Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Oct 23, 2019 at 12:03 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Did you get aftermarket upper control arms?
    Jerneyman likes this.
  2. Oct 23, 2019 at 12:15 PM
    wdooly9018
    wdooly9018 Crusaders for Christ
    William
    Enterprise, Al
    2015 Tacoma TRD Sport
    Window tint
    I did not, that is an upgrade that I will be adding later on.
  3. Oct 23, 2019 at 12:17 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Well, I have no brand. So I guess saying “I know a dude that welds”, then telling them to find me on TW works. If I ever decide to do the branding thing, I’ll get @whitedlite to cut me some weldable tags I’ll put on stuff.
    InfernoChalupa likes this.
  4. Oct 23, 2019 at 12:21 PM
    Jerneyman
    Wes
    Huntsville, AL
    And that’s good enough for now. I don’t have the time for anymore work that further marketing would provide. Especially if I want to enjoy a free weekend, which is rare.
  5. Oct 23, 2019 at 12:22 PM
    BamaTaco56
    Trey
    you may or may not be able to get enough castor out of your current UCAs with a full 3” lift to have a proper alignment done. You will also be maxing our your ball joints at full droop.
  6. Oct 23, 2019 at 12:23 PM
    wdooly9018
    William
    Enterprise, Al
    Window tint
    For now it will have to do until I can get new UCAs. I would like to go full tilt on the lift but I have to start somewhere.
  7. Oct 23, 2019 at 12:29 PM
    BamaTaco56
    Trey
    It’ll probably be able to get close. The only issue you will really run into is increased wear on the outside edge of your tires.
  8. Oct 23, 2019 at 12:30 PM
    wdooly9018
    William
    Enterprise, Al
    Window tint
    Yeah I'm hoping it wont be to bad until I can upgrade.
    JKU3000 likes this.
  9. Oct 23, 2019 at 2:19 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I can give you a hand. What's you setup?
    If you want to make a small donation, don't want to say in the interwebs but will over pm, we can cut you out something.
    If you have any questions let me know. Vcarve is cheap and does a good job setting up vector files and doesn't need a hefty computer. I usually use fusion 360 and send it to vcarve for dxf files then to sheetcam.
    cubie likes this.
  10. Oct 23, 2019 at 3:18 PM
    BlackBeauty04
    BlackBeauty04 Well-Known Member
    Justin
    Lynchburg, VA.
    2004 SR5 / 2018 TRD PRO
    Where at?
  11. Oct 23, 2019 at 3:53 PM
    BamaTaco56
    Trey
  12. Oct 23, 2019 at 5:03 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    stronghammer and JKU3000 like this.
  13. Oct 23, 2019 at 5:44 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I don't pay too much attention to these kind of post, it appears they have been overloading the springs to the point of bending springs and the shackles. He stated Medium Dakars are rated for 350lbs daily but they are rated 0 to GVW daily use and the Heavy duty support a constant load of 660 lbs.
    https://www.headstrongoffroad.com/store/p123/Old_Man_Emu_Dakar_Leaf_Packs_(PAIR)_-_ONLY_LEAF_PACKS_for_2005__Toyota_Tacoma.html
    He is using the yellow bushings and Wheelers has talked bad about them for a long time and tell people to replace them
    JKU3000 and stronghammer like this.
  14. Oct 23, 2019 at 5:51 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Dude showed up half an hour late and said he'd take $50 for them. :thumbsup: Thanks again @InfernoChalupa! Also, they look better in pics. They are in much better shape than my ones on my 2nd gen. For $50, it was totally worth the drive to ATL!
  15. Oct 23, 2019 at 5:52 PM
    BamaTaco56
    Trey
    my AAL bent the stock leaf pack on my first wheeling trip
  16. Oct 23, 2019 at 5:53 PM
    BamaTaco56
    Trey
    nice! You should sell me one!
    JKU3000 likes this.
  17. Oct 23, 2019 at 5:54 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I'm gonna sell the original ones off my 2nd gen for cheap! Maybe we can do some horse trading for some weld work or something!
    JKU3000 likes this.
  18. Oct 23, 2019 at 5:55 PM
    BamaTaco56
    Trey
    I am still on an OEM leaf pack with a single AAL
    cubie likes this.
  19. Oct 23, 2019 at 5:56 PM
    BamaTaco56
    Trey
    same wheels you just bought?
    JKU3000 and cubie[QUOTED] like this.
  20. Oct 23, 2019 at 5:57 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Yep, I bought the same rims that are on my truck now, just in much better condition. They have some rock rash on them, I'm just gonna put these newer ones on and sell the older ones.
