 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    @Jerneyman how hard would it be to make some of these but longer? I would like them to be 14” instead of 10”. Asked kB about buying just the supports since it’s “max modular” but he didn’t want to play ball.
    pat's taco and InfernoChalupa like this.
  8. May 7, 2019 at 1:32 PM
    Jerneyman
    Wes
    Huntsville, AL
    Wouldn't be too hard. But if you keep the top the same width, that angle will have to change a bit. Also, the slots and square holes would end up being a bit different as I'm only a equipped with a plasma cutter that's as steady as my hand. These type of parts are better to be CNC cut due to all the specific dimensions.
    I'd have to do a 3D model and figure out the new dimensions and really Id need the old support to in order to get the hole spacing for everything else that bolts to it.
    Leman[QUOTED] likes this.
  9. May 7, 2019 at 1:36 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    IDK man, everything just went downhill after the meet up lol
  10. May 7, 2019 at 1:57 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Wires are ran down the passenger side of the vehicle. Then drilled through the bed at the base of the rack. I forgot the specific wire I used but you can get it at Lowe’s and it’s 4 14awg (IIRC maybe 12) wires together in a thick rubber tube. Gave me a circuit for the backup/side lights, bed lights, 12v outlet, and an extra Incase I ever add a fridge.
    InfernoChalupa likes this.
  11. May 7, 2019 at 2:17 PM
    tweakit88
    Leroy IL
    Only the best.
  12. May 7, 2019 at 2:49 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Have a fuse panel on the drivers side fender in the engine bay. Fed by an extra battery cable. Wires that switch the relays feed into the cab from a hole I poked in a harness grommet up by the brake pedal.
  13. May 7, 2019 at 6:59 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Buddy of mine. 1986, 345k miles, 4cyl, manual. Runs and drives good.
    stronghammer and pat's taco like this.
  14. May 7, 2019 at 7:27 PM
    Jerneyman
    Wes
    Huntsville, AL
  15. May 7, 2019 at 7:28 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    The slow tear down begins. Taking off skids / sliders to repaint and reinforce. Also need to touch up the frame while I’m at it.
  16. May 7, 2019 at 7:31 PM
    BamaTaco56
    Trey
    Darn you. I was convinced square tube all around would look alright. That looks much better
    Jerneyman[QUOTED] likes this.
  17. May 7, 2019 at 7:34 PM
    Jerneyman
    Wes
    Huntsville, AL
    I’m just here to make things difficult :D
    JKU3000 likes this.
  18. May 7, 2019 at 8:05 PM
    T4golfR
    Allen
    HSV, Alabama
    08 T4R
    Random thought while putting up dishes tonight. How has Gucci not come out with a baby brand and named it Gucci Goo?!?! Why have they not capitalized on this million dollar market plan?!
  19. May 8, 2019 at 1:56 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    The real question is why are you thinking about Gucci?
    stronghammer likes this.
  20. May 8, 2019 at 1:59 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Bart
