Alarm stopped working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leo8, Nov 11, 2019.
  1. Nov 11, 2019 at 1:08 PM
    Leo8
    Leo8 [OP] New Member
    Tacoma 2013
    factory alarm on Tacoma 2013 stopped working and I can see a light blinking under the steering wheel when truck is parked and locked, (no power locks installed) .
    I once heard that alarm could be disabled for Valet Parking purposes. Is there a way to disable or enable the alarm?
    Thanks.
  2. Nov 12, 2019 at 4:50 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I don't believe that the factory alarm has a valet switch like the aftermarket alarms. It's usually set to active arming unless the owner chooses to change that setting. Does it go off when you open the door or the led stops flashing when you disarm it? Try replacing the key fob battery first to see if it fixes it. If not, try disconnecting the battery.
    Welcome to TW!
  3. Nov 12, 2019 at 8:32 AM
    Leo8
    Tacoma 2013
    Thanks for your time and advise, I will do that and post if it works.
