Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jun 13, 2019 at 7:25 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    If you get rid of the fender liner and get spc control arms and max out the caster you could probs do it with a 2 inch lift
    cubie likes this.
  2. Jun 13, 2019 at 7:25 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    I watched last line of defense’s video on fitting 35s. He stated he can’t stuff his tire in his wheel well, but he did fit them. To be fair, fitting 35s and wheeling with 35s are different things.
    @stronghammer will tell you how much it takes to fit 35s for wheeling
  3. Jun 13, 2019 at 7:25 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I can run a skinny tire 255/75/17 with a mild lift and no chopping. Isn't that a 33" inch tire?
  4. Jun 13, 2019 at 7:27 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I ran 255s and still had to chop.
  5. Jun 13, 2019 at 7:27 AM
    BamaTaco56
    Trey
    It’s a 32. 255/80/17 is a 33
    InfernoChalupa likes this.
  6. Jun 13, 2019 at 7:28 AM
    BamaTaco56
    Trey
    We’re you running spacers?
  7. Jun 13, 2019 at 7:34 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    That's funny, there are folks in the Skinny Tire thread that say they are running 255s on stock suspension.
  8. Jun 13, 2019 at 7:35 AM
    BamaTaco56
    Trey
    @Sandytaco14 ran 33” skinnies on stock suspension. Not sure how much wheeling he did with them before the lift went on though.
  9. Jun 13, 2019 at 7:36 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Correct
  10. Jun 13, 2019 at 7:37 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    255/80r17
    InfernoChalupa and cubie[QUOTED] like this.
  11. Jun 13, 2019 at 7:37 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Awesome Mark, thanks bro! I was about to do some process of elimination, but looks like you did it for me! I know offset and backspacing affects what size you can run without rubbing. I'm positively certain that I will not run a tire bigger than 32" or 33".
  12. Jun 13, 2019 at 7:37 AM
    tweakit88
    Leroy IL
    Only the best.
    I havnt chopped or cut anything at all
    InfernoChalupa and cubie like this.
  13. Jun 13, 2019 at 7:38 AM
    BamaTaco56
    Trey
    Front bumper, front fender, rear bumper, and cam tabs
  14. Jun 13, 2019 at 7:40 AM
    tweakit88
    Leroy IL
    Only the best.
    Jba's much better quality and you can get up to 5°+castor if you so choose
  15. Jun 13, 2019 at 7:42 AM
    tweakit88
    Leroy IL
    Only the best.
    I ment to clear 33's jerk :p
  16. Jun 13, 2019 at 7:42 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I was JUST looking at that! I narrowed it down to those 2, but didn't understand positive and negative offset, but with your explanation, it makes sense now. Negative offset pushes your wheels away from the truck.
  17. Jun 13, 2019 at 7:42 AM
    BamaTaco56
    Trey
    :rofl:
  18. Jun 13, 2019 at 7:43 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
  19. Jun 13, 2019 at 7:44 AM
    tweakit88
    Leroy IL
    Only the best.
    Also i havnt cut front fenders
  20. Jun 13, 2019 at 7:46 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    SPC been great for me so that’s all I know about right now. Now especially that they went to the one piece design. I have the older model though because I got them right before they came out with the newer ones.
    tweakit88[QUOTED] likes this.
