Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. May 15, 2023 at 8:09 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Yea got 3 sets for all around well see if it's worth it or not if I can't use them all then I can try to sell here or there.
  2. May 15, 2023 at 8:26 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    I just did 1 set. I'm pretty sure you'll only be able to use 1 at the rear(as the grease tit won't have enough room).....not sure about the front. If you can only use 2 sets, I may buy 1 since I only have 1 :D
  3. May 15, 2023 at 8:29 AM
    Tiedie
    David
    WFOY
    Like you said maybe only 1 set used but it's going up on a lift I'll let them know if they can't use just let me know then we will go from there.
  4. May 15, 2023 at 8:34 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I will say, I've never had the Tacoma "squeak" with my Dobinsons.
    Tiedie[QUOTED] likes this.
  5. May 15, 2023 at 9:22 AM
    Peligro
    Peligro Well-Known Member
    Don
    Calera, AL
    2012 GMC Sierra SLT - 2 2023 CFMoto CForce 600s - 2024 Segway Villian SX10 S
    Self installed July 2020
    JBA UCAs
    Dobinson
    Front coil C59-352 2.4” at stock weight
    Front strut GS59-220 extended +1”
    Rear shock GS59-940 0-3”
    Rear leaf L59-111-R 2.1” w/600#
    Cooper STT Pro 285/65/18 on Vision Rocker 18x9
    ChassisUnlimited Bumpers don’t even come close to weight expected. Driving with 250-300# in bed makes ride sooooo much more comfortable.
    Don’t mind the box in bed, Costco shed needed for chicken coop supplies lol
  6. May 15, 2023 at 9:26 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    I have the same problem.
    Stevie17 likes this.
  7. May 15, 2023 at 9:38 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Don
    Sup Hayden
    After watching these 2, I'm gonna build a slide in camper out of aluminum :D
    This style
    DIY Slide-In Camper Build Series - YouTube
    With this material
    Truck Camper Build - YouTube
    Hayden334[QUOTED] and Stevie17 like this.
  8. May 15, 2023 at 9:41 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    PSA just dropped the 15 round Micro dagger mags, just bought 2. Works with Glock 43x
    cubie and Stevie17 like this.
  9. May 15, 2023 at 9:49 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Do those suggest a metal mag release like the SA? I really don't want to have to use a metal one since I have so many stock mags.
  10. May 15, 2023 at 9:53 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Nope, thats why i bought it. It can be used with oem release and oem mags. You can mix and match :D
    https://youtu.be/pAXOi_PKx5A
  11. May 15, 2023 at 9:54 AM
    pndwind
    pndwind Identifies as a Clown.
    Bret
    Heart of Dixie
    Gas Guzln Pig
  12. May 15, 2023 at 9:54 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Nice. I might have to look into a few of those.
  13. May 15, 2023 at 9:55 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Nope. He used brackets and brazing rods from HF.
    I can't weld.....so I'd have to go that route. I wanted to do it that way, just didn't know if it'd work until now :rofl:
  14. May 15, 2023 at 10:08 AM
    pndwind
    Bret
    Heart of Dixie
    Gas Guzln Pig
    I was hoping you were going to learn how and then I’d have someone to ask. :rofl:
  15. May 15, 2023 at 10:18 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    @Brian422 and @Nic S are the welders :rofl:
    I'm probably gonna drop by and grab at least 4 sticks of the 1x1 aluminum tubing(and some more insulation......as I already have some from when I was messing with the ARE shell :rofl:) and do the floor after I get my monies for the desk :D
    I also plan to cut this thing up and use the tubing from it.....might even use the side panels and doors:D
  16. May 15, 2023 at 10:25 AM
    pndwind
    Bret
    Heart of Dixie
    Gas Guzln Pig
    Have you thought about using 80/20 extruded aluminum?
  17. May 15, 2023 at 10:28 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I have, but I can get 8ft 1x1 from Lowe's for $28 a stick. Being that I want to do a fully enclosed slide-in......the 80/20 was just way more than I can float :rofl:
    Stevie17 and pndwind[QUOTED] like this.
  18. May 15, 2023 at 10:31 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    This was all built with the same 1x1. I want a popup, not a wedge. This dude does some awesome builds.....and self taught.
    DualEx on YT
    DualEx - YouTube
    Tiedie likes this.
  19. May 15, 2023 at 11:40 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    If it aluminum i dont have a welder for that. I cant weld steel all day long though.
  20. May 15, 2023 at 11:46 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    After watching that series, the way I was thinking will work without a doubt. Gonna have a super light weighter :rofl:
