Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Aug 5, 2022 at 7:49 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Nah you’d be fine as is. You can always hop in with someone if it gets too crazy. Depending on who all is going we would probably hit a variety of stuff.
  2. Aug 5, 2022 at 8:27 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    That is why I would like to get two groups to go. That way everyone could have fun and not have to worry about pushing too hard. Maybe a few more guys on here will go that wants to do the easy to medium trails. I will ride with everyone but I want to do those hard trails too.
  3. Aug 5, 2022 at 9:27 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I’m planning on going probably gonna do all the medium trails. Jester, broke foot, ole 22 etc. had fun on those last time. Gotta flex out the new long travel too!
    JKU3000 and Key-Rei like this.
  4. Aug 5, 2022 at 9:31 PM
    JBTacoma
    Jeff
    Cullman Alabama
    @Key-Rei
    Key-Rei likes this.
  5. Aug 5, 2022 at 9:32 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Wow September is really only a month away...
    What days are you guys looking at going?
    I really should do my FJ case, gas tank and shock relocation on my vacation.
  6. Aug 6, 2022 at 4:26 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Weekend of 16th or 23rd
  7. Aug 6, 2022 at 5:35 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Mornin fellas
  8. Aug 6, 2022 at 12:42 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Well I screwed up @Dayman Karate day.
    Got about quarter mile from Stony's entrance and started losing power. Checked everything I could, had 60 psi fuel pressure, spark on all four cylinders, all four injectors firing. Decided it must be in the timing somewhere. Either the key in the crank pulley or cam pulley sheared or the timing belt. Been in the sun too long today, I will check it out tomorrow. Again @Dayman Karate sorry you rode so far to ride and didn't get to.
    Dayman Karate likes this.
  9. Aug 6, 2022 at 12:58 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Both sides on and brake like on. Just got to zip tie and clean everything up. Torque everything and get diff and brake fluid filled back up.
    also needed to space my bump stops down about 2 inches and luckily enough the old super bump pads I had from my stock ubolts where exactly 2 inches to I just cut off the ends and welded those to the frame.
  10. Aug 6, 2022 at 1:20 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    No worries. Hopefully it won’t take much to fix it. I may try to hit up Morris or Chocco tomorrow if that GA group is at either one
  11. Aug 6, 2022 at 1:25 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Jeff
    Sup Brian
    Sup Clay
  12. Aug 6, 2022 at 1:50 PM
    Key-Rei
    Key
    Florida
    When you doing the V8 swap? :rofl:
  13. Aug 6, 2022 at 6:17 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Anyone wanna ride Chocco or Morris tomorrow?
  14. Aug 6, 2022 at 6:47 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Finished up happy with how it turned out. Just got a couple of things to button up. Gonna try to get an alignment tomorrow. Got plenty of room at the cab mount. Gonna take some caster out. Drop out is way better than stock length. Also cv angles are very good. Ready to get it out and test her!
  15. Aug 6, 2022 at 6:55 PM
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    These keep getting better….WooooPig
    JKU3000 likes this.
  16. Aug 6, 2022 at 10:02 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Too much work tbh. It’s a head scratcher to try to make everything play nice with everything.
    Hayden334 likes this.
  17. Aug 7, 2022 at 5:18 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Mornin fellas
  18. Aug 7, 2022 at 10:13 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    With the middle bar gone and tent moved up 6 inches, there is so much more room now. What a difference. Sits just at the roof rack so MPGs shouldn’t be effected to much.
    Also, anybody know how to get welding particles off glass without scratches? Wasn’t paying attention and had the fan blowing right on my back window as I welded smh
  19. Aug 7, 2022 at 10:16 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Preston
    Looks good
    I didn't watch it, but......
    Weld and grinding spatter removal services. Glass scratch removal services NYC, Glass Restoration. - YouTube
    pdaddy[QUOTED] likes this.
  20. Aug 7, 2022 at 12:13 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I’ve got grinder splatter in my passenger window from when I did my 4 x 4 conversion and was grinding the interior of the cab.
