Alarm Installation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gluis123, Apr 24, 2011.
  1. Apr 24, 2011 at 5:11 PM
    Gluis123
    Gluis123 [OP] Active Member
    Luis
    Hemet, California
    '02 2WD 2.4 Tacoma
    Hello every one! Well I recently bought a 2002 tacoma regular cab base model and I want to put a factory alarm and power lock doors how would I start this project.!??! Thanks in advance :)
  2. Apr 26, 2011 at 10:56 AM
    Turp
    Turp Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless
    I can save you hours of surfing the net for solutions. Basically, Toyota alarms and keyless were not installed as a factory option until 03 as I recall. Prior to this, alarms/keyless were added via Toyota kits after the vehicle left the factory. While some kit components are readily available, the critical vehicle specific harness is extremely rare and some owners have been seeking them out for some time.
    I decided to install a aftermarket from Audiovox keyless. It cost about $25 and the install was very straight forward. There is a DIY install thread in DIY section.
  3. Apr 26, 2011 at 12:02 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    This is my alarm:
  4. Apr 26, 2011 at 11:35 PM
    Gluis123
    Luis
    Hemet, California
    '02 2WD 2.4 Tacoma
    Thank you very much can you give me a link to that page.. sorryy i tried looking for it I am a n00b
  5. Apr 26, 2011 at 11:36 PM
    Gluis123
    Luis
    Hemet, California
    '02 2WD 2.4 Tacoma
    HAHAHAHAHAHAHAHA I DIED OF LAUGHTER WHEN I SAW IT!
  6. Apr 26, 2011 at 11:41 PM
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    Get yourself one of these: [​IMG]
    Connect it to proximity sensors around the truck and have it roar when the proximity sensors are violated. Should someone be dumb enough to stick around when it goes off, well... They asked for it.
    Do you have a reason to install a real alarm, because often they do not stop the real criminals? They do help against crimes of opportunity, but if vehicle theft in your area is high, chances are good it probably won't be a major deterrent.
