Alarms when removing the RF passenger seat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tech67, Apr 10, 2022.
  1. Apr 10, 2022 at 7:04 PM
    Tech67
    Tech67 [OP] Member
    Ken
    2022 Tacoma Off Road
    Cap-it, 2" lift, Warn winch
    Greetings All. I removed the RF passenger seat on my 2022 Taco, to make room for a communications POD for both Ham Radio and EmComm use. Problem is that I now have a solid SRS Airbag alarm and a flashing seatbelt alarm. The DTC code is B1821 which is understandable since the side squib is gone. Question is, how do I simulate that the seat is still there for both the SRS airbag and the seatbelt system. There are 3 connectors on the floor of which the yellow is the SRS airbag and the grey is for the seatbelt. The white connector is for the seat heater which is irrelevant. 2016 to 2022 are similar.
    Any help on how to fool the system would be appreciated as Toyota does not want to help.
    Thanks
  2. Apr 10, 2022 at 7:18 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I suppose you could check resistance of the seat side connectors, purchase corresponding resistors and connectors, create a new harness with the resistors to make the vehicle think the seat is still there.
    Though honestly not quite certain this will work.
  3. Apr 10, 2022 at 7:22 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    DO NOT CHECT RESISTANCE OF THE AIRBAG CONNECTOR, YOU CAN DEPLOY THE AIR BAG.
    MannyS, TRDRed, MARSHBUSTER and 4 others like this.
  4. Apr 10, 2022 at 7:23 PM
    joeyv141
    New Jersey
    Hard to deploy a airbag when theres no voltage.
  5. Apr 10, 2022 at 7:23 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
  6. Apr 10, 2022 at 7:24 PM
    mlcc
    Oregon
    Multimeters send out voltage when set to ohms.
    MARSHBUSTER likes this.
  7. Apr 10, 2022 at 7:26 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Maybe @caribe makaira but I would probably harvest the tech from the seat and plug it in somewhere somehow.
  8. Apr 10, 2022 at 7:44 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I will repeat what @mlcc has already clearly stated...
    NEVER EVER PROBE AN AIRBAG WITH A MULTIMETER.
    NEVER REMOVE THE SHORTING CLIP INSIDE THE CONNECTOR.
    AIRBAGS ARE DANGEROUS AND SHOULD NOT BE WORKED WITH IF YOU DO NOT UNDERSTAND HOW THEY WORK!!!!!!
    This also includes the seatbelt buckles for the front seats, they are also an active restraint system!!!
  9. Apr 10, 2022 at 7:56 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Could you just remove the back of the seat and use the bottom as a shelf ?
    brandon78lusch likes this.
  10. Apr 10, 2022 at 8:08 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  11. Apr 10, 2022 at 8:12 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Are you completely removing the seat? Or, just temporary for the installation? Chances are you didn't remove the negative terminal on the battery, and set off the code? You can try removing the negative terminal for over 15 minutes, and then try hooking it up with the plugs connected. Otherwise, it might be an error code reset only in tech stream. @tonered
  12. Apr 10, 2022 at 8:27 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is another thread on Ham Radio that may give you some mounting ideas. Good luck with your project.
    https://www.tacomaworld.com/threads/ham-radio.585046/
  13. Apr 10, 2022 at 9:06 PM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    Should be a 3.0-3.3 ohm resistor to spoof the SQUIB. Idk about the seat belt connector though.
  14. Apr 10, 2022 at 9:09 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I’m curious what kind of radio setup was installed that is so massive it requires the passenger seat to not be installed.
    Pro-Taco, Rock Lobster and Chew like this.
  15. Apr 10, 2022 at 11:48 PM
    caribe makaira
    Caribbean, Puerto Rico
    +1
    No "passenger" means a modified SRS deployment.
    Unplugged SRS harness = DTC's.
    Of all the electrical items in the vehicle to not modify (fool) SRS is, in my opinion, one that should be left alone.
    Chew likes this.
  16. Apr 11, 2022 at 5:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry. I have no idea here, but info on TS can be found in the link in my signature.
    Skydvrr and RyanDCLB[QUOTED] like this.
  17. Apr 11, 2022 at 7:00 AM
    j45p3r
    j45p3r Well-Known Member
    Downeast Maine
    2022 MBM TRD Pro 6MT
    To measure resistance the meter is going to apply a voltage to the circuit.
    Chew likes this.
  18. Apr 11, 2022 at 7:23 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'm envisioning one of those antennas that can nearly hit overpasses and has the coil spring at the mount:D
    My butt puckers when I read airbag electrical mods,,, and given the gurus are out, my fears are confirmed. If OP ends up modifying anything and needs dealer help, you should know it's almost certain dealers will not modify or repair anything airbag related, they will only replace wiring and other devices which can get extremely expensive quickly.
    Rock Lobster likes this.
  19. Apr 11, 2022 at 7:43 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Even the batmobile has a passenger seat. If you have to delete the front pax, you might want to take a minute to reflect and ask yourself if your truck really needs all that stuff.
    A simple install is a happy install.
    :cookiemonster:
    OmahTako and Chew like this.
  20. Apr 11, 2022 at 10:52 AM
    splitbolt
    NW Arkansas
    @blackohio eliminated his when he did the Scheel-Mann seats...hasn't posted in a long while though.
