Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Oct 18, 2019 at 6:09 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    If you don’t have bed stiffeners, I would get them. It’ll happen over time regardless.
    And Roll Tide!
    JKU3000 likes this.
  2. Oct 18, 2019 at 6:11 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Ive got em already. Ive heard some ppl have problams and some dont. I know some ppl who run ttents and bed racks without them and have zero issues.
    JKU3000 likes this.
  3. Oct 18, 2019 at 6:16 AM
    BamaTaco56
    Trey
    Do they wheel their trucks hard?
    JKU3000 likes this.
  4. Oct 18, 2019 at 6:24 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Not like bang em but they do do trails.
    I remember @TRD Tyler said he didnt use em for a while.
  5. Oct 18, 2019 at 6:33 AM
    BamaTaco56
    Trey
    I guess it ultimately depends on the trail. If you are constantly flexing the rear end hard and making the weight of the bed shift around on the frame it’s more of an issue. If you are doing mild trails and not riding on 3 wheels often it should be fine.
    I think I’ll be boxing the rear section of my frame and running tube braces to minimize frame flex. Maybe that’ll help some.
  6. Oct 18, 2019 at 6:34 AM
    BamaTaco56
    Trey
    What do you know!
    I will say, it’s even on both sides so maybe that’s just normal spacing?
    InfernoChalupa likes this.
  7. Oct 18, 2019 at 6:39 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    you even have bed bars, which I would theoretically think would help bed spreading...interesting.
  8. Oct 18, 2019 at 6:43 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    meh, yes and no....the top still wouldn't spread because as you said that steel isn't going to give. the bottom would spread out or crack as you showed so maybe that's it. idk.
    depending on weight, and the torture put on the bed supports those could also be "failing" by spreading out too. I mean, they are simple L brackets with small gussets...depending on design. they could go from 90 degrees to 91-92 degrees with some abuse and it would offer a noticeable gap on the bed.
  9. Oct 18, 2019 at 6:51 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    you are right, it would take a lot of torture for those brackets...just depends on design. if it happened to be a couple degrees off at the start then it would definitely show issue. I still don't think the bars have anything to do with it...they are literally a connection between the bed rails that will not spread.
    nagorb and InfernoChalupa like this.
  10. Oct 18, 2019 at 6:56 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I'll try to remember to take a look at mine tonight again. it was spreading with camper shell before bed stiffeners. stiffeners pulled it in to "perfect" and always stayed that way with rtt/shell/bedrack/etc but I haven't done a sanity check in a while.
  11. Oct 18, 2019 at 7:12 AM
    BamaTaco56
    Trey
    got the stiffeners before I ever wheeled with the tent. My RTT weighs Around 180 lbs loaded that has been the only thing on there for a while. My bikes add another 50ish lbs
  12. Oct 18, 2019 at 7:15 AM
    BamaTaco56
    Trey
    what does the bumper have to do with it?
  13. Oct 18, 2019 at 7:27 AM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    My guess is the type of person that puts on a rear bumper is more likely to do harder trails causing more flex.
  14. Oct 18, 2019 at 7:28 AM
    BamaTaco56
    Trey
    Correct, it’s just thin sheet metal. The plate bumper probably reinforces the rear end of the truck if nothing else.
    But if someone has a HC rear, chances are they are wheeling their truck more than the average trail rider. Catch 22
  15. Oct 18, 2019 at 7:30 AM
    BamaTaco56
    Trey
    Or build the truck strong enough that it’s not an issue.
    tweakit88 and InfernoChalupa like this.
  16. Oct 18, 2019 at 7:38 AM
    BamaTaco56
    Trey
    I’m probably 5-6 years from a fully boxed frame and a tube flatbed. That won’t spread...
    JKU3000, tweakit88 and InfernoChalupa like this.
  17. Oct 18, 2019 at 7:42 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    does that mean you'll be buying another tacoma for daily driving
  18. Oct 18, 2019 at 7:44 AM
    BamaTaco56
    Trey
    I’ll make the Tacoma a weekend toy and get a car. That or I’ll buy a Toyota pickup
    a flatbed wouldn’t prevent me from daily driving the truck though
    Brian422 and InfernoChalupa like this.
  19. Oct 18, 2019 at 7:44 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Sorry for your loss. You're in our thoughts and prayers.
    BlackBeauty04[QUOTED] likes this.
  20. Oct 18, 2019 at 7:45 AM
    BamaTaco56
    Trey
    I get 18-20 in mine on the interstate
    JKU3000 likes this.
