Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Sep 17, 2019 at 8:24 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    I’m saying I probably have probably have less total torch time than that since I bought the welder
  2. Sep 17, 2019 at 8:27 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    That's possible. I'm only on my fourth bottle and I've been welding a lot a year now. So with my flow rate at 25 CFH, I've welded for roughly 19 hours. Doesn't seem all that impressive.
  3. Sep 17, 2019 at 8:31 AM
    BamaTaco56
    Trey
    What solid core wire do you use?
  4. Sep 17, 2019 at 8:33 AM
    Jerneyman
    Wes
    Huntsville, AL
    I use 0.035" ER70S6 wire. Just your run of the mill mild steel filler wire. I suggest getting a 10 lb spool of Hobart brand wire. I have much less spatter with Hobart brand vs the Lincoln brand you can buy at Lowe's which I've run several times in a pinch. Probably 1/3 of the spools I've used have been Lincoln and they piss me off every time.
  5. Sep 17, 2019 at 8:39 AM
    BamaTaco56
    Trey
    Thanks! I didn’t get the darn 8” spool adapter with my welder...
  6. Sep 17, 2019 at 8:40 AM
    Jerneyman
    Wes
    Huntsville, AL
    Well that sucks. Try and buy one, you'll save a lot of money and aggravation if you don't have to buy those 2 lb spools. Those small ones don't last long enough to complete a decently sized project to be honest.
  7. Sep 17, 2019 at 8:46 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Make sure when you get the bottle it has a date that will still be good after you use all of it. The bottles have to be recertified to be refilled and only good for a few years. Make them give you a newer bottle when you get it refilled. Dont get the same bottle refilled, that way you will not have to buy a new bottle or pay to have it recertified
    BamaTaco56[QUOTED] and Jerneyman like this.
  8. Sep 17, 2019 at 8:55 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    I cant get them to load on here. Its nothing fancy. Just the location and the property are amazing. Its perfect for us. We dont like fancy, we like functional lol.
  9. Sep 17, 2019 at 8:57 AM
    tweakit88
    Leroy IL
    Only the best.
    Thanks sir. Thankfully we have till the 1st tk be out of our rental, so we are gunna do a load a day and not kill ourselves.
  10. Sep 17, 2019 at 8:57 AM
    tweakit88
    Leroy IL
    Only the best.
    Thanks sir. I can see many a bonfire story shared soon.
    JBTacoma[QUOTED] likes this.
  11. Sep 17, 2019 at 9:00 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Hell yeah
    tweakit88[QUOTED] likes this.
  12. Sep 17, 2019 at 9:02 AM
    tweakit88
    Leroy IL
    Only the best.
    Dont forget, first refill is on me. And prolly the firsy 2 hours worth of gas to :rofl:
    Jerneyman likes this.
  13. Sep 17, 2019 at 12:26 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    is it bad i'm admiring this dudes ride that lives around chatanooga area
    07537ee6-6451-485f-8ab2-62c823a25777-jpe_c393f480fb6103ed856a468b650098aedc3f4dff.jpg
    JKU3000, JEtaco03 and InfernoChalupa like this.
  14. Sep 17, 2019 at 12:29 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    i think the 3.6 is proven since it's been used since 2011?!?
  15. Sep 17, 2019 at 12:30 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    1 ply toilet paper has been used for centuries, does that make it reliable? I think not.
  16. Sep 17, 2019 at 12:42 PM
    JEtaco03
    JEtaco03 Well-Known Member
    Justin
    New Market, AL
    08 Tacoma TRD
    Lifted on 18s and tires, LEDs all around
    I would guess the transmission issues probably have more to do with people putting on big tires and lifts without gears. And probably inexperienced off road driving.
  17. Sep 17, 2019 at 12:44 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    rather a finger gets dirty or not is your ass cleaned?
  18. Sep 17, 2019 at 12:48 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    You know I think driving like grannies is a problem when the rpm is right there where it has to shift down at every little hill. Gotta carry some rpm.
    I'm not in the market, though I wouldn't mind test driving one. I could go for a 3.0 diesel mid size though.
    InfernoChalupa likes this.
  19. Sep 17, 2019 at 12:53 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    GM did some impressive stuff with the ZR2. I know diesels and diesel fuel costing more it's barely a break even deal through the life of the vehicle, the difference is drivability.
    I grew up in 3/4 ton and bigger trucks, btw none of that gay lifted crap, just tuned deleted and mostly stock appearance with maybe AT tires, and the shifting and ability to never shift down is huge. They just have great manners.
  20. Sep 17, 2019 at 12:56 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    there was this one guy I talked to on IG that had one built with armor and 33's that said he easily still gets 25mpg not trying and no regear
