Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Apr 5, 2023 at 6:40 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Take it in and see , all they can do is just say no or replace them .
    pndwind and Barrie like this.
  2. Apr 5, 2023 at 7:24 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    I had it done years ago. The dealer would not put my helper springs back on. They said that they can not put any after market part back on under a recall issue. They also told me that I wouldn’t need the helpers springs with the new spring packs. Not true. The springs were soft and could not handle most weight. If you don’t carry much weight and don’t have anything after market on they, then go for it.
    I took my replacement springs off and upgraded to Dobinsons.
    Stevie17 likes this.
  3. Apr 5, 2023 at 8:11 PM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    After more research I found several cases where guys with lift blocks went in and had the springs replaced with no issues. Seems that they leave the blocks but not an AAL. I'm going to call the local Toyota dealer in the morning and see what they say. Thanks guys.
  4. Apr 6, 2023 at 5:24 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    From AlabamaWX
    SLOW MOVING FRONT: We will have a wide range of weather conditions across Alabama today thanks to a very slow moving front near the northwest corner of the state early this morning. The most widespread rain today will be over the northwest counties near the front, but scattered showers and storms will form statewide this afternoon as the air becomes unstable with the daytime heating process. We note a flash flood watch is in effect for Franklin, Colbert, Lauderdale, Lawrence, and Limestone counties, where heavy rain is possible. Rain amounts will be lighter and spotty over the rest of the state.
    Some thunder is possible this afternoon, but there is no risk of severe thunderstorms. In fact, we see no risk of severe storms for at least the next seven days across Alabama and the Deep South… a welcome break.
    Temperatures this afternoon will range from the low 60s around the Shoals to the low to mid 80s from Birmingham south and east.
    TOMORROW AND THE WEEKEND: The front will sag slowly southward, and we expect occasional rain tomorrow and Saturday statewide. There will be some breaks in the rain along the way, but the chance of it raining at any one point each day will be in the 60-70 percent range. Highs drop into the 60s over the northern third of the state tomorrow, with 70s for South Alabama. Many North Alabama communities won’t get out of the 50s Saturday, a good 15 degrees below average for mid-April.
    Dry air returns Saturday night, and Easter Sunday looks very pleasant with ample sunshine along with highs in the 65-75 degree range.
    NEXT WEEK: The weather will be dry for the northern 2/3 of the state Monday through Wednesday… a few showers are possible near the coast. Global models suggest a chance of rain statewide by Wednesday night into Thursday, followed by dry air Friday. Highs through the week will be mostly in the 70s… See the video briefing for maps, graphics, and more details.
    ON THIS DATE IN 1973: On this date through the 8th, a major spring snowstorm dumped 11.6 inches of snow across Denver, Colorado. Most of the heavy wet snow of 10.1 inches fell on the 7th when temperatures remained in the 20s. The low temperature of 5 degrees on the 8th was a new record low for the date and the lowest for so late in the season.
    ON THIS DATE IN 2007: In Cleveland, Ohio on the 6th to the 9th: The opening-season series between the Indians and Minnesota Twins is wiped out by a snowstorm and a cold snap. The Indians led 4-0 when their home opener Friday on the 6th was called off by umpires because of heavy snow. The grounds crew who tried to make the field playable with backpack blowers and brooms spent more time on the field than the players during nearly three hours of stoppages. About a foot of snow remained on the ground Monday afternoon the 9th.
  5. Apr 6, 2023 at 5:52 AM
    Barrie
    Barrie Well-Known Member
    Barrie
    Brownsville, Ky
    2004 Toyota Highlander.
    Good morning Mike.
  6. Apr 6, 2023 at 5:53 AM
    Hayden334
    Hayden
    Cullman, Alabama
    Good morning guys
    Barrie, Stevie17 and pndwind like this.
  7. Apr 6, 2023 at 6:12 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I can help you change that :p
    Barrie and Stevie17 like this.
  8. Apr 6, 2023 at 6:31 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Morning yall
    Barrie, pndwind and Stevie17 like this.
  9. Apr 6, 2023 at 6:34 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Morning buddy.
    cubie[QUOTED] and Stevie17 like this.
  10. Apr 6, 2023 at 6:48 AM
    Stevie17
    Stevie
    Crossville, Alabama
    Morning erbody
    Barrie and pndwind like this.
  11. Apr 6, 2023 at 7:03 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I’m ready to get these ball joints replaced, new suspension on and new tires installed!
  12. Apr 6, 2023 at 7:13 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    It will be an upgrade for sure.
  13. Apr 6, 2023 at 7:59 AM
    Stevie17
    Stevie
    Crossville, Alabama
    Time to get outside and work on changing lawnmower blades. :annoyed:
    JKU3000 and cubie like this.
  14. Apr 6, 2023 at 8:03 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Ctiing mine tomorrow after work so i dont have to do it sat or sunday
    Stevie17[QUOTED] likes this.
  15. Apr 6, 2023 at 8:54 AM
    Hayden334
    Hayden
    Cullman, Alabama
  16. Apr 6, 2023 at 9:25 AM
    Stevie17
    Stevie
    Crossville, Alabama
    Supposed to be raining up here the rest of the week so I try to do what I can .
  17. Apr 6, 2023 at 9:27 AM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Morning everyone!
    Seems like I've used mine more for things other than moving my truck (guiding trees down, pulling stumps, winching cement mixers up hills, moving really large rocks, etc, etc.)
    cubie and Stevie17 like this.
  18. Apr 6, 2023 at 4:39 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    I had some messages with them. The dimensions weren't right.
  19. Apr 6, 2023 at 7:00 PM
    Hayden334
    Hayden
    Cullman, Alabama
    well damn
  20. Apr 6, 2023 at 7:36 PM
    Toyotacrawler
    Cusseta/Opelika AL
    Gollee it's hard finding a quiet moto helmet that looks good for a small melon. Of course the best looking one is out of stock everywhere for the size my Wife needs.
    pndwind, Stevie17 and Hayden334 like this.
