Alignment 1" lift
Discussion in 'Suspension' started by Ktm350JH, Sep 18, 2015.
  1. Sep 18, 2015 at 7:30 AM
    Ktm350JH
    Ktm350JH [OP] Well-Known Member
    What is the desired caster ? I have seen 3 *. And camber and toe zeroed out seems to be the norm? Should I have had it aligned before I changed the to billy 5100. It has always driven straight .
  2. Sep 19, 2015 at 9:57 AM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    To where it doesn't pull.
  3. Sep 23, 2015 at 10:35 AM
    Ktm350JH
    Yea all the LCA bushings are froze up . I got it somewhat aligned . It's not right . Maybe when I get back in town I will buy new LCA and hardware kit and install. Right now caster is 1.3 difference from side to side.
  4. Sep 23, 2015 at 6:22 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I was recently told by a Firestone manager that up to 1 degree difference was okay. I told him to put it back on the rack. However if your camber and toe are okag I think you won't eat tires?
    I really liked the handling when I had 1 degree of caster. High 2s was also nice, in between kinda sucked, in a worst of both worlds way.
    Check out the Moog greaseable bolts and total chaos cam tabs.
