Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Apr 13, 2020 at 5:48 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Hmmm nothing looks to be out of the ordinary just looking at it!
  2. Apr 13, 2020 at 5:53 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I know...I mean the ball joints don’t look new but they don’t look like they’re about to fail either.
    JKU3000 likes this.
  3. Apr 13, 2020 at 7:58 PM
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    Wobbling down the road, clunk on reverse makes me think a few things. Tie rod ends, LCA bushings/Cam bolts being tightened one not sheered or stripped or something. Check your rod ends, wiggle it around maybe a wheel bearing? Our front ends are simple so it won’t be too hard regardless
    stronghammer and JKU3000 like this.
  4. Apr 13, 2020 at 8:32 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    4runner id have to feel to better help. But the taco mines been doing the same thing. Ive went through the entire front end and ive found 2 things. 1st did it everytime on the first back up of the day everytime. Found that for some reason my new rotors would rotate slightly against the lug studs when the brakes were cold, solution torque wheels to 115ftlbs. That solved that problem.
    2nd will only do it sometimes but it will do it when ever it feels like it. Feels like its coming from the drivers side but its actually my pass side cv binding up.
    stronghammer[QUOTED] likes this.
  5. Apr 13, 2020 at 8:58 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Really glad everyone is OK. Living in hit or miss tornado land is not an easy thing. Kept waiting for the sirens around 8 or 9 last night but never went off. Outside was ugly but still not like April 2011.
  6. Apr 13, 2020 at 9:19 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    New dual battery install under bed in truck. Anyone interested in a dual battery plate set up for 2nd gens. Well used but still functional. Also have a used Scangauge II for $40. PM me for additional info if interested.
    JKU3000 likes this.
  7. Apr 14, 2020 at 3:28 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Yeah I looked into all that to the extent I knew how yesterday. Wiggled, spun, torqued, and adjusted everything I could think of...
    So the Tacoma it might have actually been that. One lug nut was under torqued, and it was actually cross threaded (thanks firestone) but I got everything torqued down properly. Will see when I head to work in a bit
  8. Apr 14, 2020 at 3:55 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    The last tire shop I used broke one of the studs off my spidertrax, not running them anymore since I bought wheels but still. They didn’t tell me either until I got home and realized I was missing one. Hopefully that fixes your problem!
    curious, did you use a regular floor jack to lift your truck up?
    JKU3000 and stronghammer[QUOTED] like this.
  9. Apr 14, 2020 at 4:14 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Morning Bama, kinda nippy outside this morning!
    JEtaco03, JKU3000, Brian422 and 2 others like this.
  10. Apr 14, 2020 at 4:29 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    How’s the new job?
    cubie[QUOTED] likes this.
  11. Apr 14, 2020 at 4:32 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    dang man how the heck could they not tell you?!
    yeah I used a regular floor jack, one of the pittsburgh ones from harbor freight
    JKU3000 likes this.
  12. Apr 14, 2020 at 4:52 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I had a noise that would only happen occasionally, mostly in the morning when the truck was cold and more often in reverse. I searched for it for a long time, found my noise when I removed my sway bar. It was a loud pop, it sounds different in the video than it did inside the cab.
    https://www.youtube.com/watch?v=3DjNkEQ9jBw
    Crikeymike likes this.
  13. Apr 14, 2020 at 4:55 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I have no sway bar though... I did get the "clunk" to happen again this morning, but it happened later than normal. it usually happens as soon as the truck starts rotating in reverse, but today it took a good 10 feet backing up before it happened, and it wasn't as aggressive as it has been. not sure if I can get the video to post at work.
    Brian422 likes this.
  14. Apr 14, 2020 at 4:59 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    JKU3000 likes this.
  15. Apr 14, 2020 at 5:07 AM
    JBTacoma
    Jeff
    Cullman Alabama
    What is the camera focused on in the video?
    If you watch close what ever the camera is attached to did not move but the object the camera is focused on did jerk when the popping sound happened
  16. Apr 14, 2020 at 5:09 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    that's the front driver side tire.
  17. Apr 14, 2020 at 5:14 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Something is hanging up to cause it to jerk like that on release.
    Make sure the control arms and tie rods are not hanging on anything like skid plates. Could also be a ball joint dry of grease and binding on the inside.
    I may be wrong but in the video at :12 there is a jerk like something is in a bind and releases.
  18. Apr 14, 2020 at 5:16 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    you are correct on the jerk. after you said that I've now watched it multiple times and I distinctly see it too. the camera is just in my hand pointed towards the front tire since that's where I heard/felt the clunk.
    from looking yesterday control arms and tie rods are not hung up on anything and the lower ball joint looked good. Could it be CV?
    this is literally the ONLY time it happens. first take off, in reverse, in the morning. cannot get it to happen at any other time.
  19. Apr 14, 2020 at 5:17 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    The new job is pretty kick ass. Already given Crane and Forklift certifications to a few employees here. Way different culture from my previous employer, for the better in almost every way.
    POOLGUY[QUOTED] and JEtaco03 like this.
  20. Apr 14, 2020 at 5:17 AM
    JBTacoma
    Jeff
    Cullman Alabama
    I see the tire now I turned the video 90 degrees. It looks like you ran off the edge of the concrete and the tire moved up that was the jerk I was seeing
