Alarm wont stop going off
Discussion in 'Technical Chat' started by blackhawke88, Jul 16, 2010.
  1. Jul 16, 2010 at 9:59 PM
    blackhawke88
    blackhawke88 [OP] wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Hey guys
    So Im sleeping nice and sound this morning at 7:30 am when suddenly my taco's alarm goes off. I jump out of bed, fumble for my keys, and unlock my truck to stop the alarm. I make sure nothing is around my truck, like an animal or thief...nothing.
    I lock my truck and go back inside to go back to sleep (actually, I should be up getting ready for work). Right when I get back into bed, the alarm goes off again. I run out to switch it off...still nothing around my truck. This time I lock my truck and wait there to see what happens. sure enough, about 5 seconds after my truck is locked, the alarm goes off again. I unlock and keep the doors open so it wont lock again.
    I get ready for work, hop in the truck, starts up just fine. I arrive at the office, get out, lock my truck, start walking away...and sure enough, alarm goes off. Theres nothing i can do except disconnect the battery and manually lock the truck. Problem persists all afternoon, i have to disconnect my battery everytime i lock my truck. WTF is going on?!?!
    I have the factory alarm system from the dealership...never modded it, never touched it. Ima take it to the dealership tomorrow, but any of u guys have any suggestions?
  2. Jul 16, 2010 at 10:00 PM
    747 function > form
    1st Gen.
    Is it an oem alarm, or aftermarket?
  3. Jul 16, 2010 at 10:01 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Sounds like your LT kit is messing it up... better send that stuff to me just to be sure. ;)
  4. Jul 16, 2010 at 10:02 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    it's OEM...so the orginal dealership claims. Stevens Creek dealership said it wasnt factory when I took it in for servicing before. I really have no idea
  5. Jul 16, 2010 at 10:04 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    08 Tacoma TRD Dbl Cab 4x4 MT
    I had a problem like this, but with an aftermarket...had to bypass one of the sensors because it was in an always "on" state. Haven't heard of a factory alarm doing that though...
  6. Jul 16, 2010 at 10:07 PM
    747 function > form
    1st Gen.
    :D
    Hmm...are your doors shut securely (I assume they are)...I don't have much input on an oem alarm. I lived in a high-heat [weather] area for awhile and my non-oem alarm did the same thing (another vehicle)...I never figured out what it was, but when I moved to a more temperate climate, it didn't happen again. Is CA experiencing a heat wave?
  7. Jul 16, 2010 at 10:12 PM
    MHS2846bg8
    Nate
    its been pretty warm here in socal lately.
  8. Jul 16, 2010 at 10:29 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I had a Viper that whacked and would go off for no apparent reason, turned out to be a bad contact on the drivers door pin
  9. Jul 19, 2010 at 8:01 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I had a Chebby quite a few years ago where this would happen when the battery was weak/failing. Alarm saw it as someone disconnecting the battery to disable the alarm.
  10. Jul 19, 2010 at 8:33 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ohh, that could be the case then, because my battery has died on me twice this year already, but I havent changed it :confused:
  11. Jul 19, 2010 at 10:36 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    If your battery is low, that will trigger it.
    A way thieves get around alarms is drill out the batttery fluid it kills alarm....then get in, then pop hood swap batteries or jump it and vroooooooom...their gone with your ride.
  12. Jul 24, 2010 at 7:03 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    changed batteries, still going off...anyone know if i can pull a fuse for the alarm for the time being??
  13. Jul 24, 2010 at 7:32 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  14. Jul 24, 2010 at 7:57 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    haha, i just pulled the fuse off my horn so it will stop annoying ppl until i can find a fix
  15. Jul 26, 2010 at 8:56 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Most alarms are wired in to the system such that easily bypassing them does not work (kinda like they designed it that way :). You might be able to make a few jumpers and jump the connections around the alarm. I did that to an older truck that I had until I found out that it was my battery.
  16. Jul 26, 2010 at 11:00 AM
    Barnone
    Barnone Guest
    How do the thieves drill a hole in the battery without popping the hood?:confused:
  17. Jul 29, 2010 at 5:09 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Right thru the quarter panel if your familiar with the battery location. Nothin a little bondo wont fix. lol
  18. Jul 16, 2013 at 8:41 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    We're you able to fix it? I have the same problem. Battery is fine. Dealer can't replicate it. Tests show alarm system is ok, but it keeps triggering randomly.
  19. Jul 17, 2013 at 3:06 AM
    Matic
    Rich
    Greenville,sc
    Well. Since the last post was nearly 3 years ago......I would guess that It's probably fixed. Lol.
    You might want to make a new thread regarding your situation.
  20. Jul 18, 2013 at 7:13 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    I did that. Got nothing. Was hoping this guy got it resolved and could help.
