Alaska BS thread
Discussion in 'Alaska' started by benbacher, Nov 4, 2012.
  1. Jan 6, 2013 at 10:24 PM
    #1441
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Meh, semantics ;)
  2. Jan 6, 2013 at 10:39 PM
    #1442
    jrocthakidd
    jrocthakidd My Other Ride Is An R1
    Jahon or Matt... I prefer Matt
    Fairbanks, AK
    11 Silver 4X4 SR5
    Secondary Air Filter Removed, Cobra CB Radio, 4 Foot Fire Stick Antenna, 5000k Hid Head and Fog Lights, Retrofit Headlights, 4% Tint, Pedo Bear Sticker, 3 Inch Lift, 31" Tires, Led Interior Lights,
    Yea it is
  3. Jan 7, 2013 at 12:05 AM
    #1443
    benbacher
    Anchorage, AK
  4. Jan 7, 2013 at 1:04 AM
    #1444
    av8er2012
    av8er2012 Well-Known Member
    Nick
    Wasilla AK
    Impulse Red 05 TRD offroad
    icon coilovers, bilstein 5100 rear shocks, OME dakar leaf springs, ARB front bumper, Warn XD9000 winch, Heated mirror mod, Rear diff breather mod, fog light anytime mod, Alpine W203 headunit, boston SPZ front speakers, boston SL65 rear speakers, Jl Audio HD 750/1 and 600/4 amplifiers, JL Audio 10w6v2 sub in custom box white dash w/blue needles
    A pro comp? Lol
    Im pretty sure they only make a 6" for us tacos.
  5. Jan 7, 2013 at 1:08 AM
    #1445
    benbacher
    Anchorage, AK
    I've never understood drop bracket lifts. I just don't see it as a good wheeling solution since you only gain clearance between the front and rear axle, instead of where you need it between the left and right side of the truck. How often are you trying to go sideways over a large obstacle :notsure:
    I think that's why they get a bad rap, mostly mall crawler status.
  6. Jan 7, 2013 at 1:13 AM
    #1446
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    ^That's what I've thought as well. But, everything serves a purpose of course.
    On a side note...I went through a car wash today. Condensation galore in my headlights lol.
  7. Jan 7, 2013 at 1:34 AM
    #1447
    av8er2012
    Nick
    Wasilla AK
    Ya a DB tends to get a worse rap than the regular suspension lift because of that reason. Only nice thing about a DB is the way it retains stock angles on ur cv's. so less wear and tear on those plus a litle more down travel than the normal suspension lift with out a mid travel shock. Limited on uptravel tho. And then theres the part where u gain nothing between left and right side. Id only do a DB if i added it so my icon coils i have now ;)
  8. Jan 7, 2013 at 1:36 AM
    #1448
    benbacher
    Anchorage, AK
    Which I know you CAN do, but what would be the purpose? If you're trying to run bigger tires are you really going to sacrifice clearance to do that?
  9. Jan 7, 2013 at 4:01 AM
    #1449
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    I'll be in anchorage tonight! My truck however is going to take awhile :'(
  10. Jan 7, 2013 at 5:46 AM
    #1450
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    SWEET!!, Well not so much on the truck part but at least you will be up here hangin with the cool kids. If it not here by the meet this month you should still go and just catch a ride with one of us.
  11. Jan 7, 2013 at 6:14 AM
    #1451
    jrocthakidd
    Fairbanks, AK
    11 Silver 4X4 SR5
    I looked at the specs its not a db.
  12. Jan 7, 2013 at 7:17 AM
    #1452
    Smokey11
    Jeremy
    Anchorage, Ak
    Soooooo which one is it? Post a link if ya got it.
  13. Jan 7, 2013 at 9:01 AM
    #1453
    Kappes03
    Colorado
    2014 Tundra CM
    Yea I'll hitch a ride with Matt haha
  14. Jan 7, 2013 at 10:35 AM
    #1454
    av8er2012
    Nick
    Wasilla AK
    You're not sacrificing clearance. adding a drop bracket lift is just raising where your truck sits not adding anything to suspension. So essentially putting a 3 inch suspension lift to drop bracket is the same as putting a 3 inch lift on the stock Tacoma But now you're just sitting even higher. Not sayinh its the greatest set up but it would work for the guys that wanted 8 inches of lift and 37 inch tires. Thats essentially wat TRH had on his taco and it looked awesome lol
  15. Jan 7, 2013 at 11:40 AM
    #1455
    av8er2012
    Nick
    Wasilla AK
    if its more than 3" its a DB lift. im pretty sure there no lift out there for a taco thats more than 3in thats not a DB lift. unless your doing long travel, 3in is about the max for us suspension guys and even a long travel setup doesnt really mean your riding higher.
  16. Jan 7, 2013 at 11:46 AM
    #1456
    benbacher
    Anchorage, AK
    ^truth
    In some cases you ride lower than stock, look at trophy trucks.
    And yeah I hear what you're saying about not sacrificing ground clearance, I suppose that's true but you aren't GAINING anything useful either IMO sure you can put bigger tires on but those brackets will get torn up trying to take it over anything that you could normally clear with those tires.
    And TRH does have a pretty BA truck, although I'm biased because its orange.
  17. Jan 7, 2013 at 11:51 AM
    #1457
    av8er2012
    Nick
    Wasilla AK
    which is why you get about 8 inches of lift instead of 9 lol. but if you did a 3 inch suspension lift and i took my truck and added a DB lift to it on top of my 3 inch suspension lift we would have the same amount of clearance left to right. only advantage i have would be being able to run 37's and gain a little more clearance. BUT... if you were using the truck for serious offroading your looking at having a much higher center of gravity. thats y people dont go with 8 inches of lift haha. even though it looks BA haha
  18. Jan 7, 2013 at 11:58 AM
    #1458
    benbacher
    Anchorage, AK
    Also true, haha I guess I just don't like drop bracket lifts :)
    Feels like the cheap way to halfway accomplish something that shouldn't be done halfway in the first place. If you want to sit that high but not see the gains from being that high my brain says you probably don't want to wheel it hard, and then I wonder why you went through the trouble to get that high anyway :notsure:
    It's probably just a personal preference thing. Lol, I've taken my stock truck places I shouldn't have been so seeing guys that have the resources to do the work and get good components waste it at the malls drives me nuts.
  19. Jan 7, 2013 at 12:22 PM
    #1459
    av8er2012
    Nick
    Wasilla AK
    haha i feel your pain. thats why i stopped at 3"! most guys you see wheeling hard dont have more than 3" so to me that says something.
  20. Jan 7, 2013 at 1:14 PM
    #1460
    av8er2012
    Nick
    Wasilla AK
    Ssooooooo. which one of you sport guys wants to trade axles? lol
