Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Jul 22, 2019 at 5:28 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    Stump Jumper!!
  2. Jul 22, 2019 at 6:03 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    :drool::drool::drool:
  3. Jul 22, 2019 at 6:31 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    For your guys still needing a lift and wanting big tires. ;)
    JKU3000 likes this.
  4. Jul 22, 2019 at 6:33 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I bet that thing is a pig on the road and trails.
    It’s nice, but 10” of lift it looks like, I’d still rock it.
  5. Jul 22, 2019 at 10:38 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    I've got a problem that I can't figure out. I backed a trailer into a police car last year and smashed the right side light. I continued using it until last Sunday when I replaced the entire light unit with an identical one. It didn't surprise me when the brake/blinker light didn't work in the new light because that's the one that got smashed. And I continued backing into water for a year, so of course it was shorted. Here's the problem; I can't find any blown fuses under the dash or the hood. I swapped some relays related to trailer or towing but I can't find the problem.
    The problem isn't in the trailer. I measured at the truck's 4-pin connector (factory tow package). Everything is fine except for the right side brake/blinker (same wire which is green). It gets 300mv (I'm assuming background noise?) when it should be off, and it rises to 1.3 volts when it should be getting 13.66 volts (what I measured the other circuits at).
    Anyone got any ideas?
  6. Jul 23, 2019 at 1:05 AM
    Drumhed
    Drumhed Well-Known Member
    Jake
    17 TRDOR DCSB
    About Windrock.... I asked for a clump of days off, and got them. Now I'm like... "Uhh... I can make it to Colorado, wheel for 2 days, and make it home on-time". Anyone else got enough time for Rim Rocker?
    JKU3000 likes this.
  7. Jul 23, 2019 at 3:18 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    JKU3000 likes this.
  8. Jul 23, 2019 at 4:07 AM
    tweakit88
    Leroy IL
    Only the best.
    Thanks sir
    baldridge[QUOTED] likes this.
  9. Jul 23, 2019 at 5:03 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    JKU3000 likes this.
  10. Jul 23, 2019 at 5:18 AM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    I probably missed some posts, but was the other one trashed?
  11. Jul 23, 2019 at 6:07 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    JKU3000 likes this.
  12. Jul 23, 2019 at 6:17 AM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Release the clip under the bumper and see if you can check it there.
    JKU3000 likes this.
  13. Jul 23, 2019 at 6:21 AM
    JEtaco03
    JEtaco03 Well-Known Member
    Justin
    New Market, AL
    08 Tacoma TRD
    Lifted on 18s and tires, LEDs all around
  14. Jul 23, 2019 at 6:23 AM
    tweakit88
    Leroy IL
    Only the best.
  15. Jul 23, 2019 at 6:24 AM
    tweakit88
    Leroy IL
    Only the best.
    Thanks you
  16. Jul 23, 2019 at 6:26 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I would've been okay with the body. It was the fact both knuckles were leaking, the rear 3rd was leaking out from the pinion.
    He also said that the turbo oil return line broke and that's why there's oil on backside of engine and transmission on the bottom of the engine.
    The swap itself was great VW parts and adapter, it was all the Toyota parts that he didn't take the time to fix before doing the swap.
    I will say 4.10 gears and 35's that little 1.9L TDi made that thing scoot. The TDi only had injector nozzles changed, cheap, and a tune, also cheap and it basically doubles the power of the engine. I also think that engine weighs less than the 2.4 that's in it originally. I really think VW had the best economic 4 cylinder engine ever.
    edit I was wrong, for about $600 you take that TDI from 87 WHP to 146 WHP.
  17. Jul 23, 2019 at 6:28 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    @JBTacoma
  18. Jul 23, 2019 at 6:29 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    @JBTacoma might be down for a few more days at windrock
    JKU3000 likes this.
  19. Jul 23, 2019 at 6:51 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  20. Jul 23, 2019 at 6:55 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
