$Alex's PLATINUM Truck Build$
Discussion in '2nd Gen. Builds (2005-2015)' started by alexmxman185, May 25, 2011.
  1. May 25, 2011 at 8:52 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
  2. May 25, 2011 at 8:55 PM
    alexmxman185
    alexmxman185 [OP] Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    ok, no more BS'ing in my build thread.
    shew shew...
  3. May 25, 2011 at 9:23 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Just keep in the back of your mind, a 2wd with a locker and clearance can out wheel a 4wd without clearance.... Ask me how I know.
  4. May 25, 2011 at 11:30 PM
    alexmxman185
    Alex
    Waco, Texas
    ......how do you know bryan?:rolleyes:
  5. May 26, 2011 at 1:00 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I love it!!
    Oh and good start on the build. Keep it going.
  6. May 26, 2011 at 6:02 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Man I remeber the days where I used to hang out in golden builds :rolleyes: what was I thinking?
  7. May 26, 2011 at 8:58 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    You weren't wanted in the golden builds :p
  8. May 26, 2011 at 1:09 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    post pics of what u trimmed on ur bumper
  9. May 26, 2011 at 1:11 PM
    Shemicals
    Build Page
    also, whats ur mpg like now? im getting 33"s in decembeerrrr
  10. May 26, 2011 at 2:38 PM
    alexmxman185
    Alex
    Waco, Texas
    in all honesty I havent seen that much of a change. It might be cause i only went up 2 more inches but the wider tires are a plus, they hug the turns real well and my shifting changed too for the better. For some reason my truck rides smoother and isnt as jerky between shifts:notsure:
    I did feel a little decrease in power though but not to much to bother me and Im very anal (no homo) about those kind of things. Once i install my K&N and magnaflow it will hopefully compensate for lost power....:cool:
    Are you going to get a front replacement bumper??? because 33's are going to be extremely tight. I test fitted them, and it can be done but i dont recommend it. even the back side of the wheel well I would have had to start cutting corners on my actual fender....
  11. May 26, 2011 at 2:59 PM
    alexmxman185
    Alex
    Waco, Texas
    This is the rear part of the wheel well. See the part circled in red? this will stick out about an inch once you remove the black box just grab a small hammer and bend it back. It wont hurt anything its just a small piece of metal with really hard sealant on it. Just make sure you dont hit the actual fender weld behind it....
    This is the front of the wheel well. The blue area is outlined where my splash guard use to be before i removed it to give more clearance in the front. But when you do this you HAVE TO zip tie the remainder splash guard (red area) to something so the wind doesn't blow it into your tire and rip up your splash guard.
    hope this helps...
  12. May 26, 2011 at 3:16 PM
    Shemicals
    Build Page
    now post the truck befo i murda you... it looks like they fucked up your powdercoating when they put the wheel on????
  13. May 26, 2011 at 3:18 PM
    alexmxman185
    Alex
    Waco, Texas
    once again..... its lube. They use it to slip the rim into the tire:facepalm:
    PIC UPDATE CHECK 1st PAGE
  14. May 26, 2011 at 3:22 PM
    alexmxman185
    Alex
    Waco, Texas
    .....or I could just not help you? and you gtfo:D...
  15. May 26, 2011 at 4:14 PM
    #35
    Shemicals
    Build Page
    hahahaha hmmmmm i am hurt
  16. May 26, 2011 at 4:20 PM
    #36
    alexmxman185
    Alex
    Waco, Texas
    :rolleyes:
  17. May 26, 2011 at 6:50 PM
    #37
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    your truck looks sick dude!
  18. May 26, 2011 at 8:05 PM
    #38
    alexmxman185
    Alex
    Waco, Texas
    Thank you sir :cool:
  19. May 27, 2011 at 10:00 AM
    #39
    Shemicals
    Build Page
    I dont want to lose my whole front bumper so im going to do the black total chaos version. the custom trimmed the bumper so u can keep ur fogs but still run a skid
  20. May 27, 2011 at 11:31 AM
    #40
    alexmxman185
    Alex
    Waco, Texas
    cool :D Make sure to post pics.
