Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Apr 21, 2022 at 9:44 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    No idea what it is worth, just about everything is new. Rebuilt motor, transmission, both transfer cases, both axles, new six bolt Hellfire knuckles custom built for the FJ80 axle.
    1.6 8v custom multiport injection with Microsquirt controller.
    3 speed automatic transmission, Twin cases- modded Tracker transfer case, behind that is a Samurai transfer case with 6.5:1 gears with triple sticks, all have been rebuilt.
    New aluminum radiator.
    BFG 39 Reds
    PSC Full Hydro steering
    FJ 80 Axles, rear full float with Yukon locker, FJ80 high pinion front diff with Detroit locker, new 5.29 gears. All new Trail-Gear Hub Stud Kits all four corners. Both axles all new Toyota seals and bearings. All new calipers and Crown stainless steel braided brake lines. New Toyota E-brake cable.
    Race Line RT81 Rock 8, 17-inch steel bead locks
    Hellfire FJ80 Knuckles
    Radflo 2.0, 14-inch Air Shock 1.25'' shaft
    Heat treated chromoly 1 ¼ heim joints
    Four linked rear, three linked front
    Front and Rear, two inch T6 7075 aluminum links
    Pan hard bar T6 7075 aluminum with Barnes ¼ inch mounts
    Steel custom, LineXed Fender flares
    All ¼ inch Barnes Link mounts
    ¼ inch Barnes Shock towers
    Front and rear Suck Down winches
    Busted Knuckle Limit straps
    Toyota FJ80 front driveshaft and Toyota Rear CV Driveshaft
    ¼ inch front and Rear Diff guards
    ¼ Front Frame re-enforcement
    Front and rear axle trusses
    3/16 front and rear bumpers
    Smittybilt 9500 lb winch
    15-gallon aluminum fuel cell
    Final rear ratio 150:1 can rear gear the front case and get 330:1
    Ask what its worth to them, I have hundreds of pictures.
    nagorb likes this.
  2. Apr 21, 2022 at 9:46 AM
    JBTacoma
    Jeff
    Cullman Alabama
    The Tacoma is on the back burner right now. I still need to find some axles for that one.
  3. Apr 21, 2022 at 11:48 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Ease outs can make a bad situation much better.
  4. Apr 22, 2022 at 6:06 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Mornin Fellas
  5. Apr 22, 2022 at 6:41 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Must be that time of the year.
  6. Apr 22, 2022 at 6:47 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Roll Tide!
  7. Apr 22, 2022 at 7:25 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Haha some of the schools around here closed because of traffic. I think it’s a half day or something.
    Brian422 likes this.
  8. Apr 22, 2022 at 7:37 AM
    ty.s07
    Alabama
    That’s intense, I went once when I was like 12… Saw some things that a 12 year old should not see.. so naturally I had a lot of questions and did not return lol.
    Dayman Karate[QUOTED] likes this.
  9. Apr 22, 2022 at 7:42 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    the barbecue sauce wrestling pit is where its at lol
    JKU3000 likes this.
  10. Apr 22, 2022 at 7:44 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I’ve never been, but I’m guessing since I’m nearly ten years sober now it may not be my crowd any more :rofl:
  11. Apr 22, 2022 at 7:45 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    :amen:
  12. Apr 22, 2022 at 8:50 AM
    ty.s07
    Alabama
    Oh lord, this is a new level! Although, I do like bbq sauce. Maybe not after strangers have rolled in it.
    Yeah you’re definitely going to want to pass. I don’t think you could go to the race and actually enjoy it unless you’re lit.. or 12.
  13. Apr 22, 2022 at 9:21 AM
    JBTacoma
    Jeff
    Cullman Alabama
    If you get in the stands you can enjoy the race, it is great. Now if you roam the parking lots where the RVs are or the infield you can find just about anything. I will never forget the 1981 race we took a keg of beer into the infield. I went to the restroom and then it was a block building with water running down the walls on each side and a drain in the floor. It was always a wait to get in, this time I was on my way out and a girl came running through wearing only her shoes and sock. It has been calmed down a lot since then but it use to be a free for all. I go any chance I get, my nephew gets tickets from a dealership that donates the trucks they use to ride the drivers around the track. It isn't a free for all anymore but if you wonder off looking for it you will find it and sometimes even if you are not looking but if it is close to the track they carry people out fast if they see it.
    JKU3000 and ovrlndkull like this.
  14. Apr 22, 2022 at 9:28 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    If yall think it gets rowdy there you should of been to some of the old Darlington or Rockingham races. You really want to see crazy Wilkesboro before it closed. Today's NASCAR is not the same.
  15. Apr 22, 2022 at 9:34 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That’s been my idea of it pretty much my whole life haha
  16. Apr 22, 2022 at 10:02 AM
    ty.s07
    Alabama
    Ha same pretty much. I will admit though, seeing it in real life gave me more appreciation for how fast the cars are actually
    going. TV makes the cars seem slow.
  17. Apr 22, 2022 at 10:29 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    It’d be pretty badass to see them fly by.
    These guy are down to see a bit more-
    https://youtu.be/zk6rSPnLOLE
    :rofl::rofl::rofl:
  18. Apr 22, 2022 at 2:12 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Strapping into a car cranking it up then going wheel to wheel with guys is even more thrilling.
    Makes me kinda miss my circle track racing days. Except how much it costs.
  19. Apr 22, 2022 at 2:16 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    guinea horn :rofl::rofl::rofl::rofl:
  20. Apr 22, 2022 at 2:27 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Bahaha that video is ridiculous.
