Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 6, 2019 at 12:04 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Check out Terrapin Creek. It's a great little float for kids. Even has rope swings and cliffs you can jump/dive off of.
    https://youtu.be/FvJ90p17r10
  2. Aug 6, 2019 at 12:24 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Looks decent. Didn’t watch whole video due to how long it takes to load a video but saw bout half of it. May check it out next time we decide to go out. Thanks
  3. Aug 6, 2019 at 12:33 PM
    Nimbostratus
    Nimbostratus Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    Tell him to shoot me an offer.
    InfernoChalupa likes this.
  4. Aug 6, 2019 at 2:17 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    If you want to look in to the 5160s, look at the 7100s, they’re essentially the same but the 7100s are rebuildable and can be valved how you want them. Not sure if they make a bolt on version for the Tacoma though. I’ll be buying a set for my truck soon with stiffer valving to fix my body roll. Scotty is getting my current 5125 shocks when I do his relocation.
  5. Aug 6, 2019 at 2:27 PM
    Jerneyman
    Wes
    Huntsville, AL
    I don’t think the 7100 comes in a bolt on configuration anyway... but you can’t go wrong with Bilstein. The 5160 would be a definite improvement for sure.
  6. Aug 6, 2019 at 2:30 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Could you run those 5160s with the rear lifted 2", for instance, with a Dakar or Deaver pack? Or just for stock config?
  7. Aug 6, 2019 at 2:34 PM
    Jerneyman
    Wes
    Huntsville, AL
    I'm not sure on that. I'd check compressed and extended lengths of them and compare it to the B110s or any other shock used for lifted applications. I know I ran stock length 5100s with an AAL and the shock limited the suspension's down travel which is a real no-no if you can avoid it.
    cubie[QUOTED] likes this.
  8. Aug 6, 2019 at 2:35 PM
    Jerneyman
    Wes
    Huntsville, AL
    If you want to use a leaf pack to its fullest, the only real way to not have to extend bump stops is to do a shock relocation.
    ovrlndkull and InfernoChalupa like this.
  9. Aug 6, 2019 at 2:37 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Thansk! I see. I'm eventually going to change my rear packs out to something that will give me around 2" over stock. @TacoAlaMode got some custom built springs from somewhere I can't remember, but he seems to be really happy with them. I also want a shock that will handle all the droop that the new spring pack will offer. I guess B110s unless I hear of any other options out there. I've seriously been looking at Dobinsons too.
    Jerneyman[QUOTED] likes this.
  10. Aug 6, 2019 at 2:39 PM
    Jerneyman
    Wes
    Huntsville, AL
    There's the answer. But comparing the collapsed length, you'll have to extend your bump stop an extra 2 inches or you'll eat that b110 alive under hard compression. Just things to consider. Now if the leaf pack is thicker, that will help as well since it'll basically "extend" your bumpstop. You just need to make sure you account for everything.
  11. Aug 6, 2019 at 2:44 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    When I get new leaf packs, I'll add the u-bolt flip kit alongside it, since I'll already have everything apart.
    JKU3000 likes this.
  12. Aug 6, 2019 at 3:03 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Alcan Springs
    JS760 likes this.
  13. Aug 6, 2019 at 3:11 PM
    JMY24
    JMY24 Well-Known Member
    Huntsville AL
    '05 white TRD OR DCSB
    3 inch TOYTEC lift with Bilsteins Total Chaos uniball UCAs BAMF sliders
    So there are Tacoma’s EVERYWHERE here in enterprise. I’m new here soooo where all my rucker area people at?
    cubie and JKU3000 like this.
  14. Aug 6, 2019 at 3:13 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Idk of anyone near there or Dothan in this group.
    JMY24[QUOTED] likes this.
  15. Aug 6, 2019 at 3:15 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    I’m in Ozark till Friday
  16. Aug 6, 2019 at 3:15 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    This group makes the Bermuda Triangle. Anywhere from Tuscaloosa to Anniston in all the way up to Huntsville, every regular
    In here can be found somewhere in the triangle
  17. Aug 6, 2019 at 4:44 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    If i ever get on here in the future and start talking abouy buying another house, somebody please find me and beat some sence into my stupid ass. This sucks lok
    JEtaco03, stronghammer and JBTacoma like this.
  18. Aug 6, 2019 at 5:11 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Yep and it will continue until you close
    tweakit88[QUOTED] and ovrlndkull like this.
  19. Aug 6, 2019 at 5:59 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I ran the wheelers bumps with their ubolt flip on my deaver expedition stage 3 leafs and they were just fine paired with the b110s. I know a bunch of guys that ran that combo with the dakars as well and did just fine. The wheelers kit spaces the bump up some to accommodate for the collapsed length. Still had plenty of bump and droop.
  20. Aug 6, 2019 at 6:14 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Surprisingly mine was pretty straight forward. The house was solid as far as roof, ac, foundation, and no mold. It just needed to be badly updated as everything’s outdated.
    If you’re on the fence do inspection pending and if they don’t fix even one thing you like them to you can walk away and just lose inspection money if I understand correctly.
