Alignment 1/8 of Turn of Tie Equals Much Toe ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Sep 8, 2024.
  1. Sep 8, 2024 at 8:14 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    If adjust the tie rods out giving less toe what amount of turns of tie rod equal adjustment of the front wheels?
    In other words I am slightly too much toe trying to get 1/16 in total toe, however if I adjust each tie rod to push each wheel towards being a little straighter how much of a turn of the tie rod would i need.
    Trying to adjust each tie rod so each wheel is 0.5/16 straighter.
  2. Sep 8, 2024 at 8:59 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    0.125
    3.175 mm
    In all seriousness you can string it. Google is your friend. Best backwoods way other than eyeing down the side for toe in or out. I dought anyone has ever memorized how much of a turn is spacific to a 2005 Tacoma toe adjustment. Thats just not how its done.
    TacoBell07[OP] likes this.
  3. Sep 8, 2024 at 9:05 PM
    Bishop84
    Bishop84 Well-Known Member
    1/8th isnt much, but I've done thousands of alignments and couldnt tell you how much impact it really has.
  4. Sep 9, 2024 at 3:58 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Yeah, that small of an adjustment boils down to the minuscule details like how worn the threads are, exactly how precisely they’re manufactured, any dirt or grit in the treads, etc. we’re talking about approx 1/8th the width of a single thread here.
    Will 1/8 turn make a difference? Technically yes. But a very small one, with the exact value being specific to each individual truck.
  5. Sep 9, 2024 at 8:59 AM
    TacoBell07
    Four door 2wd Taco
    A small difference is what i need, right now its barely visible on the outside edge of the front tires. This tells me i have slightly too much toe in so i was going to try a small adjustment and watch it instead of taking hours trying to measure and adjust. And yes i know this is not the right way but its so close now thats why im trying this way.
  6. Sep 9, 2024 at 2:45 PM
    1 Limited Toyota
    California
    08 XRunner
    Scratch head...
    So you want precision results but too lazy to do what it takes?
    Work quality can be like money.
    Some people will spend a dollor to save a penny
    AusBerg likes this.
  7. Sep 9, 2024 at 4:45 PM
    risethewake
    Will
    '15 MGM Sport AC
    if you’re getting visible wear on your tires, I don’t think the alignment is as close as you think it is. And 1/8 of a turn is such a tiny adjustment that it may not make any difference at all. Each individual vehicle is different. How worn your bushings/rod ends/etc are, who manufactured your tie rods, etc etc all play into it.
    That’s why techs put em on a computerized laser alignment rack and dial it in slowly with a precise readout. Otherwise you’re just shooting in the dark/pissing into the wind.
    as said above, the string method works pretty well to get toe in the ballpark. I’ve done it plenty of times, just to get it drivable enough to make it to a shop for a proper alignment. But it’s not precise or reliable enough for a permanent fix. Unless you have unlimited time (and tire money) for trial and error.
  8. Sep 12, 2024 at 1:59 PM
    TacoBell07
    Four door 2wd Taco
    Adjusted both tie rods about a 1/8 turn looser (more toed out). Will rotate tires to unworn tires and monitor to if the same scrub wear occurs on the outside edge of the tires.
  9. Sep 12, 2024 at 2:30 PM
    TacoTuesday1
    FL
    I turn it until it's where I want it
  10. Sep 12, 2024 at 9:33 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Worn rack or lca, turning left and right not rotating tires will also wear your tire.
  11. Sep 16, 2024 at 9:45 AM
    TacoBell07
    Four door 2wd Taco
    Replaced all LCA bushings with poly ones so thats fine. Now with 300K on the vehicle my rack might not be unworn i guess LOL
  12. Sep 16, 2024 at 10:07 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I believe the thread pitch of the tie rods are 1.5mm. 1/8th of a turn = .1875mm. if you do both sides = .375mm.
    Spindle pivot axis to tie rod is ~ 1/3rd of the raidus of the outer edge of a stock size tire. .375 x 3 = 1.125mm difference at the outer edge of ONE side of the tire, total toe difference between front and back will be ~
    2.25mm
  13. Sep 16, 2024 at 8:15 PM
    TacoBell07
    Four door 2wd Taco
    What do you mean spindle pivot axis to tie rod is 1/3 of the radius. Extended the tie rods 1/8 turn on each side so how would not be 1/4 in or 0.25 in toed in total ??
