Alaska BS thread
Discussion in 'Alaska' started by benbacher, Nov 4, 2012.
  1. Dec 17, 2013 at 2:32 PM
    #5601
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    So how do the ORI's react to big temperature swings? Would it affect the dampening and ride height since the gas expands and contracts with temperature change?
  2. Dec 17, 2013 at 2:51 PM
    #5602
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Tonight we're doing that.
  3. Dec 17, 2013 at 5:53 PM
    #5603
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    Nitrogen is inert gas... Ambient temp had no effect on pressure. What you put in is what you got.
  4. Dec 17, 2013 at 6:15 PM
    #5604
    AKCD
    AKCD Well-Known Member
    Chase
    Fairbanks & Girdwood, AK
    Green 97 4Runner V6 4X4
    Temperature definitely effects the pressure of nitrogen. The fact that it is inert doesn't relate to pressure. People with nitrogen filled tires still have to adjust the pressure for temperature differentiations.
  5. Dec 17, 2013 at 6:21 PM
    #5605
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    This. It's changes less than just regular compressed air, but it still changes. Which is why I asked if it would affect the ORIs at all. Because I thought I also remember seeing another member comment on his changing height some, but I can't remember if it was temperature related or not.
  6. Dec 17, 2013 at 7:33 PM
    #5606
    AK 08TACO
    Kyle
    Wasilla, AK
    Ok I knew that it was inert and I know that it being inert has no relation to its pressure properties. I just thought temp had no bearing on its pressure overall. Apparently it's about 1psi per 10 degrees?
  7. Dec 17, 2013 at 7:40 PM
    #5607
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    :notsure: sure! Sounds about right! I have no idea on the exact amounts it changes haha
  8. Dec 17, 2013 at 7:46 PM
    #5608
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    Any idea how much that would affect the ORIs if it changed like 10-15 psi from winter to summer? I'm not sure how much pressure there is to begin with so I'm not sure if 15psi is a big deal or not..
  9. Dec 17, 2013 at 8:16 PM
    #5609
    AK 08TACO
    Kyle
    Wasilla, AK
    No sure either? I would also be curious to know the ratio of pressure to ride height? Guess it depends on your corner weight too?
  10. Dec 17, 2013 at 8:39 PM
    #5610
    AK 08TACO
    Kyle
    Wasilla, AK
    Also do you know how easy they are to rebuild a ORI strut Ben?
  11. Dec 18, 2013 at 12:02 AM
    #5611
    Syntonization
    Syntonization tAKoma Godfather
    Jeremiah
    Anchorage, AK
    09' TRD Sport dbl cab long bed
    Cooper Discoverer ST MAXX 295/70/17. Tuff Wheels 17x8 -13 Offset. Front Suspension: Fox Racing 2.5 Series Extended travel shocks w/ Eibach coil-overs, Total Chaos UCA's. Rear: Dakar Leaf Springs, Fox Racing 2.5 Series Long travel shocks. Superbump Stops. Cab mount frame chop. BruteFab frame sliders. Pelfreybuilt Front bumper, Hi-Clearance Rear w/swingarm and table. Color matched BRM! Superwinch Tigershark TS9500 SR. Morimoto 5Five FX-R Stage III HID Projector retrofit 6000K. Rigid DOT Fog lights, 20" light bar, dually ditch lights. 6500 lm LED underbody rock lights. Fog lights on any time MOD. K&N 77 Cold Air Intake. Flowmaster American Thunder CAT back dual exhaust. CompuStar 2 way remote start w/ 2 stage alarm and keyless entry. White under hood LED strip lighting, with automatic hood pin on/off switch. Dynamat & Dynaliner sound deadening in doors & cab. Kenwood DDX574BH Head unit with Maestro OBDII interface. Rockford Fosgate Punch 5 ch amp with Punch Component tweeters, woofers & sub. USB charging/data ports in blank plug under head unit. Instrument cluster, red and white LED's replacement. Backlit 4x4 selector switch. Anytime on/off Rear-view mirror back up camera. Uniden PRO520XL CB w/ co phased ATT's. Toyota Hood Protector. Coverking Neoprene black w/ red center seat covers. Color matched Devil Horns grill emblem.
    Hahaha I got to see Ben's truck first! It's pretty badass looking
  12. Dec 18, 2013 at 12:15 AM
    #5612
    benbacher
    Anchorage, AK
    I have 750 psi in there. 10-15 won't make a dent in the upper chamber. The lower however, only has about 90 psi in there. So that will be a notable difference in ride quality. Which is precisely why I'm putting together my own tank to adjust them on the fly. Going to leave the uppers where they are and alter the lower chamber when needed.
    As far as rebuilding goes, I'll send mine back to Jerry at bamf should they ever need it.
  13. Dec 18, 2013 at 12:51 AM
    #5613
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    750?? Damnnn. Yeah 10-15 won't do anything at all haha.
  14. Dec 18, 2013 at 3:36 PM
    #5614
    Syntonization
    Jeremiah
    Anchorage, AK
    Sofa king excited right meow!
  15. Dec 18, 2013 at 4:11 PM
    #5615
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    :spy:
  16. Dec 19, 2013 at 12:21 PM
    #5616
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    someone is going to have a good xmas :eek:
  17. Dec 19, 2013 at 12:47 PM
    #5617
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    What are you running right now? Just spacers and blocks?
  18. Dec 20, 2013 at 12:13 AM
    #5618
    benbacher
    Anchorage, AK
    Think he has an AAL in the rear and the revtek lift up front.
  19. Dec 21, 2013 at 2:13 PM
    #5619
    Syntonization
    Jeremiah
    Anchorage, AK
    I have the rear TSB + AAL, and RevTec coilover spacer with stock UCA's
  20. Dec 21, 2013 at 2:21 PM
    #5620
    benbacher
    Anchorage, AK
    Not no mo!
