Alaska BS thread
Discussion in 'Alaska' started by benbacher, Nov 4, 2012.
  1. Jun 10, 2014 at 9:41 PM
    #6461
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    I'm pretty much free Fri-Mon. After Friday we would have to choose another location than Ben's driveway. So if someone has some jack-stands and a location we could use then Sat, Sun or Mon work for me
  2. Jun 10, 2014 at 9:54 PM
    #6462
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Jackstands are right inside the fence should you need to swing by and grab them.
  3. Jun 10, 2014 at 10:33 PM
    #6463
    AKCD
    AKCD Well-Known Member
    Chase
    Fairbanks & Girdwood, AK
    Green 97 4Runner V6 4X4
    I've got stands. You'll need to check them out though:D
  4. Jun 10, 2014 at 10:44 PM
    #6464
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    How many quarts of oil does that require? I'm assuming you've got the 3.4l as well.
  5. Jun 10, 2014 at 10:47 PM
    #6465
    AKCD
    Chase
    Yeah 3.4l. If i remember correctly you'll want around 4 quarts. I have a clear container i drain it into that is marked so i know exactly how much to put back in when i do it. The thing here is, if your fluid is already old and in need of replacement you just need to replace it all, because the pan itself only holds like a third or a quarter of the total fluid in the transmission. Do you know of the trans over heating at all? Or is the fluid dirty or a good clearish red?
    Now that I think about it, my trans pan has a good size dent in it, as many here know, so maybe it holds more than 4. I honestly dont remember but its around that amount. Im sure the number is around the forums somewhere.
  6. Jun 10, 2014 at 11:05 PM
    #6466
    ffirg
    mike
    Anchorage, Alaska
    I don't know of it overheating and the fluid is not clear red. Doesn't look burnt either though.
  7. Jun 10, 2014 at 11:23 PM
    #6467
    ffirg
    mike
    Anchorage, Alaska
    Actually it's pretty clear still. Doesn't smell burned. Either way I should have something done. It's been shifting kind of hard lately. Especially when I put it into drive. Could that also be bad u-joints?
  8. Jun 10, 2014 at 11:37 PM
    #6468
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Automatic problems :p
  9. Jun 10, 2014 at 11:43 PM
    #6469
    ffirg
    mike
    Anchorage, Alaska
    But...first gen double cab...:pout:
  10. Jun 10, 2014 at 11:48 PM
    #6470
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    I've got tools and a driveway that could maybe be used this weekend if need be.
  11. Jun 11, 2014 at 9:31 AM
    #6471
    Kappes03
    Colorado
    2014 Tundra CM
    Sweet! Can we just work in the street? :D haha
    I.D.
    Hmmm it's a possibility.
    We can prob do it Saturday after the Meet and Greet?
  12. Jun 11, 2014 at 11:03 AM
    #6472
    Ghost.
    Ghost. TW 1%er
    Raymond
    Anchorage, AK
    4runner, Taco, GX460, Tundy
    Let's do it
  13. Jun 11, 2014 at 11:21 AM
    #6473
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    We are doing my springs thursday.
  14. Jun 12, 2014 at 9:20 AM
    #6474
    N8ivFlav
    N8ivFlav Well-Known Member
    aaron
    anchorage,ak
    04 sr5 v6
    Homertaco Satoshi,Weathertech & husky liner floormats, bamf behind grill mount and led bar, leer topper, avs rain deflectors, bug deflector, Bluetooth CD player with 6 switch panel
    Made a suicide run yesterday, had a proxy was a blast9are9a5a_3e8f03890b69155bcd99538a3d0d52545232aa76.jpg
  15. Jun 12, 2014 at 10:29 AM
    #6475
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I'm jealous
  16. Jun 12, 2014 at 8:39 PM
    #6476
    AKCD
    Chase
    I just did a drain and fill on my trans today and the pan had just over 4 qts in it FYI. If its in good shape thats what id do to save money. I did it every oil change for like 5 oil changes to get a bunch of clean fresh fluid in there and now I do it once a year.
    About the shifting, are you saying it like lurches when you put it into drive?
  17. Jun 12, 2014 at 10:42 PM
    #6477
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Lift is finished whoop whoop
  18. Jun 12, 2014 at 10:58 PM
    #6478
    ffirg
    mike
    Anchorage, Alaska
    Yes sir. Lurches forward like crazy. Does it a little going into reverse but mainly only into drive. If I'm in town Saturday I think I'll try a drain and refill. Any tips you have for it? I've never done it so I don't even know where the drain plug is lol.
  19. Jun 12, 2014 at 11:35 PM
    #6479
    Kappes03
    Colorado
    2014 Tundra CM
    Where was this at?
  20. Jun 12, 2014 at 11:41 PM
    #6480
    AKCD
    Chase
    Just like an oil change, except you put the new ATF in the dipstick tube. The drain is right on the bottom of the pan just like the engine oil pan. Make sure you've got a funnel that fits in the dipstick it's pretty skinny. And I recommend measuring how much comes out. Should be right around 4 qts but its a pain if you overfill it to remove some. And afterwords when you check the fluid level, you're going to want to do it with the trans warm and having shifted through all gears and with the engine running.
    As far as the lurch, does it do it all of the time, or when the engine is cold/ at a higher idle?
