Alarm System - Will Not Return To Normal (Gulf States Toyota Alarm)
Discussion in '1st Gen. Tacomas (1995-2004)' started by CS_AR, May 30, 2019.
  1. May 30, 2019 at 12:34 PM
    CS_AR
    CS_AR [OP] Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I drove the truck yesterday without an issue. Parked it last night. It rained. I accidentally locked the doors using the passenger side lock.
    Today I get into it and the alarm goes off. I try unlocking the doors three times. No change.
    I disconnect the battery and reconnect it with the ignition on. The emergency flasher lights start blinking. I try to start it and nothing happens. Like power to the starter/igniiton has been cut.
    I get out of the truck and close the door and it makes a series of short horn beeps. No start.
    This is a stock alarm system as far as I can tell.
    Is there any way to disarm or disable this?
    Right now the truck is parked in my side yard. I can't even get it into my driveway.
  2. May 30, 2019 at 12:39 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Does your key fob look like this?
    If not, it's likely aftermarket.
    I'd say that's a normal thing for older aftermarket alarm systems. The Viper I had on my old 4Runner eventually took a dump and started acting weird, so I had it removed.
    But I don't tend to hear about OEM systems going back like that. Weird.
    CS_AR[OP] likes this.
  3. May 30, 2019 at 12:52 PM
    CS_AR
    No key FOBs.. It has a sticker on the driver's window that says anti-theft system. Also, the dealer etched the vin numbers on each window.
    I guess I will need to get it towed to the dealer to get them to remove whatever the hell is on this.
  4. May 30, 2019 at 1:02 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    the RS3200 brain is typically behind the DS left foot kick panel. Check there and see if there is a black box there.
    RedManRocket likes this.
  5. May 30, 2019 at 1:02 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Ah so you've triggered the alarm without key fobs, so you're probably going to have to get an oem fob, connect the fob, and disarm it
    wilcam47 and jbrandt like this.
  6. May 30, 2019 at 1:07 PM
    jbrandt
    Justin
    So you don't have a key fob? You may just need to get one, then. Dealer would have them, they're expensive thru the dealer, but there are other options I believe. Not sure how to have it programmed tho, so dealer would be able to help there, too.
    I believe the factory alarm is an RS3200, and it should say that on the module under the dash.
    I remember trying to unlock one of my doors with the key (instead of the button) and it got all pissed off until I was able to disarm it with the button.
    CS_AR[QUOTED][OP] likes this.
  7. May 30, 2019 at 1:17 PM
    RedManRocket
    Red
    2002 Double Cab LT
    You can buy a fob online and should be able to find the program sequence also. It's a mixture of turning the ignition on and off and opening the doors
  8. May 30, 2019 at 1:18 PM
    RedManRocket
    Red
    2002 Double Cab LT
  9. May 30, 2019 at 2:11 PM
    CS_AR
    OMG - I can't believe what just happened.
    I called Caldwell Toyota and explained the situation to the service tech about my 1999 Tacoma.
    I asked: Do I need to get the truck towed in so you can work on it?
    Service Tech replied: "Let me get the Service Manager to help you."
    Andy Lamb comes on the phone and asks: "Where is the vehicle right now?" I gave him my home address.
    He said: "Just give me a few minutes and I'll be right there.". I thought I was going pass smooth out.
    Knock me over with a feather. The Service Manager is driving to my house to fix my 99 Taco in my yard!
    He pulls up a few minutes later. We try a couple of things. I have a 10mm barrel, a #2 JIS driver, a punch and 10mm open end for disconnecting the battery.
    We are in my side yard. He checks a couple of things. He pulls the panel under the steering column. Locates the anti-theft system module with the red 10 amp fuse. Pulls the fuse turns the key on, then reconnects the fuse and resets the system. Problem fixed. Some sequence of locking the doors and jacking around with the passenger door lock must have tripped the system. While he was under the dash, he showed me how to reset the system.
    I HAVE NEVER SEEN AUTOMOBILE SERVICE LIKE THIS. CALDWELL TOYOTA now has a customer for LIFE.
