Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 31, 2019 at 2:47 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Yeah, I can show them where to put your finger when installing the bushing. image.jpg
    JKU3000 and R4MBLN_YOTA like this.
  2. Aug 31, 2019 at 3:05 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Looks like that one sticks out a little further than the rest.
  3. Aug 31, 2019 at 3:36 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Eibach Coilover Lift Cooper 285's on Ar23’s BHLM w/ Morimoto Halos Custom Hybrid Front Bumper Custom High Clearance Rear bumper Custom Sliders (weld on) RCI skids Sway Bar Delete CMC WILCO Spare Tire Carrier Auxbeam/ Opt7 lighting components Hella LED Pods RC 30 inch Lightbar Smittybilt XRC Synthetic Winch Timbren Bumpstop/ U-Bolt Flip Rear Diff Breather Relocate
    15E80372-5362-4A87-95AD-E5567392E1B0.jpg C4B4E428-DFF2-4811-8071-91F3E541DA82.jpg
    So I won this Molle panel that mounts to your spare tire. It’s coming in the mail but I don’t really have use for it so gonna try and sell it to buy some progressive AAL’s. Offering it up to you guys before it arrives. Once it’s here I’ll post it in the for sale forum if none of y’all want it. Asking $170
    baldridge likes this.
  4. Aug 31, 2019 at 3:47 PM
    POOLGUY
    JEFF
    ALABAMA
    It does. The other 3 are short from birth defect. Makes that one an easy target.
  5. Aug 31, 2019 at 3:52 PM
    POOLGUY
    JEFF
    ALABAMA
    Test drive: no good! Axel seal leaking. I replaced it, because ecgs recommended to since I have 320,000 miles on it. Wish I didn’t. Now I got to figure it how to fix it.
    Any suggestions?
  6. Aug 31, 2019 at 4:43 PM
    TacoAlaMode
    Brian
    Huntsville AL
    Unfortunately it will be a complete rinse and repeat. There is supposed to be a spring inside it. If it got loose, that could be the problem. They are pretty much impossible to reseat while in the diff. I think replacing the seal is worse than the bearing.
    POOLGUY[QUOTED] likes this.
  7. Aug 31, 2019 at 5:05 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
  8. Aug 31, 2019 at 5:18 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    War Eagle!
    JKU3000 and baldridge like this.
  9. Aug 31, 2019 at 5:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don’t have any pics handy but mine cracked there too. I believe it’s from “spirited driving”. Anyways, first I attempted to TIG it. Split back open next trip out. Then I cut it all out around the crack and welded in a piece of 14 gauge. Has held up thus far.
    JKU3000 likes this.
  10. Aug 31, 2019 at 5:58 PM
    TacoAlaMode
    Brian
    Huntsville AL
    Ask everyone I have wheeled with, but I don’t off-road spirited. But I did run a washboard road out in Moab (22 miles I believe) at 35/40 this spring. Not sure when this happened, just noticed it today though.
    This is going to be a pain to weld up.
    stronghammer and JKU3000 like this.
  11. Aug 31, 2019 at 6:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s the type of driving that’ll do it. I’d bet it cracked then and spread.
  12. Aug 31, 2019 at 6:15 PM
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    Anybody get a video?
    I used to be the weld engineer in a bus frame shop and I now work with the best welder I have ever seen. He might be willing to tig it for you for a price.
    JKU3000 likes this.
  13. Aug 31, 2019 at 6:27 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Roll tide!
    Cred92, JKU3000, R4MBLN_YOTA and 3 others like this.
  14. Aug 31, 2019 at 6:42 PM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    Anybody in here that’s a sparky (EE) or has experience, your help would be appreciated.
    If I run a dual battery setup with this Blue Sea ACR https://www.amazon.com/dp/B001VIXLRO/ref=cm_sw_r_sms_c_api_i_geYADb5SE36KT can I run different sized batteries?
    I was planning on running two group 35s and I bought 1 last week when my stock battery died. But, I just realized I can get a group 31 for less than a 35.
  15. Aug 31, 2019 at 6:47 PM
    baldridge
    Bart
    Auburn, AL
    :facepalm:
    Brian422[QUOTED] likes this.
  16. Aug 31, 2019 at 6:58 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Prediction. Bo Nix starting QB for Auburn until 0-6, then Murphy my Mini Schnauzer will be put in. Soon after Gus will be fired and my pup will take the blame for the horrible 0-11 record.
    Auburn Football 2019 season. :thumbsup:
    JKU3000, InfernoChalupa and baldridge like this.
  17. Aug 31, 2019 at 7:01 PM
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    I thought he done pretty good for a true freshman with a crumbling line and a non-existent defense. Gotta run before you can pass.
    Play calling has been horrible (big surprise there). Agree Gus is gone after this year.
  18. Aug 31, 2019 at 7:03 PM
    baldridge
    Bart
    Auburn, AL
    Gone before the year is out. Can we say interim coach?
    Toyotacrawler likes this.
  19. Aug 31, 2019 at 7:07 PM
    Toyotacrawler
    Cusseta/Opelika AL
    Gus needs to be gone before this game is over. I'm sick of this garbage.
    This on TV is not Auburn football. It's a joke with a side of run it up the middle cause I don't know what to call.
  20. Aug 31, 2019 at 7:13 PM
    baldridge
    Bart
    Auburn, AL
    JKU3000 likes this.
