Alibaba / AliExpress Camper Shell Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by 2018H, Apr 21, 2024.
  1. Jun 13, 2025 at 8:30 PM
    #241
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    It seems to have a minimum purchase of two, but even then cheaper and possibly more useful then a smartcap. the only concerns I have looking at it are.
    - how durable and water resistant are the windows in the double door area.
    - could the outer molle handle the wind force of some max Trax mounted to it
    - you lose a few inches of headroom at the opening due to lower hinge placement.
    - the hinged molle may get in the way if trying to access gear from the side as you would need to awkwardly reach over it. Could be a good surface though depending how durable it is.
  2. Jun 14, 2025 at 10:23 PM
    #242
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    It's cute, but more moving parts more problems, I'd be wary of that design vs the simple design that others are happy with here. Really not sure what the big advantage is, a small fold out table? Surely there's other ways to achieve that :).
    As for the 2 limit, if you're interested I'd be very surprised if they didn't offer an individual item to you for a slightly higher cost.
  3. Jun 17, 2025 at 5:45 AM
    #243
    jwalter1337
    jwalter1337 Member
    Jamie
    Maine
    2016 SR5 - Quicksand DCSB
    I sent them a message and they offered a single unit at $679.50
    TRD493 and Yukon DoIt[QUOTED] like this.
  4. Jun 21, 2025 at 6:31 AM
    #244
    2018H
    2018H [OP] Well-Known Member
    How much is it shipped?
  5. Jun 24, 2025 at 10:39 AM
    #245
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Has anyone modified a sliding front window into their alibaba canopy?
  6. Jun 24, 2025 at 10:47 AM
    #246
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Have you talked to the supplier? They may be able to produce one that would fit.
  7. Jun 24, 2025 at 11:30 AM
    #247
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Yes, with a higher MOQ though
  8. Jun 24, 2025 at 2:17 PM
    #248
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    You could see if they would be able to do it for a higher rate for an individual unit, or your next best option would be finding another supplier who's able to make one, or fashion one yourself out of plexiglass. It would be pretty expensive to get a custom window done for one of these, so I doubt anyone here has bothered. Buying this to save money after all :)
    I notice that @dappstate got a sliding front window on his topper for his F150 (top of page 9), so they're out there somewhere, you might just have to try a different supplier. Personally I don't think it's going to be a big issue as a static window but YMMV.
  9. Jul 4, 2025 at 7:20 AM
    #249
    Woggs1
    Woggs1 Member
    San Francisco, ca
    2021 Tacoma TRD Off Road
    2018H[OP], Vinny C and Toyko Joe like this.
  10. Jul 4, 2025 at 8:17 AM
    #250
    bryanjoh
    bryanjoh Well-Known Member
    Bryan
    Calgary
    2016 DCLB TRD Sport
    I just picked up and installed mine this last weekend. I think I am one of the first customers on this new unit.
    First night in it tonight to shake things down.
    My order ended up taking longer than they quoted, I ordered early January and just received it late June. I'd anticipate 6 months.
    mrtonyd likes this.
  11. Jul 4, 2025 at 1:27 PM
    #251
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Looking forward to seeing photos and impressions of these! :popcorn:
    Woggs1 likes this.
  12. Jul 7, 2025 at 6:50 AM
    #252
    Woggs1
    Woggs1 Member
    San Francisco, ca
    Any first impressions? I'd love to see some pics
  13. Jul 20, 2025 at 9:17 AM
    #253
    bryanjoh
    Bryan
    Calgary
    2016 DCLB TRD Sport
  14. Jul 27, 2025 at 11:46 AM
    #254
    2018H
    That is looking very nice. Is that RTT removable and can you show the opening from where you get in to the camper?
    That mountain background is beautiful. Where is that?
  15. Aug 6, 2025 at 3:37 PM
    #255
    NFLDTACOTACO
    NFLDTACOTACO Member
    2021 White Tacoma TRD Off-Road
    how did you install the crossbars on top?
  16. Aug 9, 2025 at 4:43 AM
    #256
    2018H
    I used the bolts with big flat top head and used the flat head to hold the cross bars against the cross bars then I used washers and bold. So far it has been solid. I have used it to haul 12 2x6x16 lumbers with no issues.
    Others may have installed it differently.
  17. Aug 15, 2025 at 1:13 PM
    #257
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Not bad for $1600 with shipping and tarrifs.
    Canopy plus door molle plus light (still need to wire it in)
    My only minor complaints are.
    - Canopy brake light opening was slightly too big and the seal didn't cover it, letting light and water through. I had to caulk around it which came out looking kind of meh.
    - aligning the panels is a bit of a pain and it came out sitting slightly lower towards the passenger side in the back, which caused part of the seal bulb to rip, it's still water tight though.
    Looks much better then the other canopies from China though
    I also believe rough country gets their canopies from this manufacturer, they just don't have one for Tacomas .
    https://www.alibaba.com/x/B0VZeU?ck=pdp
    I additionally drilled a hole in the back of the rear hatch locks so that I could release them from inside with a screwdriver or other small tool if for some reason I ended up locked inside.
    Vinny C likes this.
  18. Aug 16, 2025 at 8:58 AM
    #258
    Vinny C
    Vinny C Well-Known Member
    Vince
    NE Ohio
    2019 Cement TRD OR MT
    I know they are all so barely different but that is one of the nicer ones I've seen. And a decent price. :thumbsup:
  19. Aug 18, 2025 at 11:22 AM
    #259
    btmtrd
    btmtrd Active Member
    Luis
    2019 Black Tacoma TRD
    Hi! The shell looks great. Did your shell come with the covers to the latches? Also, what cross bars are you using? Im looking for some cross bars for mine. Thank you
