alighment after lift help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Dec 22, 2009.
  1. Dec 22, 2009 at 2:37 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey guys I'm going to get the toytec ultimate lift will I nees UCA's when I lift it ot get my alighnment back to factory specs.....I have a rims with 4" backspacing and 265-75-r16 all terrains...
  2. Dec 22, 2009 at 2:49 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I think it all depends on how high you crank it up. If you go the full 3" then you are going to be able to get within specs, but not perfect. UCA's can make it perfect. If you are at 2" or so you should be alright without the UCA's. From all I read it really seems like 2.5 is about the breaking point to getting your alignment right. I am sure others will chime in, but I have been studying this a little for future reference.
  3. Dec 22, 2009 at 2:51 PM
    Brunes
    Brunes abides.
    Rotorhead
    Hendo is right...The higher you get, the more alignment issues you will have that you need UCAs to correct.
    It's worth getting them first time imo- They give you the option to crank them up later and they are easy to install all at once.
  4. Dec 22, 2009 at 3:08 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
  5. Dec 22, 2009 at 5:42 PM
    BRP27
    04 4X4 Tacoma SR5
    Just one more reason I like 1st gen
  6. Dec 24, 2009 at 7:30 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    I just did a 2.5" hbs front and 1.5" toytec rear and it drives perfectly straight but i may have it checked to be safe
  7. Dec 24, 2009 at 7:34 AM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    If you keep your lift under 2.5 you should be okay with stock UCAs.
    I just got my Kings installed at 2.5 and there were no issues at all. I would think toytec would be the same. either way get it done right away. If you are in san diego go to The Truck Shop and ask for James. He knows his stuff. Did my install and alignment.
    Tri
  8. Dec 24, 2009 at 8:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    Good Call- Driving straight and properly aligned are two different things. Mine drove straight- but there was some wicked tire scrub in turns. TOTALLY worth getting it checked.
  9. Dec 24, 2009 at 10:32 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Mine was fine when I first did my lift, but it slowely got worse and started having wondering. So I just descided to get new UCA's so that I wouldnt have any issues and my tires wouldnt wear unevenly.
    But most 1st. gens do just fine without new UCA's.
