Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. May 13, 2019 at 6:25 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    btw for those who don't have bed stiffeners...this guy ended up having to replace his bed because it spread too far and cracked.
    60111077_10162005811380790_3706964282945_5f729bb4fa03af761b70c85a45b0a2491901e2eb.jpg
    JKU3000, rmepilot and Brian422 like this.
  2. May 13, 2019 at 6:31 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    If you get tired of grinding it will teach you to weld better:anonymous:
    rmepilot likes this.
  3. May 13, 2019 at 6:32 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
  4. May 13, 2019 at 6:32 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    From a structural standpoint, I think the bed rack I have (weld together All Pro) inversely stiffens the bed. I just don't see the rack itself spreading apart at the bed rail level. That being said, I don't ride around off road or on road with the tent mounted. Only when we go camping. Thoughts?
    stronghammer[QUOTED] likes this.
  5. May 13, 2019 at 6:34 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I agree. I believe bed racks, or bed bars do act as sort of bed stiffeners/supports. It's usually the camper shells, which also flex, that cause the bed spreading.
    For me, 100$ for never having to worry about it was worth it..
    Toyotacrawler[QUOTED] likes this.
  6. May 13, 2019 at 6:35 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    yeah the stairs was a game changer for me for sure. also being cordless is great, though you can't vacuum the whole house on one charge. the time it saves though I'm more than willing to hit a room or two or whatever every couple days and not lump vacuuming the whole house into one day.
    rmepilot[QUOTED] likes this.
  7. May 13, 2019 at 6:35 AM
    JBTacoma
    Jeff
    Cullman Alabama
    2nd gen problems :rolleyes:
  8. May 13, 2019 at 6:36 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Yea as long as the rack doesn't have a constant load on it all the time you should be fine. But when you have the money i would just go a head and get the bed stiffeners just to be safe rather than sorry.
  9. May 13, 2019 at 6:36 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Ahh 10-4 I gotcha.
  10. May 13, 2019 at 6:40 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Well yesterday when I was working on the tire carrier, I decided to jack the front end up and check for play in my wheel bearings. Discovered my Driver side Front is toast. Ordered a pre assembled hub with bearing and all the seals from eBay. The seller uses all OEM components so I'm hoping for a an easy swap when it comes in. Here's to hoping that this is the source of my incessant "humming" coming from my tires.
  11. May 13, 2019 at 6:41 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    how much that run you if you don't mind me asking? Bill still sells his wheel bearings and mind have held up great is why I ask
    Jerneyman[QUOTED] likes this.
  12. May 13, 2019 at 6:43 AM
    Jerneyman
    Wes
    Huntsville, AL
    stronghammer and rmepilot like this.
  13. May 13, 2019 at 6:48 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    tweakit88 likes this.
  14. May 13, 2019 at 6:51 AM
    Jerneyman
    Wes
    Huntsville, AL
    When I was doing some research, I came across that he made pre assembled hubs as well but for now, ordering through ebay was quickest and easiest. If I've got more time next time this happens, I'd rather go with someone like Bill but I'll be happy if these work out well. Can't beat the price for genuine Toyota bearings.
  15. May 13, 2019 at 6:51 AM
    JBTacoma
    Jeff
    Cullman Alabama
  16. May 13, 2019 at 8:16 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    tweakit88 and pat's taco like this.
  17. May 13, 2019 at 9:49 AM
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    Bilstein 5100 at .65 265/70/17 tire and the level 8 mk6 wheels 17x8 0 offset I believe
    ty.s07[QUOTED] likes this.
  18. May 13, 2019 at 9:54 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Those MK6’s tho! I need a set of wheels.
  19. May 13, 2019 at 10:06 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    tldr
    pat's taco and InfernoChalupa like this.
  20. May 13, 2019 at 10:19 AM
    rmepilot
    Rob
    Huntsville, AL
