Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Mar 1, 2020 at 12:16 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    You need to get the complete build diffs. Call them, they are great about helping you with what you need. Their customer service is great
    cubie likes this.
  2. Mar 1, 2020 at 12:17 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Off topic but do you know how to do transmission work?
    cubie likes this.
  3. Mar 1, 2020 at 12:20 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I’m getting the fully built clams but don’t know to select solid spacer or the crush sleeve. I know what a crush sleeve is but never heard of the solid spacer. Also don’t know if I need a cv bushing or not.
  4. Mar 1, 2020 at 12:20 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Yes Sir but I dont even like doing mine. Lol
    Brian422[QUOTED] likes this.
  5. Mar 1, 2020 at 12:20 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    @gixxerphil took that. I bet he has one of each of ours.
  6. Mar 1, 2020 at 12:21 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Call ECGS the can explain it all to you, they are great
    cubie likes this.
  7. Mar 1, 2020 at 12:22 PM
    newdles
    Achmed
    That’s the plan tomorrow at work when they’re open. I’d call now but don’t wanna listen to their automated voice mail :)
    cubie likes this.
  8. Mar 1, 2020 at 12:24 PM
    JBTacoma
    Jeff
    Cullman Alabama
    I have never disassembled a 3rd gen diff, if it was a 1st gen I could answer you
    cubie likes this.
  9. Mar 1, 2020 at 12:27 PM
    newdles
    Achmed
    There’s YouTube videos on it but also requires specialty tools I don’t see the need to purchase for a one time thing.
    cubie likes this.
  10. Mar 1, 2020 at 12:35 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Best thing to do is call ECGS they can tell you everything you need. Swapping them out is easy
    cubie likes this.
  11. Mar 1, 2020 at 3:44 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Lol ok, trying to figure out my 4x4 transmission.
    JKU3000 likes this.
  12. Mar 1, 2020 at 3:56 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    You going manual?
  13. Mar 1, 2020 at 4:05 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I shipped my front diff to them and had it back in about a week.
    Basically once the solid spacer is set with the correct shims it can't change. With a crush sleeve if your seal leaks there's a good chance changing it can over crush the spacer. All it does is set the amount of pre load on the pinion bearings. Some people suggest one on the rear in the event something slams the pinion flange. But like jb said ecgs is great at explaining everything.
    I re geared my rear, I already had all the tools required and could make whatever I didn't. It took over a week setting everything up 100 times and then waiting on proper shims etc to be shipped and then setting everything again. I really only did it for the learning experience, next time I'll probably pay someone.
    cubie likes this.
  14. Mar 1, 2020 at 4:41 PM
    JBTacoma
    Jeff
    Cullman Alabama
    What do you need to know?
  15. Mar 1, 2020 at 5:15 PM
    newdles
    Achmed
    Yeah definitely not taking my truck apart and letting it sit on jack stands for over a week in the garage. Core return fee is not an issue to pay up front and start tear down the day before parts are scheduled to be delivered. May start taking it apart two days prior to because it may be a bit more difficult if I’m by myself in the garage again but anything’s doable.
    As for building my own diffs, maybe one day for learning experience but definitely not this round.
  16. Mar 1, 2020 at 5:33 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Noooo lol
  17. Mar 1, 2020 at 5:43 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I’m trying to convert my tans to the 4x4 version. Basically just need someone who is knowledgeable and would be able to swap out all the parts. From what I’ve read it’s all bolt up.
    cubie likes this.
  18. Mar 1, 2020 at 5:47 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Phillip just posted up a bunch of pics in your GaT thread! I hate that we missed the snow!
  19. Mar 1, 2020 at 5:57 PM
    tweakit88
    Leroy IL
    Only the best.
    As long as the output shaft is the same lenght for 2wd and 4wd trans all you should have to do is take the tail housing off and bolt on the tcase. But most likly thats not gunna be the case.
    JBTacoma, Brian422[QUOTED] and cubie like this.
  20. Mar 1, 2020 at 6:10 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    They are not the same! I’ve already confirmed this
