Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Feb 17, 2020 at 4:07 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    No worries. If I drop bumper and do the rewire I’ll do it at work. Just set the bumper on forklift and add a strap and some leveling blocks. Only hard part of the job was removing and reinstalling the bumper with the high clearance wings on it. If it weren’t angled on the wings it would be very simple.
    One other hard part was when I got it up there on one side on the bolts I started jacking it up to line the other side up. That’s when I smashed the solenoid on one of the braces inside the truck so had to drop it again and remount the solenoid to the side. That was very frustrating as I was lifting this massively heavy bumper and winch combo by myself to the floor jack and then having to wheel it where I needed it and keep it balanced. Then jack blew a seal and lost all hydraulic fluid. So had to drop it down again. Definitely using forklift next time as my back felt the extra lifting of that heavy sucker.
    cubie[QUOTED] likes this.
  2. Feb 17, 2020 at 4:08 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
  3. Feb 17, 2020 at 4:09 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Rob! You back stateside yet?
    rmepilot[QUOTED] likes this.
  4. Feb 17, 2020 at 4:11 PM
    rmepilot
    Rob
    Huntsville, AL
    Yes in Auburn, of all third world sh!tholes...
    :crapstorm:
    JKU3000, baldridge and cubie[QUOTED] like this.
  5. Feb 17, 2020 at 4:11 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Although it might be a bit far out lets plan for 2021. Brian said he is going in July/August and including Yellowstone. I have a Wyoming hunting trip in September so can't go with Brian as that will be my annual trip out west.
  6. Feb 17, 2020 at 4:14 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Hooah! War Eagle!
  7. Feb 17, 2020 at 4:16 PM
    rmepilot
    Rob
    Huntsville, AL
    If the Athletic Dept gets widespread Coronavirus cases, I swear I’m not patient zero.
    :thumbsup:
    JKU3000 and cubie[QUOTED] like this.
  8. Feb 17, 2020 at 4:17 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    You'd be sitting in quarantine somewhere right about now...:D
  9. Feb 17, 2020 at 4:17 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Just talked to a guy about doing his. Told him some beer and a pizza and id throw it in for him. Ill offer you the same.
    cubie likes this.
  10. Feb 17, 2020 at 4:18 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    We have done a number of the bushings swap at Mod days over at Tacoalamode's. How bad is the vibration and how long ago did it start???
    Davtopgun[OP] and cubie like this.
  11. Feb 17, 2020 at 4:21 PM
    rmepilot
    Rob
    Huntsville, AL
    My health screening upon re-entry to the US was “were you in China?”. So no quarantine for me.
  12. Feb 17, 2020 at 4:21 PM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    It’s not bad but it’s driving me nuts. It started right after my lift in October. Just to be double sure I’ll see what happens when I rotate my Wildpeaks this week.... this will be the first rotation at 5k
    cubie likes this.
  13. Feb 17, 2020 at 5:15 PM
    rmepilot
    Rob
    Huntsville, AL
    Are you sure it’s needle bearing and not D/S angles?
  14. Feb 17, 2020 at 7:46 PM
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    It does sound a lot like the driveshaft angle because it was directly after your lift.
    This is where most of us did ours.
    cubie and rmepilot like this.
  15. Feb 18, 2020 at 2:28 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Tuesday.. make it a good one fellas!
  16. Feb 18, 2020 at 2:29 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Mornin fellas
    JEtaco03, cubie and Cred92 like this.
  17. Feb 18, 2020 at 3:34 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Right after the lift is when most get the needle bearing vibes too.
    Davtopgun[QUOTED][OP] likes this.
  18. Feb 18, 2020 at 3:46 AM
    mac84
    Alabama
    Yeah, I’ve tried to read as much as I could on this.... does go away in 4wd.
    I’ve checked the angles on the driveline but admittedly a bit crude.
    cubie and stronghammer[QUOTED] like this.
  19. Feb 18, 2020 at 3:48 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Don’t be hating!!! :anonymous:
    rmepilot[QUOTED] and cubie like this.
  20. Feb 18, 2020 at 3:53 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I’d bet that’s it. A lot of us have done it but a lot of us have not done anything to our driveshaft so...lol
