Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 10, 2020 at 7:08 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    thanks
  2. Aug 10, 2020 at 7:09 AM
    jmaack
    Justin
    Helena Alabama
    good morning. off to the hospital.
    POOLGUY, stronghammer and cubie like this.
  3. Aug 10, 2020 at 7:10 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Mornin’ Justin, good luck at the hospital!
    jmaack[QUOTED] likes this.
  4. Aug 10, 2020 at 7:14 AM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    True, the band clamps only work when the mating pipe is designed to be used with them. The first rock will drag the exaust clean off the truck. It will get put on, ive actaully been looking for small resinators to put in front of the muffler to help with any rasp. Ill run the resinator on the front section then weld the muffler on in place of the factory one. I have to get some junction pieces as well. Its at the top of the to do list. Want to make it nice enough to last for awhile. Eventually the truck will get a full turbo back exaust fully custom 2.5" into a 3.5" single axle dump. But thats a few years out lol.
    stronghammer[QUOTED] and cubie like this.
  5. Aug 10, 2020 at 7:14 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Anyone have any recommendations on a sturdy and reliable hi lift jack or will I be alright with the Hi Lift brand one?
  6. Aug 10, 2020 at 7:17 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Anything not Hi Lift brand would literally be an off brand of a Hi Lift Jack. Hence “Hi Lift” lol.
    synaps3 likes this.
  7. Aug 10, 2020 at 7:20 AM
    weagle22
    weagle22 Well-Known Member
    Josh
    Birmingham, AL
    2018 Blue SR5 DCSB 4x4 2022 Lexus GX 460
    Bilstein 6112s/5100s Deaver AAL
    Good luck buddy!
  8. Aug 10, 2020 at 7:37 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    only buy the hi-lift brand hi-lift
    it’s a dangerous tool and there is no substitute. You can also get rebuild kits for them, and I’m not sure if they fit on the others.
    Also, that adapter may or not fit other jacks....
    synaps3 and cubie[QUOTED] like this.
  9. Aug 10, 2020 at 7:42 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    do the ones i told you about its super simple and only 4 small screws
    cubie[QUOTED] likes this.
  10. Aug 10, 2020 at 7:43 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Thanks for the info Trey. I know they call them farm jacks too and they’ve been around forever. I’m going to pick up a 48” when I get one.
  11. Aug 10, 2020 at 7:43 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Im going to fab one up as a welding project to learn on lol
    cubie likes this.
  12. Aug 10, 2020 at 7:43 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I’ll hit you up for those parts. Gonna drill some holes in the front of my truck box to mount it.
  13. Aug 10, 2020 at 7:44 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    :confused:
  14. Aug 10, 2020 at 7:45 AM
    BamaTaco56
    Trey
    I think farm jack is the general name for the “hi-lift”.
    So anything that isn’t hi-lift branded is a farm jack.
  15. Aug 10, 2020 at 7:51 AM
    BamaTaco56
    Trey
    It’ll be a good project for early on, but I wouldn’t do that as your first if that’s your plan. And I also wouldn’t do it on a welder less than 140 amps. The welds holding the jack in a vertical position with the weight of the truck on them are not something you want to break. There is a good bit of load bearing weight on those welds.
    Do something that you can stress test without hurting yourself, someone else, or your truck for your first project.
    cubie likes this.
  16. Aug 10, 2020 at 7:53 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Before they came out with the screw jacks, all the older cars had hi lift type jacks in them to change your spare. @JBTacoma remembers those!
  17. Aug 10, 2020 at 7:56 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Didnt say it was going to be first project, i just said project not in a rush to make one.
    But i understand what your saying, thanks for the concern!
  18. Aug 10, 2020 at 7:59 AM
    BamaTaco56
    Trey
    I wasn’t saying you were and I tried to acknowledge that. Just trying to look out!
    cubie and Brian422[QUOTED] like this.
  19. Aug 10, 2020 at 7:59 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Yes they were an accident waiting to happen.
    Farm Jack, Railroad Jack, High Lift Jack or Kanga-Jack
  20. Aug 10, 2020 at 8:00 AM
    BamaTaco56
    Trey
    I’m going to build a poor eagle jack soon.
    cubie likes this.
