ALI3N'S Basic/Budget Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ALI3N_123, Jul 10, 2018.
How much lift should set my new kit to?
  1. 2.5" front, 1.5" rear
    35.7%
  2. 2" front, 1.5" rear
    21.4%
  3. 2" front, 1" rear
    17.9%
  4. Get a 2021 Sport 4x4 Premium
    25.0%
  1. Oct 21, 2019 at 10:23 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Just put in the mileage from the odometer, cost per gallon, and gallons it takes to fill up. It does the rest for you
  2. Oct 21, 2019 at 10:24 PM
    ALI3N_123
    ALI3N_123 [OP] ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    You see that just seems like a drag since I usually fill up at the gas station 2 minutes before class starts so that's that
    irayfz6[QUOTED] and Bigdaddy4760 like this.
  3. Oct 21, 2019 at 10:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Dont think in terms of worse case just yet.. first things first..
    Get an actual average mpg number like joey and i are talking about, look at some trims and we'll go from there
  4. Oct 21, 2019 at 10:26 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    Input the info while the gas is pumping, then all you need is the last number (which is gallons used). That will take half a second to put that in after the pump shuts off and you’re good to go
    ALI3N_123[QUOTED][OP] likes this.
  5. Oct 21, 2019 at 10:27 PM
    ALI3N_123
    Eric
    Austin, Texas
    I always have bad luck with everything, and my brain has naturally always prepared me for the worst possible outcome, so I want you as a professional mechanic to tell me what's the worst thing that could be wrong with my truck
    irayfz6 likes this.
  6. Oct 21, 2019 at 10:27 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    How many miles do you get out of a full tank usually?
  7. Oct 21, 2019 at 10:27 PM
    ALI3N_123
    Eric
    Austin, Texas
    irayfz6[QUOTED] likes this.
  8. Oct 21, 2019 at 10:28 PM
    ALI3N_123
    Eric
    Austin, Texas
    Highest I've seen lately was 154ish and that was to the SPI run so mostly highway miles
    b_r_o and irayfz6[QUOTED] like this.
  9. Oct 21, 2019 at 10:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Coolant temp would be helpful to know as well, engine should get around 190-200 degs quickly and stay there. You guys didnt take the thermostat out did you?
    irayfz6 and ALI3N_123[OP] like this.
  10. Oct 21, 2019 at 10:29 PM
    ALI3N_123
    Eric
    Austin, Texas
    I did not... Would there be a problem if I did?
    Do those go bad? I can buy another one and replace it
    b_r_o[QUOTED] and irayfz6 like this.
  11. Oct 21, 2019 at 10:32 PM
    ALI3N_123
    Eric
    Austin, Texas
    I did overheat while stuck in traffic at the international bridge with 103 degree weather in direct sunlight... Turned off the AC and the temperature guage immediately went back down to normal
  12. Oct 21, 2019 at 10:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Worse case would be you'd have to take the oil cap off and park a new truck under it lol
    If it sticks open the engine will run cold and cold engines burn more fuel. Usually a bad thermostat will code though.. does your cel light up key on /engine off?
    Again.. the data reader will tell us if you have a thermostat problem
  13. Oct 21, 2019 at 10:35 PM
    ALI3N_123
    Eric
    Austin, Texas
    Let me try to get is scanned sometime this week, and we'll meet up here same time this Friday night... How about that?
    irayfz6 and b_r_o[QUOTED] like this.
  14. Oct 21, 2019 at 10:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Borrowing a code reader for a couple days would be better, but scan it anyways if possible
    They're not hard to use. you connect it, punch a couple buttons and you got data on your lap while driving around
  15. Oct 21, 2019 at 10:40 PM
    ALI3N_123
    Eric
    Austin, Texas
    Yeah for sure. Should I just leave it connected for a few days and drive the truck to my regular commute?
  16. Oct 21, 2019 at 10:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yep just leave it plugged in. The cheapies have to be "turned on" every time you start the truck but again, its just a couple buttons
    There will be a bunch of hard to read data like 02 sensor voltages and stuff but all we need is short/long trims and a few others
  17. Oct 21, 2019 at 10:44 PM
    ALI3N_123
    Eric
    Austin, Texas
    I'll have my friend tell me how to operate it
  18. Oct 21, 2019 at 10:44 PM
    ALI3N_123
    Eric
    Austin, Texas
    Night dudes
    Be back in a few hours :D
    irayfz6 and b_r_o like this.
  19. Oct 21, 2019 at 10:48 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And dont forget to write down the miles and gallons next time you fill up :boink:
    :D
    irayfz6 likes this.
  20. Oct 21, 2019 at 11:01 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    Night night
