Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Dec 13, 2016 at 10:58 AM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    Hey @Davtopgun, did that Allpro u-bolt flip kit work out for you?
  2. Dec 13, 2016 at 11:00 AM
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    It worked great, thanks man! I just need me some nice bumpstops now.
    SuthrnTaco07[QUOTED] likes this.
  3. Dec 14, 2016 at 6:58 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Here is a video clip I took yesterday of the "knock" that I now have. Jacked the truck up this morning and couldn't get anything to "wiggle" or make that sound again. at 26 seconds is the first time it happens and then at 38 seconds and a few times after that. help...
    https://youtu.be/SbrmbXKvMJ0
  4. Dec 14, 2016 at 7:20 AM
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    I think... trucks broken time to sell.
    SuthrnTaco07 likes this.
  5. Dec 14, 2016 at 7:28 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    32k its yours.
  6. Dec 14, 2016 at 7:35 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  7. Dec 14, 2016 at 7:45 AM
    O906
    O906 Well-Known Member
    My trucks makes all kinds of noises. Turn the radio up and don't worry about it until it stop going forward when you press the skinny pedal.
    Sandytaco14, nagorb and rmepilot like this.
  8. Dec 14, 2016 at 7:54 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Lol mine makes plenty more but this one is a new one and comes from an area i dont want to have an issue
  9. Dec 14, 2016 at 7:57 AM
    O906
    It's weird it happened randomly not when your suspension cycled. Do you have a GoPro?
  10. Dec 14, 2016 at 8:00 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I don't. It happens when I hit bumps in the road. If I'm not mistaken I think it had started when we were leaving the trails at Choccolocco. On our path out I had Brad's shackles on the front of the truck that I had used to pull a tree with earlier and I had assumed it was those "rattling" every time I hit a bump...
  11. Dec 14, 2016 at 8:04 AM
    O906
    Oh I didn't know it happened when you hit a bump... jacking the truck up and wiggling stuff probably won't help you because it's taking a lot more force to cycle whatever part is making the noise than you can produce. I'd just keep an eye on it and see if it gets worse or louder, go grease all your suspension parts and break out the torque wrench and check everything wouldn't be a bad idea. I could probably check for torque on all my front end suspension parts in about 30 min including taking both front tires off.
  12. Dec 14, 2016 at 8:07 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    If i dont figure out or dont have any issues before saturday i will have brian and justin and rob and whoevers there take a look with me.
    rmepilot likes this.
  13. Dec 14, 2016 at 9:54 AM
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    Any opinions on the smittybilt rtt? Offered a guy $500 for one local and going to look at it tomorrow afternoon.
  14. Dec 14, 2016 at 10:01 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    When you Jack it up also Jack the suspension up, ie Jack stands on the frame and Jack under tire, then try prying/moving whatevering parts.
  15. Dec 14, 2016 at 10:02 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    hm, good point. I only jacked it up with my hi-lift on the slider so all the suspension drooped..
  16. Dec 14, 2016 at 10:28 AM
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    I'm having a rough week...
  17. Dec 14, 2016 at 11:28 AM
    justinalldredge19
    Justin
    Arab, Alabama
    :luvya:
  18. Dec 14, 2016 at 11:35 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    We'll go for a drive first and go from there. By the end of the day, you may have to buy a supercharger to fix the problem... JS :thumbsup:
    stronghammer[QUOTED] likes this.
  19. Dec 14, 2016 at 11:36 AM
    rmepilot
    Rob
    Huntsville, AL
    :lalala:
  20. Dec 14, 2016 at 11:45 AM
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    I'll give you tree fidy
