Alighnment after adding AAL?
Discussion in 'Suspension' started by korny351, Jun 11, 2014.
  1. Jun 11, 2014 at 10:35 AM
    korny351
    korny351 [OP] Well-Known Member
    Stockton, CA
    07 DCLB SR5 4X4
    Finally getting around to installing Wheeler's 3-Leaf HD AAL. Is it necessary to have an alignment done after the install? Currently running 5100's fore and aft. Front set to 1.75 with stock springs. Rear is 3-leaf OEM.
  2. Jun 11, 2014 at 10:37 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    No alignment needed unless you changed something in the front.
  3. Jun 11, 2014 at 10:49 AM
    korny351
    Stockton, CA
    07 DCLB SR5 4X4
    Thanks for the quick reply. Front was done about a year ago, with an alignment immediately afterword. Just wasn't sure 'cuz I believe the Taco required a 4-wheel alignment.
  4. Jun 11, 2014 at 10:56 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    To my knowledge, they only require a two wheel(front) alignment. But I have been wrong before.
  5. Jun 11, 2014 at 10:58 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I thought you should get a front alignment so that it would track properly with the rear since the axle is being separated from the leaf springs. Am I mistaken? Lol if so I've spent money unnecessarily at least once in the past :p
  6. Jun 11, 2014 at 12:01 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    You should get an alignment. There is a lot of play between the centering pin and the hole which affects the thrust angle. Toyota dealer did an alignment after they installed TSB springs because the TSB calls for it.
