Alarm oddity
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HankG99, Oct 17, 2017.
  1. Oct 17, 2017 at 7:53 AM
    HankG99
    HankG99 [OP] Member
    Hank
    Los Angeles
    ‘06 Tacoma Access Cab 4x4 5spd MT
    Hey everyone!
    So, for the past few nights, my truck has been doing like 6 rapid honks in the middle of the night and then stopping. Any ideas what could be causing this? Any help is much appreciated
  2. Oct 17, 2017 at 8:24 AM
    Muddinfun
    Muddinfun Well-Known Member
    Some punk testing your alarm. When you get tired of hearing it and decide there's something wrong with your alarm and leave it off, then they'll smash the window and steal your stuff. Or it's the repo man.
  3. Oct 17, 2017 at 8:27 AM
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    Believe it or not, this same thing happened to me last winter when the temperature started dropping. It ended up being a bent check arm in my door had bent the window track and as it would get cold, it would cause the metal track to pop loudly, which would cause a vibration in the door, and set my alarm off-probably from the shock sensor. Changed parts, no more issues :)
    Also to note, I read that a weak battery can cause this in cold weather. Hope this helps! :)
    Jester243 likes this.
  4. Oct 17, 2017 at 8:27 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    aftermarket or factory?
  5. Oct 17, 2017 at 8:28 AM
    climbhigher23
    climbhigher23 Well-Known Member
    SoCal
    2017 QS TRD Off-Road 4x4
    2.5" King w/Adj 285/70/17 Wildpeaks Ray 10's
    Sounds like a warning violation for the shock sensor. Could be a cat jumping on your truck too
    Whitetrash likes this.