  10. May 30, 2019 at 2:22 PM
    jbrandt
    Justin
    Damn, that is straight up great service.
    Shows you he's actually a fan of the brand and takes pride in his work, and not just some schmoe working there for a paycheck.
    wilcam47, CS_AR[OP] and RedManRocket like this.
  11. May 30, 2019 at 2:30 PM
    taco bout it
    taco bout it Well-Known Member
    Los Angeles, CA
    2003 DC Tacoma PreRunner V6 Limited TRD
    When you removed the Viper is the OEM keyless entry still present? If I got a OEM fob could I theoretically get rid of this barely functioning Viper?
  12. May 30, 2019 at 2:36 PM
    jbrandt
    Justin
    The viper was on my '86 4Runner, no such thing as keyless entry back then, lol... I got it after it was broken into (twice) back in college. It really only lasted a few years before it started going nut. POS IMO...
    As long as you still have the RS3200 hardware intact, you should be fine, I would imagine, but I don't know how the viper plays into the stock wiring and if they have to cut a bunch of wires to do it.
  13. May 30, 2019 at 2:38 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Wow that's amazing, awesome for them giving a good name to that department
    wilcam47 and CS_AR[QUOTED][OP] like this.
  14. May 30, 2019 at 2:58 PM
    tony2018
    tony2018 Well-Known Member
    Thats a keeper.
    wilcam47 and CS_AR[OP] like this.
  15. May 30, 2019 at 3:01 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  16. May 30, 2019 at 3:53 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I thought with the RS3200 if the alarm goes off you can deactivate it by putting the key in the ignition and turning it to ON. This is in case the battery in the fob dies you're not stuck.
    I'm not sure if your system was set to passively arm itself or something, but it's best to get a fob and program it however you want. If you do buy a fob from somewhere online make sure you communicate with a human to make sure you get the correct fob. There are slightly different versions based on year, etc., and sometimes they take the circuit board from original fobs and put them in new plastic housings, so you can't go by color, black vs. gray. Just make sure if the fob doesn't program that they'd be willing to send the correct one. Better would be to get a fob from a local store where they can make sure it works right there, but might be more expensive.
  17. May 31, 2019 at 3:29 PM
    CS_AR
    So I drove it to Kroger this afternoon to rent the Rug Dr.. I get out and go inside come back and load the Rug Dr in the bed. I sit in it while I wait for my daughter to come out. While I'm sitting in it the doors lock for no reason. When I hit the unlock button, it trips the alarm. Here we go again.
    The bad part is its sitting with cars parked next to it. When I pulled in there were none around it. I'll need to go back later tonight to try to reset the alarm system. Something is causing the system to arm itself. Then it ignores me using my key to turn on the ignition or to disarm it by using the key.
  18. May 31, 2019 at 3:51 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Did you ever verify what type of alarm it is? You said it was a stock alarm as far as you can tell, but what did you base that on? A stock alarm or Toyota installed alarm will either have a red light built into the gauge cluster or have a red light mounted somewhere with the word Toyota under it. When the alarm is armed this light will blink every few seconds.
    Best way to verify alarm system is to take a picture of the alarm computer box and read the model number printed on it. The guy from the dealer showed you were it is.
    Were you able to get it going by pulling the fuse like the dealer guy did?
  19. May 31, 2019 at 3:57 PM
    CS_AR
    The service manager said it was part of a dealer installation campaign for Toyota in the southern region. Though, there is no red light or reset button on the dash. It has a little black bezel looking thing next to the fuse box. The service manager said that has a clear light inside it.
    I'll need to go back later this evening and try the steps he went through to get it to run. I'll pull a picture when I get into it.
    cruiserguy likes this.
  20. May 31, 2019 at 4:16 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wow I've never even heard a story close to that type of customer service. Do the guy a solid and send the general manager an email telling him how exceptional the service was from this guy. He deserves a raise or a bonus
    wilcam47 likes this.
