Alabama thread!
Discussion in 'South East' started by Davtopgun, May 18, 2009.
  1. Jun 12, 2019 at 6:06 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** CBI Offroad Moab 2.0 Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs 1.5 inch AAL Rear Bilstein 5100s COMING SOON: Chevy 63 Swap **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 255/85/16 Cooper STT MAXX **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable Ammo Can Bed Rail Tool Box Cab Mount Chop Pinch Weld Mod (Mini Sledge Special)
    My sliders need a beating too. Be the first time to really use them. Guaranteed they’ll be used this trip.
    tweakit88 and InfernoChalupa like this.
  2. Jun 12, 2019 at 6:28 PM
    InfernoChalupa
    InfernoChalupa Using CRAWL control on Bunny Trails
    Mark
    Birmingham,AL
    2016 Inferno DCSB TRDOR
    Child booster seat, spilled glitter slime, chicken nugget crumbs, spilled milkshake in cupholder, and many more courtesy of daughter.
    Jonny’s right; this is the new bed mat mount! They’re just used sooooooo much I need to keep them handy.
    baldridge likes this.
  3. Jun 12, 2019 at 6:43 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    Two 2000 SR5s and a 2003 Limited Double Cab
    :worthless:
    tweakit88 likes this.
  4. Jun 12, 2019 at 7:43 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    You already had pictures, you just didn’t look close enough!
  5. Jun 12, 2019 at 8:21 PM
    JBTacoma
    Jeff
    Cullman Alabama
    I guess i didn't, lol
    Looks good
    JKU3000 likes this.
  6. Jun 13, 2019 at 4:05 AM
    TacoAlaMode
    Brian
    Huntsville AL
    Charter captain bailed on us this morning. Trying to see if we can line up a boat for tomorrow. If we do, I’ll end up missing Choccoloco.
    JKU3000 likes this.
  7. Jun 13, 2019 at 4:21 AM
    pat's taco
    pat's taco Well-Known Member
    Gulf Coast
    2013 XSP-X DC
  8. Jun 13, 2019 at 6:06 AM
    whitedlite
    whitedlite Insta @loadedtacos.. budget built
    Central AL
    Inferior TRD 4WD
    So check this out, my thoughts are it would be easier to go ahead and run the bolt through the bushing and mount then weld, but idk.
    Anyways, interesting, but also 150-170 seems high?
    https://www.alpinedesignsoffroad.com/product/2005-2015-toyota-tacoma-front-cab-mount-relocation-kit
    Kenny Moved your post to the first page. :cheers:
    New and improved cab chop done today :headbang:
    Alpine Designs relocate plates. Basically they take place of that monstrosity triangular piece everyone likes to hack away at, and moves the bracket further back while keeping the cab mount in the same spot. All in all it was a huge pain in the ass; but after some trial and error could be done in half the time especially if the truck could come off the ground more. Can't thank @Bigdaddy4760 Mike enough for all the help and letting me use his space :fistbump:
    A little before action. You can see with after my original chop, my tires were still eating away at it, and that wasn't even at full lock.. Time for that fucker to go..
    After some burning and grinding, same view
    The real burning man. Again without a lift, it makes this project that much more miserable
    You can see how the bracket is designed and intended here. Keep in mind I still need to do a bunch of little grinding work to clean the old cuts up, but with some time restrictions we did what was needed to finish it up; and I can always go back and clean those up another time. His welds weren't skipped though :benchpress:
    And BAM.. The clearance gained is awesome..
    At full lock. Before, the tire would start rubbing about halfway down on there.. A couple inches does wonders, ask any woman out there.. It might still look close, but with these tires this is a killer improvement
    I feel I've gained 7-33 hp from the weight shaved off as well
    And nothing better than taking numerous breaks in between to check on these bad boys. I'm gonna continue on to my meat coma. Thanks for checkin' it out! :thumbsup:
    pat's taco and InfernoChalupa like this.
