Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Dec 2, 2024 at 8:44 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    pretty much what this thread is now unfortunately
  2. Dec 2, 2024 at 8:54 AM
    moto.hermit
    moto.hermit Well-Known Member
    JD
    Munford, AL
    '20 SR5 DCSB 4x4, '25 Suzuki DR650, '16 Triumph Scrambler
    Stock-ish
    Weelllll... here's a convo starter. I'm thinking about going with 285s in a few weeks when I get new tires instead of putting on a new set of skinnies... But I'm hella overwhelmed trying to figure out how many things I'm gonna have to change to make it work. lol
  3. Dec 2, 2024 at 9:08 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Not much to make them work if you have a 2inch lift already. I can give you a cab chop to help clear them. Will need some wheel spacers as well if you are running stock wheels. 1.25 should be enough.
    JKU3000 and moto.hermit[QUOTED] like this.
  4. Dec 2, 2024 at 9:53 AM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    I see your 3rd gen, but on the 2nd gens, might have to cut a little angle on the bottom edge of the front bumper depending on rim width, castor angle. Potentially have to flatten the pinch weld and flatten the inner fender with a heat gun. Not sure if you did any of that for the skinnies.
    moto.hermit likes this.
  5. Dec 2, 2024 at 10:14 AM
    moto.hermit
    JD
    Munford, AL
    Stock-ish
    Right on! I wasn't sure if I would need different UCAs. Guess that's more of an after-the-fact kind of thing if they can't get it aligned right?
    Shouldn't have an issue with the front of the bumper. I cut most of that off when I put on the steel bumper. :anonymous: I have heard about the pinch weld/inner fender stuff. Please correct me if I'm wrong (I've heavily used the search and been reading tons, so just trying to make sure I understand correctly), but to identify if that needs to be done, I've got to pull the coilover and stuff the tire in there as far as it'll go to find out where it contacts?
    Brian422[QUOTED] likes this.
  6. Dec 2, 2024 at 11:49 AM
    TacoAlaMode
    Brian
    Huntsville AL
    Official answer, yes. Effectively, you are looking at the centerline (plus maybe a couple of inches) of the tire at full stuff against the firewall side of the inner fender. As for a disclaimer, that is from years ago information on 2nd gens.
    Brian422 likes this.
  7. Dec 2, 2024 at 12:52 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    New UCA will help with Alignment and fitting the tires better but def not required. Youll just need to add in a little bit more caster when you take it to get aligned. Might ride slighlty worse than stock which thats where new arms come in the help correct the wheel alignment and fit the tires while keeping the alignment at stock. I can cut and weld your cabmount to help with frame clerance at full lock.
    Like Brian said you can pull the coil and see where you will bottom out on the bump at but with just 285 i really dont think it will be a big problem like it is for 315's.
  8. Dec 2, 2024 at 3:40 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Long time since we saw you here! Have a good night!!!
    cubie likes this.
  9. Dec 2, 2024 at 6:16 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Brian! Jeannie just got a job in Huntsville. We’re thinking of moving up towards that way.
  10. Dec 2, 2024 at 6:16 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    How was yall’s Sweetwater camp?
  11. Dec 2, 2024 at 7:16 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Keep me in the loop also.
    cubie[QUOTED] likes this.
  12. Dec 2, 2024 at 8:27 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Goodnight Brian, sleep well.
  13. Dec 2, 2024 at 10:25 PM
    TacoAlaMode
    Brian
    Huntsville AL
    Goodnight John
    Cool, not a bad place to be. If it gets serious, I can try to give you a run down of the areas around here.
    Goodnight Jeff
  14. Dec 3, 2024 at 2:57 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Good morning Bama y'all stay warm and safe today and have a good day.
    It's official it's winter here!
    IMG_20241203_055220265.jpg IMG_20241203_055228629.jpg IMG_20241203_055232989.jpg
    Brian422, Barrie and POOLGUY like this.
  15. Dec 3, 2024 at 3:38 AM
    POOLGUY
    JEFF
    ALABAMA
    Good morning David. Is this about 2” of snow overnight?
    Tiedie[QUOTED] likes this.
  16. Dec 3, 2024 at 3:39 AM
    POOLGUY
    JEFF
    ALABAMA
    Good morning everyone, have a great, safe and blessed Tuesday.
    Barrie likes this.
  17. Dec 3, 2024 at 3:45 AM
    Tiedie
    David
    WFOY
    Good morning Jeff, I'm thinking a little bit more than an inch couldn't find the ruler easily.:rofl:
    POOLGUY[QUOTED] likes this.
  18. Dec 3, 2024 at 5:03 AM
    Barrie
    Barrie Well-Known Member
    Barrie
    Brownsville, Ky
    2004 Toyota Highlander.
    Good morning David.
    Good morning Jeff.
    19 degrees here with a dusting of snow.
  19. Dec 3, 2024 at 6:59 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    We amped at Coleman Lake. It was great! Had an awesome time. Will go back when it reopens in March.
    POOLGUY, Barrie and cubie[QUOTED] like this.
  20. Dec 3, 2024 at 8:33 AM
    Barrie
    Barrie
    Brownsville, Ky
    Good morning Brian.
