Alarm noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ralphtaco805, Aug 23, 2021.
  1. Aug 23, 2021 at 5:15 PM
    Ralphtaco805
    Ralphtaco805 [OP] Well-Known Member
    15 Tacoma
    Bilsteins 5100 Hellwig Rear swaybar 17 trd sportswheels
    Hello everyone I have an issues with my 2015 taco
    1st is that after I lock my truck with the factory alarm it spontaneously makes 3 small honks like if someone was tampering with it but no one was messing with it and I check my cameras and Also was there went it happened
    2nd I hear a humming noise coming from the gas tank area also spontaneously happens too which is weird but not all the time
    Any solutions?
  2. Aug 23, 2021 at 6:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The humming noise from the gas tank is Normal.
    Nothing to worry about, it has do to with emissions.
    The horn, I have no idea.
    What does your key fob look like?
    Maybe it isn’t an OEM alarm?
    verynearlypure likes this.
  3. Aug 23, 2021 at 6:05 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Did you buy your truck new? Aftermarket alarm? Didn’t know there is a honk option but I don’t have any fancy software to play with.
  4. Aug 24, 2021 at 9:37 AM
    Ralphtaco805
    15 Tacoma
    CPO truck I bought in 2018 I change the original battery it had cuz it died 8 months after I bought it the alarm is original I have two sets but it happens spontaneously though:crazy:
  5. Aug 24, 2021 at 9:38 AM
    Ralphtaco805
    15 Tacoma
    TnShooter[QUOTED] likes this.
  6. Aug 24, 2021 at 12:58 PM
    TnShooter
    Deogee
    STOCK
    Good, it’s supposed to make the noise when the truck is off.
    That’s how it was designed. There is a timer that starts when you turn the truck off.
    Depending on certain criteria, the “hum” AKA=EVAP Test will start.
    Simplified version is, it’s checking the fuel tank for vapor leaks.
  7. Aug 24, 2021 at 1:44 PM
    05ordc
    05ordc Member
    Billerica, Ma.
    05 silver trd or dcab [new frame]
    I get three honks if try to lock my truck with a door open or if door is not closed all the way. When you close the door ill get one more honk telling you its armed and locked.
  8. Aug 24, 2021 at 2:01 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    3 rapid hooks if the a door is not closed
    1 hook if all closed
    2015 DCSB
    I'd check the door switches.
  9. Aug 24, 2021 at 10:04 PM
    Ralphtaco805
    15 Tacoma
    Wow didn’t new that but does it run all day too? Cuz I was curios one time and I went back couple hours later and it was still humming
  10. Aug 24, 2021 at 10:05 PM
    Ralphtaco805
    15 Tacoma
    Yeah I make sure all my doors and windows before I lock it but some how it still do it?
  11. Aug 24, 2021 at 10:07 PM
    TnShooter
    Deogee
    STOCK
    No, that is not normal.
    Mine runs maybe 1-2 mins.
    It should not be running nonstop for hours?
  12. Aug 24, 2021 at 10:07 PM
    Ralphtaco805
    15 Tacoma
    Could also be sensitive alarm? Even though it from factory?
  13. Aug 24, 2021 at 10:08 PM
    Ralphtaco805
    15 Tacoma
    Then I think I have an electrical problem then or something hmm
  14. Aug 25, 2021 at 7:18 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Will a Tacoma do a three-honk when you try to lock it while it is still running? I wonder if the noise from the gas tank area you are hearing is the pump running, because it is still energized. That might indicate your ignition switch or an associated relay is keeping the circuit powered up after you have switched it off. And the alarm may look at that as “vehicle is still running”.
  15. Aug 25, 2021 at 9:07 AM
    Leomania
    Leo
    All stock, baby!
    Just went to test this, and the answer for my 2011 is "no". If the ignition is on, pressing the lock button on a second remote does nothing. If the door is open, I'll get a long beep, not three beeps.
  16. Aug 25, 2021 at 11:53 AM
    anonemoose
    Bill
    Big Pine, Calif
    Check the connector under the dash to the alarm. Mine had a wire that was crimped on the insulation
    and one day after I pulled in to the drive way it died - completely dead. Toyota towed it in and it took 3 days to find it.....
    maybe a wire from the door switch is not making contact in the plug.
    Ralphtaco805[OP] likes this.
  17. Aug 26, 2021 at 12:38 AM
    Ralphtaco805
    15 Tacoma
    what?? mine makes a different sound it sounds like a new car alarm you know the chime sound eeeeeeeeeee when the door is not closed all the way when I try to lock it but when I lock it honks 1 time
  18. Aug 26, 2021 at 12:40 AM
    Ralphtaco805
    15 Tacoma
    Checked and still can’t find the problem I’m replace the key fob battery and see if that helps if not I’m try my other set of keys …..
