Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Mar 8, 2020 at 10:06 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Yes it could, do a continuity test on the ground inside the control box.
  2. Mar 8, 2020 at 10:08 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Are you getting power after the small fuse where the wire connects to the solenoid?
  3. Mar 8, 2020 at 10:10 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
  4. Mar 8, 2020 at 10:10 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I’m going to try to manually spool winch with jumper cables
  5. Mar 8, 2020 at 10:17 AM
    JBTacoma
    Jeff
    Cullman Alabama
    I was referring to the ground wire that connects to the bottom of your winch, the one coming from the battery. A small ground wire also connects to the bottom of the winch motor that runs up to the control box, make sure they are not loose or corroded
    Also check the wires that connect to the winch motor from the control box
    Brian422[QUOTED] likes this.
  6. Mar 8, 2020 at 10:18 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Quick question- currently medium dekar leaf pack with 1 inch block in the back (I know I should have ordered heavy duty from the beginning). Ordered add a leaf to make heavy duty, so will this keep my truck level/slight rake. Should I order another leaf to compensate for the block?
  7. Mar 8, 2020 at 10:34 AM
    baldridge
    Bart
    Auburn, AL
    Just to make it a heavy duty/ want to get rid off the block but I don’t want to do it all just to realize I’m still sitting low in the back.
    cubie likes this.
  8. Mar 8, 2020 at 11:28 AM
    baldridge
    Bart
    Auburn, AL
    Just camping gear. Sometimes 4 bikes. Might even purchase some jet skies for the summer. Guess I’ll set it up and see. If I end up needing another AAL then I’ll order and slap on.
    JKU3000 likes this.
  9. Mar 8, 2020 at 11:40 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    The AAL will add thickness to the leaf pack and stop some sagging. You will likely sit higher with just the one AAL and no block.
    JKU3000 and baldridge[QUOTED] like this.
  10. Mar 8, 2020 at 11:59 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I’m going to check when I get home. I got tired of messing with it for the moment
  11. Mar 8, 2020 at 1:45 PM
    Jb0623
    Jb0623 New Member
    17 limited quicksand
    Anybody know anyone around Montgomery that performs a cmc?
  12. Mar 8, 2020 at 2:18 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Not sure man. That’s a good bit south of me. Any fab shop can do it though with a grinder and a welder. You can purchase the plate online or just have them cut you in to fit.
  13. Mar 8, 2020 at 3:39 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    For everyone thats been asking about the tune. I put the 1.05 93 octane performance tune on today and just the little bit ive drove i cant stop smiling. Turned my truck into a beast. So happy with it, i cant wait till the 2.0 5.29 gear tune drops. I just cant imagine it getting any better tho. So happy with it. Thanks @newdles for letting me borrow the cable.
    JKU3000, JBTacoma, JEtaco03 and 3 others like this.
  14. Mar 8, 2020 at 4:36 PM
    newdles
    Achmed
    Told ya it’s good! Glad it worked d out for ya!
    JEtaco03 and cubie like this.
  15. Mar 8, 2020 at 4:44 PM
    newdles
    Achmed
    Just be aware the initial feeling you got when first installing then driving wears off of course. But if you ever want that feeling to come back flash back to stock for a few days then flash the tune to 1.05 or 2.0. It’s quite an upgrade that’s for sure.
    Keep in mind it’ll feel much different in 4lo too. The aggressive throttle at the start is quite massive in 4lo til you get used to it. But your truck has so much weight it might just offset it enough that it feels great all around as is.
  16. Mar 8, 2020 at 5:08 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    So took @tweakit88 advise and drilled some holes to mount the rci bed rack awning mounts. Love the location but mounts are a good bit wobbly. Not to the point that the 3/16 steel would break but I don’t like how it wobbles. Maybe some gussets from @BamaTaco56 are in order.
    JEtaco03, tweakit88 and cubie like this.
  17. Mar 8, 2020 at 5:20 PM
    tweakit88
    Leroy IL
    Only the best.
    Looks good buddy
    cubie and Brian422[QUOTED] like this.
  18. Mar 8, 2020 at 5:42 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Evenin fellas
    Got a good night of camping and some trails in TN this weekend:D
  19. Mar 8, 2020 at 5:45 PM
    tweakit88
    Leroy IL
    Only the best.
    Nice, looks like a good time
  20. Mar 8, 2020 at 5:47 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Was a great time.
    JBTacoma likes this.
