Alaska BS thread
Discussion in 'Alaska' started by benbacher, Nov 4, 2012.
  1. Jan 10, 2018 at 12:30 AM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    I appreciate the info! What OMEs are you running?
  2. Jan 10, 2018 at 12:31 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I have all 5100s on my truck and haven’t had any problems yet but I don’t really do much to stress them in the cold. Coldest I’ve actually off-roaded and made them work was probably 20°, most of the winter is just regular road driving to work with a few bumpy unplowed roads going to some friend’s houses.
    300AACTaco likes this.
  3. Jan 10, 2018 at 12:34 AM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    I've had the 9000s up front and the 90021s from OME. I'm currently running the 9000s since they're for extra weight to be paired with 886s and that's my current setup. I used to run the 90021s and 887s and also 884s before that on them when i didn't have extra weight. I've gotten pretty familiar with the different coils (unfortunately for my wallet) lol
  4. Jan 10, 2018 at 12:39 AM
    300AACTaco
    Alaska
    I think it'd be pretty cool to do a Tacoma meet where we drive to McCarthy or the Denali highway or something like that. I drove the Denali this past summer and I think fall is probably a better time to go though. Summer weather seems pretty shit there unless you can find a really good window. I spent the night out there in a full on rain, thunder and lightning storm in my CVT with high wind, weather turned fast from sunny to crap
  5. Jan 10, 2018 at 12:44 AM
    nazlax10
    David
    Woodstock, GA
    I'm kind of in the same boat. I don't off road much if at all, it may be easier to just do the OME though since everything else (coils and leaf springs) are OME as well.
    With my current setup what shocks and coils would you recommend to level out with my back end? I obviously won't hold you to anything. My back end went from 35 3/4" to 39 1/4".
  6. Jan 10, 2018 at 12:50 AM
    300AACTaco
    Alaska
    Personally I would either go with 885s and the top plate spacer option on ToyTec.com with the 90021s, or the 9000s and 886 coils. Even though the 886s and the 9000s are made for extra weight up front and lot of people warned me that when I had those with no extra weight that the ride would be way too rough, I actually liked the ride way better. It was more stiff but it wasn't bad at all, I found it was more firm and rugged, easier to control. I went ahead and did those because I knew in the future I'd add a winch and plate bumper, and now I have the extra weight and the ride is a bit softer. Plus they haven't sagged at all under the extra weight. I had 3.5" of lift up front after 886s and 9000 shocks from OME, after the extra weight (steel skid, aluminum plate bumper, warn winch) my front is at like 3.2". So if you really wanna get a level truck that's that full 3" and won't lose it, I think the 886s and 9000s are the way to go. Because the 90021s and 885s will sag with any extra weight up front. It's all about planning for the future.
  7. Jan 10, 2018 at 12:58 AM
    nazlax10
    David
    Woodstock, GA
    I don't have any intentions of adding any significant weight anywhere else on the truck. I definitely do prefer a solid ride as opposed to bouncing around. Especially since I don't off-road much. So just to make sure I understand it right the 886s up front and 9000s all the way around with the top plate spacer should level me out?
  8. Jan 10, 2018 at 1:00 AM
    300AACTaco
    Alaska
    Everything you said is correct except: Don't add a top plate to 886s and 9000s.
    They'll give you like 3"-3.5" on their own. A top plate probably wouldn't even fit, at least not very well lol. Top plate spacer is only necessary on the 885s and 90021s
    I only threw the 1/4" spacer on the driver side to compensate for the taco lean (battery being on that side). That's the only spacer I'd add on the 886s and 9000s
  9. Jan 10, 2018 at 1:02 AM
    nazlax10
    David
    Woodstock, GA
    Oh ok. Will the Taco lean kind of correct itself with that setup?
  10. Jan 10, 2018 at 4:45 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Ha! Something like that.
  11. Jan 10, 2018 at 5:57 PM
    MOBB1N
    MOBB1N Well-Known Member
    Sam
    Palmer, Ak
    2019 SSM TRD Sport
    Pro grill
    I got my taco lean correcter from Amazon for 23$
  12. Jan 10, 2018 at 5:58 PM
    nazlax10
    David
    Woodstock, GA
    Link? :boink:
  13. Jan 10, 2018 at 6:01 PM
    MOBB1N
    Sam
    Palmer, Ak
    2019 SSM TRD Sport
    Pro grill
  14. Jan 10, 2018 at 6:03 PM
    nazlax10
    David
    Woodstock, GA
    MOBB1N[QUOTED] likes this.
  15. Jan 11, 2018 at 12:43 PM
    300AACTaco
    Alaska
    That was the spacer to correct the taco lean that I was talking about. Goes on the driver side of course
    nazlax10[QUOTED] likes this.
  16. Jan 11, 2018 at 12:45 PM
    300AACTaco
    Alaska
    Just saw this post on here but yes if you get that exact setup you shouldn't have any lean. That's the setup I have and it doesn't have any noticeable lean
  17. Jan 16, 2018 at 2:30 AM
    300AACTaco
    Alaska
  18. Jan 16, 2018 at 4:18 PM
    nazlax10
    David
    Woodstock, GA
    Anyone free this weekend and want to help install a lift on base? :D:D:D:D
    FarNorthTaco14, SnowroxKT and MOBB1N like this.
  19. Jan 16, 2018 at 7:04 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    You always pick days that are bad for me.
  20. Jan 16, 2018 at 7:17 PM
    nazlax10
    David
    Woodstock, GA
    :pout::sorry:
    That sucks man. Once it warms up we really should set up a mod day. I think it would be a lot of fun.
    SnowroxKT[QUOTED] and MOBB1N like this.
