Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Feb 25, 2020 at 9:53 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    cubie and InfernoChalupa like this.
  2. Feb 25, 2020 at 9:55 AM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    I would say no also. Let me know if you have any issues getting the bushings out to put the new ones in. I have a press that should work if you do.
  3. Feb 25, 2020 at 9:56 AM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    I'm going to have some Icon billet UCAs for sale after this weekend. Will want to check out the heim joints in them after they are off first.
  4. Feb 25, 2020 at 9:56 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    I didnt do mine. If your looking for max rear flex i would. The stock one hinder mine, ill be switching them out soon.
  5. Feb 25, 2020 at 9:57 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Your More than welcome to do it at the farm if you want to! Its about 15 min from springville!
    Im sure @cubie wants to add that 1/4th inch plate on his.
  6. Feb 25, 2020 at 10:09 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    The truck handled the washboard roads awesomely! Took it off on some mild trails and it soaked up the uneven terrain like nobody's business! Not only does it look great, but it truly rides even better! I can tell you that we are going to enjoy the GA Traverse in this truck.
  7. Feb 25, 2020 at 10:12 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Glad you like it
    cubie[QUOTED] likes this.
  8. Feb 25, 2020 at 10:13 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    So Brian's mod day has been pushed back to when you are coming up there? Hopefully I'll have my Victory rack by then!
  9. Feb 25, 2020 at 10:15 AM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Now you both will know why they refer to mall crawlers and the speed bumps!
  10. Feb 25, 2020 at 10:16 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    That's with about 300lbs in the back too. I almost went with the medium duty springs, but totally glad I opted for the heavy duty ones!
    InfernoChalupa likes this.
  11. Feb 25, 2020 at 11:09 AM
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    You need one of them awesome @TacoAlaMode grills on that rig, sir.
    JKU3000, cubie and tweakit88 like this.
  12. Feb 25, 2020 at 11:17 AM
    tweakit88
    Leroy IL
    Only the best.
    Agreed
    cubie and Davtopgun[QUOTED][OP] like this.
  13. Feb 25, 2020 at 11:17 AM
    tweakit88
    Leroy IL
    Only the best.
    Thinking about checking this out. Anybody down?
  14. Feb 25, 2020 at 11:22 AM
    Davtopgun
    David
    Central Alabama
    Busy this weekend, sadly
    cubie and tweakit88[QUOTED] like this.
  15. Feb 25, 2020 at 11:34 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
  16. Feb 25, 2020 at 11:40 AM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Was expecting it to be very sluggish but it’s not. Fuel mileage on the digital display dropped from 19.6 to 18.7 but I just filled up before the lift and driving back and forth to work it’s rolling hill after hill and even downshifted each hill before lift and tires. Not once did it drop to 4th on way to work though.
    JEtaco03 and cubie[QUOTED] like this.
  17. Feb 25, 2020 at 11:41 AM
    newdles
    Achmed
    It’s not as much as the pic makes it look like.
    cubie likes this.
  18. Feb 25, 2020 at 11:42 AM
    newdles
    Achmed
    Procrastinator. Can do it in an afternoon after work! If not, two afternoons. :)
    cubie likes this.
  19. Feb 25, 2020 at 1:03 PM
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Hello bama forum, vouching for my buddy Jordan here. I think the most evil thing I've seen him do was draw a penis in dirt on a TRD OR in PA.
    Also curious, do the folks from southern expeditions still post up here?
  20. Feb 25, 2020 at 1:35 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    @newdles Did you have any problems mounting your e-brake hoop to the spring pack? My cable was too tight to mount in the hole that Dobinson's provides, so I had to improvise, but I checked at full droop and compression and it's going to work out just fine.
    Removed the bolt from the leaf pack bracket.
    Drilled out the hole for the hoop and re installed on the leaf pack bracket.
    Driver's side
    Passenger side
    POOLGUY likes this.
