Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 16, 2013 at 4:52 AM
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    I see! lol What do u sell? I'm always buying stuff!
  2. Aug 16, 2013 at 5:59 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    apparently adult themed "toys" and "implements"
  3. Aug 16, 2013 at 6:53 AM
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    And other "novelties" :rofl:
  4. Aug 16, 2013 at 7:58 AM
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    Bill's bumper to butt toys sold here!
    HaHa oh sorry. Anywho....tropical storm here in Pensacola, FL. we are locked down until further notice.
    Also i found a nice '09 Tacoma sport 4x4 4dr in Indiana for 20K with 64k miles.
  5. Aug 16, 2013 at 7:59 AM
    TacoFMS
    Justin
    Louisa County, VA
    what part of IN?
  6. Aug 16, 2013 at 8:06 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check the link in my sig. I sell 2nd gen hub bearing assemblies, ready to bolt on. Also I have a full shop where I can repair anything you have on your vehicle. I even do custom 4X4 work, lockers, compressor installs, etc.
    Gives new thought to the company "Snap-On tools" doesn't it? Haha
  7. Aug 16, 2013 at 8:16 AM
    TacoFMS
    Justin
    Louisa County, VA
    well I am sure everyone here has heard of cornwell tools before...... bill sells cornhole's line up.
  8. Aug 16, 2013 at 8:31 AM
    GATORTACO92
    Alex
    Hoover, Al
    clinton, indiana. it has 5 or 6 bids now. i found it on ebay. there is also another one i am looking at, Scott Crump toyota. its and 08 i believe.
    giggity
  9. Aug 16, 2013 at 8:44 AM
    GATORTACO92
    Alex
    Hoover, Al
  10. Aug 17, 2013 at 9:10 AM
    mac424205
    Mathew
    Chelsea
    anything can be talked down. it's just a matter of knowing how to do it. keep in mind, mods don't add value and he is leaving the S/C and lift on if he parts it out.
  11. Aug 17, 2013 at 1:18 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Hello everyone! I've been on the forums for a little while now but never really posted much in here.
    To the point I recently got enough time to start working on my truck again which is still having an overheating issue. This is the link to my original post.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/267372-engine-running-hot.html
    Ok so since then I have ran with no thermostat for almost 2 months now on long trips the truck gets up to 130-150 Degrees which is fairly cold. Short trips it barely makes it to 110. With the thermostat out if you grab the bottom hose you can feel what i think are small air bubbles going through the hose occasionally.
    I just put the thermostat back in yesterday and time after time the temp gauge continues to climb fast until i shut the truck off. I usually shut the truck off at 210. It has a OEM 180 thermostat that I tested not an hour before putting it in.
    If you guys have any ideas that would be GREAT! Thanks!
  12. Aug 17, 2013 at 1:21 PM
    medic2230
    Murph
    Bama! Roll Tide
    Do you have a clog in the cooling system somewhere? Water pump issue?
  13. Aug 17, 2013 at 1:28 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Unless the clog is in the block no I have replaced everything new water pump, radiator, upper lower hose, radiator cap, clutch fan, and of course the thermostat. The only hose that I haven't replaced is the small one at the bottom that goes towards the rear of the engine.
    These are fairly current pictures of the truck. Just a little history the previous owner did not take care of it very good but I got it fairly cheap so overall I'm still doing good.
  14. Aug 17, 2013 at 1:32 PM
    BamaToy1997
    Bill
    Navarre, FL
    My concern would be the air bubbles that you state you feel in the bottom hose. That COULD be an indication of a small head gasket issue. Not having a thermostat would help keep the temp down.
    I checked the linked thread. I remember now posting in it before.
  15. Aug 17, 2013 at 1:47 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    That's what I was thinking but I have done the leak down test where you check for gases in the antifreeze. I've done that test at least 5 times it always comes back good. If it were a small head leak would it not show up?
    Could that small hose by the lower hose be an issue and possible be causing a small leak?
  16. Aug 17, 2013 at 6:23 PM
    GATORTACO92
    Alex
    Hoover, Al
    so does anyone wanna come down labor day and go riding somewhere down here???? i need to have a day of my old normal life back...you know riding and laughing.
  17. Aug 17, 2013 at 8:59 PM
    tunernewb92
    tunernewb92 Well-Known Member
    Brian
    Houston, TX
    2010 DCSB MGM OR
    Bills 5100 Front and Rear OME 885 Front Sway Delete 33" MTZ TRD FJ Wheels (Plasti - Black) Pioneer 10" Sub Kicker DS series component and speakers Alpine 5 way Amp Pioneer Double Din ImMrYo Mirror Bracket Escort 8100 Radar hung from mirror Waiting at house for install: TRD skid plate Retrofit Waiting on: BruteForce sliders BruteForce front bumper 2x3 6 led spot lights
    Bought a 2010 DCSB MGM TRD OR today. 53k miles. Guys at Serra Toyota were very nice. Would buy from them again.
    Wish I could mod it in time for the offroading meet but I won't get any parts in on time.
  18. Aug 18, 2013 at 4:02 AM
    TacoFMS
    Justin
    Louisa County, VA
    another MGM!! yay
    congrats by the way. serra is pretty good on sales..... but just wait til its time to take it to them on service. they will make up for being good on sales.
  19. Aug 18, 2013 at 7:11 AM
    GATORTACO92
    Alex
    Hoover, Al
    hey his name is also Brian, Brian 1 Brian 2
  20. Aug 18, 2013 at 7:37 AM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Drive up to the meet, park it and ride with someone. That way you get to meet the group and get to see what a Tacoma can do.
