Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. May 30, 2019 at 12:38 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Yes for a locker They are more dependable than air
    JKU3000 likes this.
  2. May 30, 2019 at 12:39 PM
    JEtaco03
    JEtaco03 Well-Known Member
    Justin
    New Market, AL
    08 Tacoma TRD
    Lifted on 18s and tires, LEDs all around
    @BAMATOY I've got a 10x10 that i use for the beach you can borrow if you still want. The bags of sand are the best idea for keeping it in place on the beach. Just tie them to the top corner post to get the weight in the right place or a good wind will just break the leg off, "ask me how I know". I've also got a large beach umbrella that we took with us last year. I'm in huntsville every day if you want to meet up and grab them.
    T4golfR and InfernoChalupa like this.
  3. May 30, 2019 at 12:53 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Dont you have to replace the whole axle though? Also i have 4.56 gears not sure if it will work with them?
  4. May 30, 2019 at 1:00 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Yes you would need the entire axle but you can modify yours, you can find just about any gear ratio you need. It takes a little work but very doable. If you have to get someone to do it for you it's probably not worth it.
  5. May 30, 2019 at 1:42 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Get straight leg not stand leg. I got a lot of first hand experience with pop ups over the last year hosting a tailgate every weekend on the quad. I got an ozark trail 10x10 for $50-60 and it’s about the best you can get for the cost
    T4golfR[QUOTED] likes this.
  6. May 30, 2019 at 2:33 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    No problem bud, let me know if you still like to use it tho. Then youll have 2 lol.
  7. May 30, 2019 at 2:35 PM
    tweakit88
    Leroy IL
    Only the best.
    Got mine on sale for $44 works good. Can even have a fire under it in the snow at windrock ;)
  8. May 30, 2019 at 2:59 PM
    tweakit88
    Leroy IL
    Only the best.
    If i ever front lock ill be going elocker. Few hundred more but after seeing all the air leak issues everybody have i think it would be worth it.
  9. May 30, 2019 at 3:23 PM
    JBTacoma
    Jeff
    Cullman Alabama
    They finally got mine fixed but electric is more dependable
    tweakit88[QUOTED] likes this.
  10. May 30, 2019 at 3:44 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    See that pyramid rock at the top on the right? Rear started climbing the stair I need up and then the driver side slide backward but the passenger held , kicked the truck hard right into the rock.
    JBTacoma[QUOTED] and tweakit88 like this.
  11. May 30, 2019 at 3:49 PM
    TacoAlaMode
    Brian
    Huntsville AL
    ECGS had a good price when I got mine regeared and locked.
    JKU3000 and tweakit88 like this.
  12. May 30, 2019 at 4:59 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    As far as airline leaks that’s the only thing if installed correctly. Air lines eventually need to be replaced. So does wiring in some cases.
    I know the stock lockers aren’t as strong as the ARB lockers, but that doesn’t mean I’d swap one for ARB. I’d be curious to see how strong the Harrop Elocker is compared to ARB though.
    Also, idk if you can find deals on the Elockers. That one front Elocker at $1400 costs the same I’ve got in my whole setup locker F/R, Dual Compressor, and miscellaneous mounting parts.
  13. May 30, 2019 at 5:01 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Dude I just sold a brand new RTIC 10x10 for $60 bucks.
  14. May 30, 2019 at 5:05 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Bed stiffners installed!
  15. May 30, 2019 at 5:41 PM
    tweakit88
    Leroy IL
    Only the best.
    What did you pay total? Mine was
    They were just on sale for 1100. And im talking about when people engage them and pressurize their entire diff and start blowing oil out of the breather
    JBTacoma likes this.
  16. May 30, 2019 at 5:46 PM
    JBTacoma
    Jeff
    Cullman Alabama
    A lot of people have problems with the air lockers. Compressor, lines, electrical, seals... I know the front air locker is stronger not sure about the rear. If anything goes wrong on the trail with the air locker you can't use it. E-locker you can pull the motor and engage and disengage it with a screw driver
    tweakit88 likes this.
  17. May 30, 2019 at 5:47 PM
    JBTacoma
    Jeff
    Cullman Alabama
    That happened to me 3 times
  18. May 30, 2019 at 6:18 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Any of y’all have the factory roof rack or Thule setup laying around you’re not using anymore? Needing a roof rack for work, but don’t want the prinsu rack and figured I’d ask before buying new.
  19. May 30, 2019 at 6:39 PM
    baldridge
    Bart
    Auburn, AL
    A guy has one for sale in AL Tacoma FB page. It’s a gen 2 but think it fits a gen 3 too (if I’m wrong someone will correct me). He is only asking $100 bucks.
  20. May 30, 2019 at 6:40 PM
    tweakit88
    Leroy IL
    Only the best.
    Stupid expensive
    InfernoChalupa likes this.
