Align immediatly after OME lift, or wait a few days?
Discussion in 'Suspension' started by drifter, Jun 6, 2011.
  1. Jun 6, 2011 at 9:31 AM
    drifter
    drifter [OP] moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    *Maybe this should go under technical chat, if so, mod please move*
    Allright, I ordered a front OME setup *880 coils and the 90004 shocks* for my truck last night. After it gets here and is installed, should I have it aligned immediately, or wait a few days for the springs to settle a little bit? It seems to me like waiting a while would be a good idea, but it could also have bad handling during that time as well. Will these springs settle enough to tweak out the alignment if I align immediately? Any suggestions?
    Thanks,
    Sam
  2. Jun 6, 2011 at 9:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I did mine immediately after new coils/struts and would recommend the same. I took mine for a quick drive (about 5 miles or so) retightened everything, then drove it the 15-20 miles to the shop for an alignment.
  3. Jun 6, 2011 at 9:45 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    yeah driving to the shop already settling down the coils already.
  4. Jun 6, 2011 at 9:48 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Let it settle, i drove for 5 months with stock wheels with no alignment till I got it done.
  5. Jun 6, 2011 at 9:49 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    After I installed my lift I took the truck for a spin everything was fine handling wise. Tightened things up when I got home. I had plans to install rims and tires later so I waited, after I got the rims and tires I ordered UCA's. Once those were all in and on I went ahead and got an alignment. No negative affects. This was over the course of 6 months or so.
    If you see any thing that concerns you, your tires leaning or pointing, strange driving, then I would certainly go and get things checked immediately.
  6. Jun 6, 2011 at 9:52 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Probably a good idea to drive it a few days first. Couldn't really hurt, may help. Regarding this 'if it feels right' type of comment - mine all looked good, nothing noticable, drove decent. Took it in about a week later - it was quite a bit out of alignment. You should DEFINITELY get it aligned after a lift.
  7. Jun 6, 2011 at 9:54 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Good info, i will be doing mine soon, and i would have aligned it right away.
  8. Jun 6, 2011 at 9:59 AM
    Pugga
    Massachusetts
    x2. Mine was way out of alignment and I only installed a slight lift (5100's at 0 with Eibachs for about 1.5" lift). When you drove it though, nothing 'felt' out of place. It didn't drift or pull but if I left it for months it would have just chewed up my tires.
  9. Jun 6, 2011 at 10:00 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I didn't mention it in my first post, but my alignment was certainly off after, no doubt about that, any time you take your suspension apart it will throw your alignment out. However it won't harm anything except your tires with prolonged usage.
  10. Jun 6, 2011 at 10:04 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    As long as you don't have any vibes or hard pulls (safety first!), I'd give it about one week to drive it around and settle everything in so you only need to get one alignment. Go through some parking lots and roll over a few speed bumps at different speeds so you can flex those coils. That should do it.
  11. Jun 6, 2011 at 10:09 AM
    Pugga
    Massachusetts
    Having your alignment out of spec affects how the truck handles and brakes. You're right that the only part that gets worn out are the tires but tires are expensive and it can be dangerous if the truck is pulling when braking.
  12. Jun 6, 2011 at 10:14 AM
    drifter
    Sam
    Oregon
    good stuff
    All right, so maybe I'll wait a few days. I don't want to pay ~$75 dollars twice for an alignment. I just need to give the coils a good workout, like maybe hit the gravel bar etc. Thanks guys :thumbsup:
  13. Jun 6, 2011 at 10:22 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Ok so my point is if you are competent enough to drive your vehicle then you can wait longer than those that aren't. Damn.
    Yes a vehicle that is out of align is not as save and guaranteed as one that is aligned. But that also goes for a vehicle that is lifted or modified in any way, everything is affected when you change things out of stock specs. Keep in mind when you wheel you can knock your alignment out so you should check it frequently, just giving a heads up.
    Drifter search around some shops have a lifetime alignment policy. It normally cost about $190-$200 bucks but its lifetime.
  14. Jun 6, 2011 at 10:46 AM
    Pugga
    Massachusetts
    I knew what you meant, just clarifying so someone didn't just take it at face value. Sometimes common sense isn't so common ya know...
  15. Jun 6, 2011 at 11:26 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ This is a very good point! Thanks man
