Alarm broken after battery change
Discussion in 'Technical Chat' started by pipcorona, Sep 27, 2011.
  1. Sep 27, 2011 at 7:46 PM
    pipcorona
    pipcorona [OP] New Member
    08 PreRunner TRD Off Road
    I have a 2008 Tacoma with the factory alarm system in it. My battery recently died and I had to replace it. Since I replaced the battery the red LED alarm light will do two short flashes, stop, then two more flashes. It does this constantly, whether the car is on or off. The alarm is not arming when I lock the doors and I tested opening the doors from the inside after locking with the remote and the alarm didn't activate.
    I'm not exactly sure which alarm system I have. Usually after I arm the system the horn honks once. The back of the remote has TRW on it.
    Any help on fixing this so my car alarm arms itself again would be great.
  2. Oct 3, 2011 at 7:46 PM
    tooxslick
    tooxslick Well-Known Member
    Gary
    San Gabriel, CA
    06 SR5 BSP Access Cab
    LED Interior, MagLite Mount, BHLM, Limo Tint, Fog Lights, HIDs, PA15-TOY, DTRL, ReadyLIFT SST 2.75", Maplight Mod, Secondary Air Filter Removal, Black Interior, Debadged, AFE Stage II Intake, "Deckplate Mod", Satoshi grill.
    I just came across the same problem today. Have you fixed it yet?
  3. Oct 4, 2011 at 12:30 PM
    pipcorona
    I was able to fix it. Apparently the alarm switched into valet mode. By turning the key to on (accessory) and off three times in a row, it switched the alarm back to normal mode. I still don't have the horn honk to notify that the system is armed, but at least it arms itself now.
  4. Oct 4, 2011 at 2:00 PM
    tooxslick
    Gary
    San Gabriel, CA
    I just did this right now. I was able to get the alarm to work again. My horn is able to honk when the alarm is armed. Thank you for your help!
