Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Feb 26, 2020 at 4:23 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Time to change your avatar pic as well.
  2. Feb 26, 2020 at 5:10 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Evenin fellas
    baldridge and cubie like this.
  3. Feb 26, 2020 at 5:17 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Sup Phil!
  4. Feb 26, 2020 at 5:17 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    With topper off yes. With on no
    InfernoChalupa likes this.
  5. Feb 26, 2020 at 5:18 PM
    tweakit88
    Leroy IL
    Only the best.
    Ill join and contribute. Yall make badass stuff.
    Crikeymike[QUOTED] and cubie like this.
  6. Feb 26, 2020 at 5:19 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    x2!
    Crikeymike and tweakit88[QUOTED] like this.
  7. Feb 26, 2020 at 5:21 PM
    tweakit88
    Leroy IL
    Only the best.
    Very well put.
    Crikeymike and InfernoChalupa like this.
  8. Feb 26, 2020 at 5:23 PM
    tweakit88
    Leroy IL
    Only the best.
    Damn Mark. Your so wise tonight.
  9. Feb 26, 2020 at 5:24 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I use mine all the time.
  10. Feb 26, 2020 at 5:26 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Jonny
    Same ole same ole
    Sup Matt
    and x3 on your post :D
  11. Feb 26, 2020 at 5:30 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Brandon
    Sup Mark
    cubie and InfernoChalupa like this.
  12. Feb 26, 2020 at 5:34 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    They will. The frame is still at the welder's. I'll also need to replace one of the bushings as it was missing one. I'm thinking I might as well replace all 6 of them since it's apart anyway.
    @baldridge hooked me up with some stock leafs that are in great shape
    baldridge, cubie and InfernoChalupa like this.
  13. Feb 26, 2020 at 5:44 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I just think for the $50 it'll just be best to do it before I put it all together. Knowing my luck I'd have to do it right after I got it on the road :rofl: I'll put the cheapest I can on the trailer cause it's not a huge issue.
  14. Feb 26, 2020 at 5:44 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Another question about TPMS. If you air down and the light comes on, when you air up should it go back out?
    cubie likes this.
  15. Feb 26, 2020 at 5:45 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Had mine all replaced at discount tire when I got my new tires this week. 7 year guarantee. In case anyone didn't know there is a Discount Tire dealership in Madison.
    JEtaco03 and cubie[QUOTED] like this.
  16. Feb 26, 2020 at 5:46 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Mine did on a 2013. I only went down to 25lb, so that may change things....not real sure on that. I plan to unplug the box that's in the headliner once I put sound deadener up there.
    cubie likes this.
  17. Feb 26, 2020 at 5:50 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    There should be a button under your dash that you press and hold for 3 seconds once you have all your tires set to the pressure you want. When it gets below that, the light comes on. When you air it back up, the light goes off. At least on my second gen it does. The key has to be turned on.
    JEtaco03 likes this.
  18. Feb 26, 2020 at 5:54 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I'm referring to if you decide to run 30 PSI instead of your normal 35 PSI. You can hold the button for 3 seconds until the light blinks 3 times, this is where it will set to your new 30 psi that you want to run. This is on 2nd gen, I assume it's the same on the 3rd gen.
  19. Feb 26, 2020 at 6:01 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Yep! What I can't stand is, I run 33 in the front and 30 in the rear. When I take the truck in for rotate and balance, I have to let the air out of my rear tires and air up my front tires!
  20. Feb 26, 2020 at 6:15 PM
    newdles
    Achmed
    You already sound deadening rest of truck including doors and floor and back seat wall?
