Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Oct 9, 2020 at 9:30 AM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Cool man thanks, what does it hold? I've only seen the one that holds six switches!
  2. Oct 9, 2020 at 9:39 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    My fairlead is recessed (bc ARB doesn’t believe in synthetic line) and on hard angles, the line will rub the bumper edges and fray. I want to put some sort of curved hard plastic around it. I’m thinking I will temporarily put it on and take it off when not in use but I don’t know what I could use. Any ideas?
    Cred92 likes this.
  3. Oct 9, 2020 at 9:42 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    :anonymous:
  4. Oct 9, 2020 at 9:44 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    put some sound deadening mat over the edge where it rubs
    Peligro, pdaddy[QUOTED] and JKU3000 like this.
  5. Oct 9, 2020 at 10:21 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    From AlabamaWX
    updated
    OVERVIEW
    : A combination of the dynamics of a tropical system and the building instability with the heating of the day brings the potential for a few tornadoes on Saturday, especially during the afternoon and early evening hours. NWS Birmingham is really starting to push the word out that we will really need to focus on a higher tornado threat across Central Alabama as the latest model runs are showing that to be the case with the heating of the day. Due to this developing situation, NWS Birmingham is in discussion to upgrade parts of the area into a level 2 Slight Risk for severe storms. Right now, all of Central Alabama is in a level 1 Marginal Risk. We are using the 12z NAM-3k model run as this is the best view of what we will be discussing.
    _________________________________
    7:00 AM SATURDAY: At this point, we see a pretty hefty rain band from Delta beginning to move into the extreme western portions of Central Alabama. While the threat is rather small for any tornadoes with this band at this early of the morning, we will still have to watch as the tornado chance is not 0%, especially over the southwestern portions of the area (Marengo and Sumter counties). The line will be moving slightly east of due north at this point.
    1:00 PM SATURDAY: We are starting to see the leading band has developed further and become a little more intense, and as we are getting to the main heating of the day, the instability has increased and continues to build as we go through the afternoon hours. You’ll notice that the line is getting a little more ragged. That is because the band has started transitioning into more of a line of cellular thunderstorms. This is when we will really need to start watching for tornado development. Remember, we already will have plenty of shear in place with Delta’s wind field over the area, so it won’t take much for a few spin ups to develop quickly.
    QUICK NOTE: If any tornadoes do develop with this system as it moves across Central Alabama, they will more than likely be your smaller EF-0 to EF-1 tornadoes; but, with the banding turning into cellular storms, the potential for a stronger EF-2 tornado is there. We cannot let our guard down one bit just because we hear that Delta is weakening as it moves through the area. That weakening only tells us about the maximum sustained winds, not the ongoing storms occurring in the associated rain bands.
    7:00 PM SATURDAY: As you can see with the band, the storms within the band have turned mostly into cellular structures… almost like a supercell look. As we start to lose instability due to the sun setting, these storms will begin to lose their punch. At this point, these storms will be close to the highest potential to perform. Instability values will be in the 1000-1200 J/kg range and plenty of helicity (potential for rotating updrafts) in place, this will probably be the time that we would be at our highest risk throughout the day of seeing a tornado or two. The threat will continue on for a few more hours, more than likely ending around 11:00 pm.
    We’ll also have to watch any other bands that enter into the western portions of Central Alabama at this time as well. Even though they will be working through air that as already been worked over, there could be some recovery in the instability according to the time in-between the first band moving through to this point.
    1:00 AM SUNDAY: By this time, just about all of the instability that built up during the daytime hours should have dissipated and the severe threat should be over with. We’ll be left with a little bit of a breeze and some showers. There may be a few rumbles of thunder, but the main action for the day will be over.
    QUICK SUMMARY: Don’t be surprised if portions of Central Alabama go under a Tornado Watch for a good bit of your Saturday. The main window for the potential of stronger to severe storms within the rain bands will be from 1:00 pm to 11:00 pm Saturday. If any tornadoes do develop, they will mainly be smaller EF-0s and EF-1s; but, the potential is there for one or two stronger tornadoes. Maximum wind gusts outside of storms are expected to be in the 20-30 MPH range, below Wind Advisory criteria. Damaging winds up to 60 MPH are possible in any storm that goes severe. We’ll keep you posted throughout the event.
    POOLGUY, Peligro and cubie like this.
  6. Oct 9, 2020 at 11:15 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    pdaddy, Peligro and Brian422 like this.
  7. Oct 9, 2020 at 11:47 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    It's for the spod switch thing.
    JKU3000[QUOTED] likes this.
  8. Oct 9, 2020 at 11:47 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Would that rubber door trim work?
  9. Oct 9, 2020 at 12:28 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Check out this thread. Read both pages, some really good ideas there especially since you already have molex connectors. https://www.tacomaworld.com/threads/tapping-dash-lights.523073/
    Iceberg[QUOTED] and JKU3000 like this.
  10. Oct 9, 2020 at 1:14 PM
    pdaddy
    Preston
    Central AL
    Maybe, worth a shot
    JKU3000 likes this.
  11. Oct 9, 2020 at 1:36 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
  12. Oct 9, 2020 at 1:49 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Eibach Coilover Lift Cooper 285's on Ar23’s BHLM w/ Morimoto Halos Custom Hybrid Front Bumper Custom High Clearance Rear bumper Custom Sliders (weld on) RCI skids Sway Bar Delete CMC WILCO Spare Tire Carrier Auxbeam/ Opt7 lighting components Hella LED Pods RC 30 inch Lightbar Smittybilt XRC Synthetic Winch Timbren Bumpstop/ U-Bolt Flip Rear Diff Breather Relocate
    Hola gents. So I come out of hiding to comment on this that was sent to me recently although it happened last year.... So what’s up with Mobtown? Can’t come up with their own designs had to steal the one John made for me that was one of a kind? Lame....and all proud of it like they designed it too... boooooooooo
    Ghost OTC likes this.
  13. Oct 9, 2020 at 1:58 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Thank You
    medic2230 and cubie[QUOTED] like this.
  14. Oct 9, 2020 at 2:03 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I saw your bumper and thought you designed it around theirs lol. Guess yours came first then?
    cubie likes this.
  15. Oct 9, 2020 at 3:10 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Yup. Back in winter of 2018. John built it for me and posted his work on a Tacoma page and then a few months later they came out with this...
    Brian422[QUOTED] likes this.
  16. Oct 9, 2020 at 3:13 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Yup December 27th 2018 is when I got it back from him
    Brian422 and Cred92 like this.
  17. Oct 9, 2020 at 3:16 PM
    Cred92
    Cred92 PAID4MOD
    Caleb
    Jasper Al
    Indigo Ink Sport DCLB/White RC I4 5MT
    BLACK AND BLUE STUFF
    https://www.morris4x4center.com/factor-55-hawse-offset-fairlead-1-5-thick.html?gclid=CjwKCAjwlID8BRAFEiwAnUoK1W7r7NYus34Iav-OQ2BK8VGWuGE5trLj0ZZH1gn3J86DjaqvQXbN4hoCieIQAvD_BwE
    I always thought you were supposed to have an offset fairlead for poly line on the arbs that or they make polley roller fairleads too. Kinda why I just went with steel cable.
  18. Oct 9, 2020 at 4:18 PM
    JKU3000
    Birmingham, Alabama
    2014 Tacoma
  19. Oct 9, 2020 at 4:36 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    You should be able to find the dimensions of each one.
  20. Oct 9, 2020 at 4:43 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    I've always wanted to use this emjoy but could never find the proper place and time! I think I need to follow you?
