Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Dec 6, 2019 at 5:54 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    The set after next will be 35” or 37”. If I’m going to cut the firewall, might as well do it once and be done
    JKU3000 and InfernoChalupa like this.
  2. Dec 6, 2019 at 5:55 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
  3. Dec 6, 2019 at 5:59 AM
    BamaTaco56
    Trey
    JKU3000 likes this.
  4. Dec 6, 2019 at 6:03 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Nah, only if you want it to be, it's part of a national forest like TNF.
    I been a couple times, it is no more mud than any other ride and usually always a way around it.
    Also Turkey Bay Offroad park is just a few miles away.
    A lot of those guys look for the mud but there is usually several group that don't want to hit the mud.
    JKU3000 likes this.
  5. Dec 6, 2019 at 6:16 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Have fun..
  6. Dec 6, 2019 at 6:17 AM
    BamaTaco56
    Trey
    cutting and reforming the firewall with sheet metal will be slightly easier but equally as frustrating as bashing it with a hammer.
    stronghammer[QUOTED] likes this.
  7. Dec 6, 2019 at 6:20 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Got gears as your plan too?
    InfernoChalupa and Jerneyman like this.
  8. Dec 6, 2019 at 6:20 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I'm still on the fence about my next tire size. Larger tires also mean beefier steering rack at some point and potentially replace CVs with something stronger such as the RCV axles. I'd like 37s but I'm not sure I'll like them that much once I get them. Lol.
  9. Dec 6, 2019 at 6:25 AM
    BamaTaco56
    Trey
    nah. I was going to run 37s on 3.73...
  10. Dec 6, 2019 at 6:29 AM
    BamaTaco56
    Trey
    true. 37s depend on the availability of the marrack for stock setups. 35s would be about the comfort limit for beefed stock components.
    I want to sleeve my tie rods, just haven’t seen anyone do it.
    cubie likes this.
  11. Dec 6, 2019 at 6:31 AM
    Jerneyman
    Wes
    Huntsville, AL
    Just looked at prices on 37s and they are almost a solid $100 more per tire. I think 35s will do just fine especially if I get a true 35 and not a 315.
    stronghammer and cubie like this.
  12. Dec 6, 2019 at 6:32 AM
    BamaTaco56
    Trey
    35s are the new 33s
    Jerneyman[QUOTED] likes this.
  13. Dec 6, 2019 at 6:33 AM
    Jerneyman
    Wes
    Huntsville, AL
    And 40s are the new 35s. Who's doing that first?
  14. Dec 6, 2019 at 6:35 AM
    BamaTaco56
    Trey
    big mike
  15. Dec 6, 2019 at 6:35 AM
    Jerneyman
    Wes
    Huntsville, AL
    He doesn't count. Lol. I meant a normal person.
    stronghammer likes this.
  16. Dec 6, 2019 at 6:42 AM
    BamaTaco56
    Trey
    he has to have the only IFS truck in stock-ish configuration (not back halfed) on 40s that is capable of doing life
  17. Dec 6, 2019 at 6:42 AM
    JBTacoma
    Jeff
    Cullman Alabama
    They really stuck those tie rods in a bad place, not protected very well
  18. Dec 6, 2019 at 6:48 AM
    BamaTaco56
    Trey
    nope. There are sleeves all over the place for half ton trucks. Have yet to see any for our mini trucks.
  19. Dec 6, 2019 at 6:50 AM
    JBTacoma
    Jeff
    Cullman Alabama
    May have found you a side business
  20. Dec 6, 2019 at 6:59 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Again, I run Wheeler's. The progress bump is much nicer than the solid.
    InfernoChalupa and Cred92 like this.
