Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Mar 10, 2020 at 6:26 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    :rofl:
    stronghammer[QUOTED] and cubie like this.
  2. Mar 10, 2020 at 6:27 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I've been checking my u-bolt nuts every so often since my suspension install. They say to check em after every first couple of hundred miles. I've checked, but they're all still tight.
  3. Mar 10, 2020 at 6:35 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Haven’t even glanced at mine since install. They’re still connected I’m sure.
    cubie[QUOTED] likes this.
  4. Mar 10, 2020 at 6:37 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Well, I'm sure there's a reason they say to check after a few hundred miles. I did just to be on the safe side, an ounce of prevention is worth a pound of cure!
  5. Mar 10, 2020 at 6:42 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    it’s the angle of the photo. I took the picture from in front of the wheel without looking at it.
    my u bolts were torqued at install and 500 miles after. That is definitely not the issue
  6. Mar 10, 2020 at 6:45 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Be careful not to pull the bolts through the rails, it's not hard to do because that will be the new weak point
    tweakit88[QUOTED] likes this.
  7. Mar 10, 2020 at 6:48 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Yeah, that angle looks like your inner u-bolt could be pushed in towards the spring perch a little bit more. Odd that your leaf kicked out like that, maybe @Crikeymike will chime in soon.
  8. Mar 10, 2020 at 7:01 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Ill lightly tighten them
    cubie likes this.
  9. Mar 10, 2020 at 7:13 PM
    BamaTaco56
    Trey
    they are as straight as they can be!
    @tweakit88 has had the same issue apparently
    JKU3000 and cubie[QUOTED] like this.
  10. Mar 10, 2020 at 7:22 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    He has? I hope my leaf doesn't rotate out like that, first I've seen with the Dobinson's pack.
  11. Mar 10, 2020 at 7:22 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Nudes
  12. Mar 10, 2020 at 7:24 PM
    BamaTaco56
    Trey
    Yea. His have done it twice
  13. Mar 10, 2020 at 7:29 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I've been looking at Archive Garage's Stealth u-bolt flip kit. Looks like they made the flip plate specifically with holes closer together, so the u bolts will fit tight on both sides of the leaf pack, so this kinda thing doesn't happen. May go this route when I get around to purchasing.
    https://archivegarage.com/explore-archive?olsPage=products/stealth-toyota-u-bolt-flip
  14. Mar 10, 2020 at 7:41 PM
    tweakit88
    Leroy IL
    Only the best.
    Shortly after i installed them 2 years ago. Then i forgot about it. Never had a problem with them. They just sit crocked.
    JKU3000 and cubie like this.
  15. Mar 10, 2020 at 7:45 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    You run a u bolt flip kit? I haven't flipped mine yet, but the u bolts that came with my Dob springs sit nice and tight against both sides of the leaf pack, perfect fit actually. Some flip kits I've seen have a gap on each side of the leaf leaf pack, due to the holes being spaced further apart on the flip plate. I imagine if there's a gap, then there's more room for a leaf to rotate out of position.
  16. Mar 10, 2020 at 8:00 PM
    Cred92
    Cred92 PAID4MOD
    Caleb
    Jasper Al
    Indigo Ink Sport DCLB/White RC I4 5MT
    BLACK AND BLUE STUFF
    I’ve got the archive flip kit awesome made product fit and finish, I did wheelers superbumps before they offered the new foam bumps. Did them when I did my dobinson springs, I’m prolly doing hammer hangers next product of his.
  17. Mar 10, 2020 at 8:04 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Good to hear! When you get a chance, can you snap a pic from the the back of the truck, showing how tight the u-bolts sit against the leaf pack? Too big of a gap would bother my OCD. I want em tight! I'll probably run the Durobumps or the Timbren Active Offroad bumps.
  18. Mar 10, 2020 at 9:06 PM
    tweakit88
    Leroy IL
    Only the best.
    No flip for me yet. Been running the u bolts Dobinsons supplied since i put them on. Ill eventually flip it. Probably before our summer trip
    JKU3000 likes this.
  19. Mar 10, 2020 at 9:13 PM
    tweakit88
    Leroy IL
    Only the best.
    Im going to go with these, but with chevy bump stops.
  20. Mar 11, 2020 at 4:35 AM
    BamaTaco56
    Trey
    That leaf is in a retainer at the front of the pack, so it probably can’t shift much more. But I don’t know... we will see what Mike’s thoughts are.
    gonna hammer it back in tonight
    tweakit88 and stronghammer like this.
