Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. May 6, 2020 at 5:51 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Yeah in theory yes, but it wouldnt be that noticable. I honestly would go 4.56 that would make the biggest diffrece in a 6cyl without adding too much rpm on hwy.
    JKU3000 likes this.
  2. May 6, 2020 at 5:52 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    take it from me lol. I regeared twice because i undergeared the first time :hattip:
    JKU3000 and cubie like this.
  3. May 6, 2020 at 5:53 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    I suppose I'll just cross that bridge when I get there :D If I have to regear, I'm throwing a locker in just cause :rofl:
    JKU3000 and Brian422[QUOTED] like this.
  4. May 6, 2020 at 5:55 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    No better time to do it? Front locker? Or rear? Yours didn’t come with rear locker?
  5. May 6, 2020 at 5:56 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Rear. No, I just have the SR5.
    JKU3000, cubie and Brian422[QUOTED] like this.
  6. May 6, 2020 at 5:59 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Jonny
    JKU3000 likes this.
  7. May 6, 2020 at 6:00 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yup i def through a locker in that thing. I had an easiertime on some obsticles at the slab 2wd locked than @Peligro did 4wd not locked.
  8. May 6, 2020 at 6:04 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I don't really think a locker is a "must have" for me, but if I do regear…..might as well.
    I don't consider myself a "rock crawler", just a camper that likes trails :D......or "overlander" :rofl: :rofl: :rofl:
    JEtaco03 likes this.
  9. May 6, 2020 at 6:06 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Sup Phillip, just relaxin' after a great dinner.
    You have a 4-cylinder? if you move up to 255/75, it'll only be an inch taller. When mounted on your truck, would lift your truck an extra 1/2".
    A rear locker would be one of the greatest mods you can do to your truck. Ask Brian!
    Brian422 likes this.
  10. May 6, 2020 at 6:09 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I have the 6cyl with 3.73 gears. I've been more than happy with how my truck has done. A rear locker will only come if I have to regear. I'm just not sure what tires I will have to go with after the lift. Tire size will determine what happens as far as gears and stuff.
  11. May 6, 2020 at 6:20 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    If you have 4wd you are going to have to redo the front and back to be the same. Even then not sure a 4cyl would drop into current vehicles without a bunch of modification. I read a lot over the years and finally got most of the info through my thick skull about how they operate and pros/cons of the different ratios.
  12. May 6, 2020 at 6:23 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    2wd prerunners 4cyl are the same as 6cyl models. I replaced mine with a complete diff from a 6cyl trd sport. but yes he will have to regear the front as well if he plans on using 4wd
  13. May 6, 2020 at 6:25 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I do know that both F/R will have to be done at the same time :D. I was just thinking that if the 4cyl came with 4.30, that might be a cheap way to regear. With it being 4.10. I assume it'd be just like my TJ(3.73) to a Rubicon(4.10). There wasn't too much of a difference in those.
  14. May 6, 2020 at 7:23 PM
    Peligro
    Peligro Well-Known Member
    Don
    Calera, AL
    2012 GMC Sierra SLT - 2 2023 CFMoto CForce 600s - 2024 Segway Villian SX10 S
    Regear hopefully sooner than later and will add rear locker. I doubt I'd do front...probably regret that however.
    On that note you got any local Bham shops to do the full regear instead of sending off?
    Also if I ever buy new lift setup (just not a fan of the 5100s....) I'll buy crawfish and beer for install help!
  15. May 6, 2020 at 7:25 PM
    Peligro
    Don
    Calera, AL
    What a travesty....auto correct crawfish to crayfish! No sir!
    cubie and JKU3000 like this.
  16. May 6, 2020 at 7:26 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I could go for some mudbugs :drool:
    cubie, JKU3000 and Peligro[QUOTED] like this.
  17. May 6, 2020 at 8:04 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    4wp
  18. May 6, 2020 at 8:34 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Order from East Coast Gear Supply, install when you get them and send the old ones back for a core refund.
  19. May 7, 2020 at 4:39 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  20. May 7, 2020 at 4:40 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup EJ
    cubie and yota243[QUOTED] like this.