  9. Jun 13, 2019 at 6:17 AM
    InfernoChalupa
    Mark
    Birmingham,AL
    Id definitely run the bolt through the mount first too. Sure would suck to weld it up only to be barely off..
    also, why is it always called a relocation? The body mount stays in the same spot. Why not call it a low profile cab mount bracket or something similar?
  10. Jun 13, 2019 at 6:24 AM
    BamaTaco56
    BamaTaco56 #GreenTrailTeam
    Trey
    Tuscaloosa, Alabama
    2015 Tacoma TRD Off Road 4x4
    Archive garage made a good point about those relocate kits not too long ago.
  11. Jun 13, 2019 at 6:41 AM
    Brian422
    Brian422 Well-Known Member
    Brian
    Birmingham
    2012 Tacoma Dbl Cab
    A Buck Fity Protein powder one eyed snake SUSPENSION 2.5 Radflow remote resi front and rear SPC upper control arms Wheelers super bumps 2 inch add a leaf ARMOR Dv8 Front Bumper RCI Front IFS Skid WINCH, TIRES, LIGHTS Badlands 9000lb winch (works great with zero issues) nitto tires Moto Metal 970 18x10 -24 amp power steps Ledheadlights Spyder Led taillights Spyder 20inch light-bar Flowmaster exhaust SOUND SYSTEM Sony xav-ax 100 head unit 2 kicker shallowmounts in a ported box Rockford fosgate p3 all the way around speakers MISC Kobalt toolbox Weathertech floor mats CMC KB Voodoo Heavy Duty Bed bars Victory 4x4 Roof Rack Smitty Built overland Tent
    Hey man what rear bumper are you running? I really like that design! Or whose that is lol!
  12. Jun 13, 2019 at 6:44 AM
    whitedlite
    Central AL
    Inferior TRD 4WD
    I cant say I disagree, plus if you just trim the hell out of existing cab mount on the front side the back side should hold up to any impacts.
  13. Jun 13, 2019 at 6:49 AM
    BamaTaco56
    Trey
    Tuscaloosa, Alabama
    That’s the train of thought that he was following as well. Even without filling the CMC back in, you still retain most of the structural support
  14. Jun 13, 2019 at 6:50 AM
    cubie
    cubie Asian Redneck
    Jonny
    Sweet home Alabama with a shotgun, rifle and a 4wd
    '18 TRD OR 4x4 Access Cab
    None
    What's the purpose of this? Just to clear bigger tires?
  15. Jun 13, 2019 at 6:52 AM
    InfernoChalupa
    Mark
    Birmingham,AL
    yep, prevent rubbing on bigger tires
    cubie likes this.
  16. Jun 13, 2019 at 6:55 AM
    cubie
    cubie Asian Redneck
    Jonny
    None
    That's a lot of cutting and welding just to clear bigger tires! lol
  17. Jun 13, 2019 at 6:56 AM
    Brian422
    Brian
    Birmingham
    2012 Tacoma Dbl Cab
    Thats why i just got a simple cab mount chop. With spc control arms and the right offset you can clear up to 35's. Well 35 11.50
    cubie likes this.
  18. Jun 13, 2019 at 6:58 AM
    InfernoChalupa
    Mark
    Birmingham,AL
    this was from the video I posted a little bit back the last time we were talking CMC's. I kinda came to the conclusion that its just the risk everyone takes when modding their vehicle in any way. The way I see it, the same risks are at play when going larger tires, lift, spacers, etc. I guess it was technically designed to deflect a 30" tire, not spaced an extra inch or so in or out of the wheel well, at stock height.
    cubie likes this.
  19. Jun 13, 2019 at 6:58 AM
    cubie
    cubie Asian Redneck
    Jonny
    None
    I don't wanna chop anything on my truck! lol I guess if I can't fit it under the wheel well, then I'm not gonna run it!
  20. Jun 13, 2019 at 6:59 AM
    InfernoChalupa
    Mark
    Birmingham,AL
    Its all about your wheel specs and UCA's honestly. @tweakit88 can speak from experience, running 33's no CMC, correct?
