Alarm won't disable after new stereo install?
Discussion in 'Audio & Video' started by double dee, Oct 23, 2011.
  1. Oct 23, 2011 at 3:38 PM
    double dee
    double dee [OP] Well-Known Member
    Arizona
    I put in a Pionner AVH-P3300BT this weekend and had installed everything and had it up in working fine. Now all of a sudden my alarm keeps going off and I can't start my car even after I get it to go off. When I try to start it the alarm once again goes off and wont start. As well as the stereo will not come on. sometimes it will but it turns off shortly.
    I have pulled everything out to look at the wiring to make sure there wasn't anything loose and everything seems to be fine so I am not sure what to do? Anyone....????
  2. Oct 23, 2011 at 4:10 PM
    double dee
    Arizona
    anyone?!?!?
  3. Oct 23, 2011 at 4:27 PM
    double dee
    Arizona
    no but i did when i couldn't get the alarm to shut off
  4. Oct 23, 2011 at 5:55 PM
    JaysTOY
    JaysTOY Well-Known Member
    J
    Cincy, OH
    4x4 debadged sport
    DD,
    Sounds like you blew a fuse,, maybe an ignition fuse or a constant fuse,, I can tell you it is a fuse that both your radio and your alarm are tied into, as you stated your radio will stop working and your alarm will not disarm... The reason you can't start the truck is because of the alarm starter-kill being active or the ignition circuit fuse being blown..
    Check fuses..
    Goodluck
    J
  5. Jan 20, 2012 at 11:21 PM
    freddy92117
    freddy92117 New Member
    same thing is happening to me but my doors unlock and alarm stays armed but radio works fine and it happen once before and it just started working and worked for 1 week but its doing it again
